    Duet 3 first-generation prototype giveaway
    34
    4.5k
    • nopheadundefined
      nophead
      What is the timescale for production Duet 3's? I am designing a machine that has some CAN peripherals but I won't finish it anytime soon.
      I like the idea of a small firmware that just does the realtime stuff and the rest on an SBC in Python. That is how my early machines work, including HydraRaptor and the very first Mendel90.
      DocTruckerundefined fmaundefined 2 Replies Last reply Reply Quote 1
      • DocTruckerundefined
        DocTrucker @nophead
        @nophead said in Duet 3 first-generation prototype giveaway:
        No real detailed research went it to using python over anything else but it's how I set up the metal sintering (edit: melting) machines for MCP/MTT/Renishaw. Hardcore realtime stuff for the lasers through the API/application for the scanners and less time dependant stuff through the PLC controllers.
        No complaints about the python though and it can be really powerful on the text file manipulation. Finally dusting off my coding hat with trying to sort out the python side of the Ciclops scanner and attempting to get RepRapFirmware on a dev board. Anyhow I digress.
        Still need to read through that monster background reading file that is on the reprap site.
        • Cataundefined
          Cata @dc42
          @dc42 said in Duet 3 first-generation prototype giveaway:
          this board was designed to be capable of running standalone, without an attached Raspberry Pi
          • Slidexundefined
            Slidex
            Good luck to the guys that get these boards, just been setting up my Wifi 2, awesome board, great job
            • fmaundefined
              fma @nophead
              It's the Replicape approach.
              Frédéric
                dc42 administrators @fma
                @fma said in Duet 3 first-generation prototype giveaway:
                Speaking as an experienced real time systems engineer, IMO it's a very bad idea to have the motion planning written in an interpreted language, running on a processor running a non-realtime operating system, that is also doing many other tasks.
                The Duet 3 approach is to do just the initial GCode parsing on the single board computer, send them to the Duet 3 main board over a dedicated bus (not a shared USB), do the motion planning on the Duet 3 main board running under RTOS, and do the step generation on the main board and the expansion boards.
                nopheadundefined 1 Reply Last reply Reply Quote 1
                • fmaundefined
                  fma
                  You are right. I owned a Replicape, and was not really satisfied. That's why I switched to the Duet 😉
                  On the other hand, if we drop Python, using C under linux is a good way to go, and works fine: LinxCNC is a good example. It needs a (almost) RT kernel, though.
                  Frédéric
                  • nopheadundefined
                    nophead @dc42
                    @dc42 The motion planning does not need to be realtime, only the actually stepping of the motors. As long as the data is produced fast enough to keep a buffer full it works. I sent trapezoids to my real time code encoded as a list of step durations during the ramps, the constant speed step duration and the total number of steps. My reatime code just did the Bresenham loop. Never had to change in more than 10 years and only needs a tiny 16 bit micro.
                      DocTrucker
                      The speed difference between good and bad python scripts is also stunning.
                      • nopheadundefined
                        nophead
                        Yes but it doesn't need to be fast because 3D printers are very slow. Even a slicer written in Python runs many times faster than the printer that prints the result.
                          DocTrucker @nophead
                          @nophead yes. I took slice data for 50 mircron layers for the laser machines and in most cases break the vectors down into a sequence of points around 50 microns apart while the system was inerting and while another process was running the laser/galvo control card. It did fall over with lots of little sections from time to time.
                          I wanted to look at setting a a parameter file for build on these systems and slice individual layers direct from STL on the fly for similar reasons to what you state. Nothing ground breaking but would tidy uo a lot of things like parameter change on the fly and killing parts that are failing.
                          Edit: This parsing on the fly could also work to get rid of a lot of timy vectors that some of our slicers make, which can cause issues.
                            Exactly so. Just because the average speed of the slicer is faster than the printer, that doesn't mean that you don't need real-time performance for the critical parts - in particular, curved perimeters. A perimeter printed at 80mm/sec with a resolution of 0.2mm equates to 400 segments per second. Doing the motion planning for that demands real-time performance.
                            nopheadundefined 1 Reply Last reply Reply Quote 0
                            • nopheadundefined
                              nophead @dc42
                              @dc42 No it doesn't because motion planning does not depend on real time input, so it can be done in advance. I process all of the gcode on my PC, or an RPI, before the printer starts moving. and then send trapezoids to my firmware using Ethernet.
                              Do you know that the Glowforge laser cutter does all its motion planning in the cloud and sends stepper motor waveforms for the whole job over http? Crazy, but it works.
                              DocTruckerundefined zaptaundefined 2 Replies Last reply Reply Quote 0
                                DocTrucker @nophead
                                @nophead What are the best reads for the various approaches to motion planning or is it all very scattered?
                                • nopheadundefined
                                  nophead @DocTrucker
                                  @doctrucker I don't know. I don't read many books. I did spend 30 years writing real time embedded software though before giving it up to make 3D printers and then retiring.
                                  • zaptaundefined
                                    zapta @nophead
                                    How do you handle motion related configurations that are done at the printer's level? E.g. from config.gcode? Do you feed them to the off line planner?
                                      DocTrucker @nophead
                                      @nophead it was a genuine question following your name drop on the 'Bresenham loop', which I will look up. My question wasn't intended to put you on the defensive. Likewise most of my tricks have been learnt on the fly rather than a single source but it was worth asking.
                                        How does offline planning handle changes in extrusion factor? Or changes in speed factor without violating acceleration and jerk limits? Or pause and resume? Not to mention other dynamic changes that are useful when tuning the printer, such as changes to pressure advance, jerk, acceleration etc.
                                        DocTruckerundefined Edgars Batnaundefined 2 Replies Last reply Reply Quote 0
                                          DocTrucker @dc42
                                          @dc42 we prepared a buffer of slices and if the user made changes these were applied a few slices ahead of the systems current position in order to avoid any stutters.
                                          Edit: We also weren't processing right down to step sequences, just doing any coding that required a measure of look ahead or geometric correction. Essentially we cleaned the slice data and simplified it.
                                          • Edgars Batnaundefined
                                            Edgars Batna @dc42
                                            The discussion about realtime vs non-realtime can be a catch 22, but generally I agree about having only stepper control in real-time. I've got quite a bit of desktop application development experience and I've been learning the RepRapFirmware for around 6 months now as a hobby to do some custom things to my printer. To be entirely honest there's not enough resources on such machines. Even if you do find the resources, you end spending more time and the code ends up hard to read and debug. I'd much prefer non-realtime planning, well, on an actual OS and CPU with RAM, including some actual development tools. Pardon if it's a bit harsh, but debugPrint is not the way of the future. In any case, I really appreciate the amount of features made possible so far.
