    Need help with attitude at slic3r pe
    Example setups and prints
    962
    • thwe
      thwe last edited by
      As you can see in the picture, throughout filled areas (green marked area) are good .
      As soon as the nozzle moves to the next area, mass flows out of the nozzle (see red marked areas).
      Can I adjust the slic3r pe to make a retraction within a layer when traveling without extrusion?
      Thomas
      • PuterPro
        PuterPro last edited by
        It's in Printer Settings -> Extruder 1 -> Lift Z. Tell it in mm how high to lift. Called Z Hop in Cura, FYI.
        thwe 1 Reply Last reply Reply Quote 0
        • Veti
          Veti last edited by
          i think its called avoid crossing perimeters in slic3r pe
          in cura its combing mode
          • thwe
            thwe @PuterPro last edited by
            @puterpro thanks for your answer
            this is paramter name "avoid_crossing_perimeters" = true in my case
            unfortunately does not help, because this parameter only prevents crossing contours
            a retract is therefore not carried out
            Thomas
            PuterPro 1 Reply Last reply Reply Quote 0
            • thwe
              thwe @Veti last edited by
              @veti thanks for your answer
              this is paramter name "retract_lift#0" = 0 in my case
              this paramter will lift z at each retract but there is no retract
              Thomas
              • Veti
                Veti last edited by
                why not give cura a try?
                • thwe
                  @veti
                  only if that is the last solution
                  this should not mean anything against cura. I have now incorporated myself in Slic3r reasonably. Add to that the understanding of the duet - that's too much for me at once
                  Thomas
                  • thwe
                    thwe last edited by
                    at the last layer of the plate he makes a retract before approaching new areas
                    that would be just fine between the lowest and highest levels ...
                    Thomas
                    • PuterPro
                      PuterPro @thwe last edited by
                      @thwe - Well, I tried ☺
                      Just a casual PE user, but been playing more with latest build. More of a Cura guy ...
                        I wish there was a Z hop on top layer option. I've used a work around on prints where I needed a very clean top surface. I use firmware retraction so I can simply go into the sliced gcode file, find the Z height of the surface layer. Insert the gcode command to enable 1mm of Zhop M207 Z1 . Then I'll turn it off again after the surface layer is finished if it isn't already the topmost layer.
                        https://duet3d.dozuki.com/Wiki/Gcode#Section_M207_Set_retract_length
                        You may also need to adjust your minimum travel after retraction value in printer settings > extruder 1. This is how long a travel must be before a retraction is triggered. 5mm seems to work for me.
                        • thwe
                          thwe @Phaedrux last edited by
                          @phaedrux said in Need help with attitude at slic3r pe:
                          Thank you for your answer, this value I have at 2mm, but it makes no retract ☹
                          I'll make a small 10 x 10 x 3mm plate and experiment with it ...
                          Thomas
                          • OBELIKS
                            OBELIKS last edited by
                            It should be retracting in these cases. Slice a model, go to preview window and enable retractions, unretractions and travel moves. You should see gray dots for retractions, blue lines are for travel moves and maybe you will also see red lines for wipe moves.
                            P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
                            Original Prusa i3 MK3S
                            • thwe
                              thwe @OBELIKS last edited by
                              @obeliks thank you, i will try and see (hopefully ☺ )
                              Thomas
