    Pay for config / json files for my corexy printer build.
    67
    5.7k
    • Stevoundefined
      Stevo
      This be the "Road runner" lol
      Finished it last year enjoyed nearly every minute of the build lol
      • Stevoundefined
        Stevo @Veti
        @veti as follows.....
        • Stevoundefined
          Stevo
          Evening,
          If I wanted to home y axis first prior to the x due to how i plan to locate the x and y endstops have I made suitable alterations to the home all file to do this ?
          Be gentle lol
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v2 on Wed Jun 26 2019 19:39:28 GMT+0100 (BST)
          G91 ; relative positioning
          G1 Z15 F6000 S2 ; lift Z relative to current position
          G1 S1 Y445 F1800 ; move quickly to Y endstop and stop there (first pass)
          G1 S1 X445 F1800 ; move quickly to X endstop and stop there (first pass)
          G1 X-5 Y-5 F6000 ; go back a few mm
          G1 S1 X445 F360 ; move slowly to X axis endstop once more (second pass)
          G1 S1 Y445 ; then move slowly to Y axis endstop
          G90 ; absolute positioning
          G1 X188 Y-222 F6000 ; go to first bed probe point and home Z
            Yes that looks correct.
            Stevoundefined 1 Reply Last reply Reply Quote 0
            • Stevoundefined
              Stevo @Phaedrux
              @phaedrux should I swap around the x and “move slowly” commands ? Towards the end of the file
                That will depend if the end stops will still be lined up or not. If you need to get Y homed first to line up X, is the switch contact area large enough to trigger 5mm away? If it's still going to miss, you can switch the order of the second X and Y moves so that it moves Y first.
                You can copy and paste each line of the macro into the gcode console to execute it one at a time for testing to make sure it actually works.
                • Stevoundefined
                  Stevo @Phaedrux
                  @phaedrux thank you very much like that
                  • DanLundefined
                    DanL
                    @stevo said in Pay for config / json files for my corexy printer build.:
                    G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move
                    G1 R1 X0 Y0 ; go back to the last print move
                    M83 ; relative extruder moves
                    G1 E10 F3600 ; extrude 10mm of filament
                    More of a question than a suggestion....
                    Theway I read the above is that 10mm of filament will be deposited on top of the last print position. Shouldn't the extrude filament command be first...as a priming step....then move the extruder to the last position to start printing again?
                    This is a really helpful thread...thanks!
                    DanL
                    • Stevoundefined
                      Stevo
                      Evening,
                      I have done the final wire up and fitted the BLTouch and both X and Y limits.
                      Been editing the files to get me to where I am as follows,
                      When I turn on the printer the BL touch deploys and retracts twice and then lights up red self test ?
                      I can then hit the home all and the y axis will home firstly then followed by the x axis homing after this has completed the print head moves to the centre of the printbed which then starts to rise but the probe does nothing in regards to the homing of the z axis.
                      I realise I have not put the offsets in for the BLTouch just wanted to get an understanding of how the z homing should work.
                      Have wired BLTouch as per be true 3d link
                      Would appreciate a pointer please.
                      ; generated by RepRapFirmware Configuration Tool v2 on Tue Jul 23 2019 21:10:42 GMT+0100 (BST)
                      M669 K1 ; Select CoreXY mode
                      M550 P"WILE E COYOTE" ; Set machine name
                      M552 S1 ; Enable network
                      ;*** Access point is configured manually via M587
                      M586 P0 S1 ; Enable HTTP
                      M586 P1 S0 ; Disable FTP
                      M586 P2 S0 ; Disable Telnet
                      M569 P0 S1 ; Physical drive 0 goes forwards
                      M569 P1 S1 ; Physical drive 1 goes forwards
                      M569 P2 S0 ; Physical drive 2 goes backwards
                      M569 P3 S1 ; Physical drive 3 goes forwards
                      M92 X80.00 Y80.00 Z1600.00 E420.00 ; Set steps per mm
                      M566 X900.00 Y900.00 Z30.00 E2400 ; Set maximum instantaneous speed changes (mm/min)
                      M203 X6000.00 Y6000.00 Z144.00 E1200.00 ; Set maximum speeds (mm/min)
                      M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
                      M906 X800.00 Y800.00 Z2000.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
                      M84 S30 ; Set idle timeout
                      M208 X-220 Y-220 Z0 S1 ; Set axis minima
                      M208 X220 Y220 Z660 S0 ; Set axis maxima
                      M574 X1 Y1 S0 ; Set active low and disabled endstops
                      M574 Z1 S2 ; Define Z to use Probe. Home to Min.
                      M558 P5 H5 F500 T4000 X0 Y0 Z1 ; Set Z probe type/mode 5. Not using on XY, but using it on Z.
                      G31 P25 X0 Y-25.3 Z0.0 ; Z probe trigger value, offset in relation to nozzle. And trigger height
                      M574 Z1 S2 ; Set endstops controlled by probe
                      M307 H7 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                      M558 P9 H5 F100 T2000 ; Set Z probe type to bltouch and the dive height + speeds
                      G31 X0 Y0 Z0 P25 ; Set Z probe trigger value, offset and trigger height
                      M557 X220:220 Y-220:220 S20 ; Define mesh grid
                      ; BLTouch - Heaters
                      M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
                      M140 H-1 ; Disable heated bed
                      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                      M106 P0 S0 I0 F500 H-1 C ; Part cooling fan
                      M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                      M563 P0 D0 H1 ; Define tool 0
                      T0 ; Select first tool
                      ; homeall.g
                      G1 S1 Y-445 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                      G1 Y5 F6000 ; go back a few mm
                      G1 S1 Y-445 F360 ; move slowly to Y axis endstop once more (second pass)
                      G1 S1 X-445 F1800 ; move quickly to X axis endstop and stop there (first pass)
                      G1 X5 F6000 ; go back a few mm
                      G1 S1 X-445 F360 ; move slowly to X axis endstop once more (second pass)
                      G1 X0 Y0 F6000 ; go to first bed probe point and home Z
                      ;G91 ; relative positioning
                      ;G1 S2 Z15 F100 ; lift Z relative to current position
                      ;G90 ; absolute positioning
                      ; homez.g
                      ; called to home the Z axis
                      G30 ; Do a single probe to home our Z axis
                      G90 ; Make sure we are in absolute mode
                      G1 Z10 F6000 ; Rapidly move the Z axis to Z=10.
                      ; homex.g
                      ; called to home the X axis
                      G1 Z-15 F6000 S2 ; lower Z again
                      ; homey.g
                      ; called to home the Y axis
                      ; deployprobe.g
                      ; called to deploy a physical Z probe
                      M280 P3 S10 I1
                      ; retractprobe.g
                      ; called to retract a physical Z probe
                      M280 P3 S90 I1
                        Phaedrux Moderator @Stevo
                        ; BLTouch - Heaters
                        You've got a few commands duplicated there. You should probably clean those up to prevent future confusion.
                        It would seem you are using 0,0 as bed center? Just checking.
                        ; homez.g
                        You may want to add a G1 X Y move before the G30 to place the probe in the same location as you do in homeall for consistency, unless you have different plans for using homez alone in certain situations. That's valid, but just be aware that G28 and G28 Z will give you very different results.
                        ; BLTouch - Heaters
                        ; deployprobe.g
                        M280 P3 S10 I1
                        You're unbinding heater pin 7, but then you're targeting servo 3 in your deploy and retract commands. I think this is the reason the probe isn't doing anything. If you are actually using pin 7, then change the servo commands to be P7 instead of P3.
                        Did you test the deploy and retract macros? What happens if you send M401 and M402? (should be deploy and retract)
                        Use this procedure for safely testing your probe. https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                        • Stevoundefined
                          Stevo @Phaedrux
                          @phaedrux Thank you for the help as always much appreciated!
                          Will report back once I have sorted my mess out lol.
                          • Stevoundefined
                            Stevo
                            Evening all,
                            Now have signs of life from the BL touch on hitting the home button the bed lowers 15mm the y axis then homes followed by the x axis homing and then the printhead moves to the middle of the machine and deploys the probe and upon touching the bed and retracting the table lowers 15mm again.
                            Its a little hit and miss as sometimes when I turn the machine on the bl will just flash red and will not deploy at the z axis homing stage.
                            If I actually deploy the prove manually after one of these instances but prior to powering the machine on everything seems to be ok ?
                            G31 P25 X0 Y-25.3 Z0.0 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                            M558 P9 H15 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
                            G31 P500 X32 Y2 Z2.5 ; Set Z probe trigger value, offset and trigger height
                            M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                            ; homeall.g
                            ; homex.g
                            ; homey.g
                            ; homez.g
                            G1 X0 Y0 F6000 ; go to first probe point
                              Some people add a command to reset the BLTouch out of an error state, before using it for probing. You can add this command in homez.g and homeall.g (before the G30 command), and if you wish in bed.g. It's an M280 command but I forget the details. You may need a short G4 delay command after it, to make sure that the reset happens before the firmware tries to deploy the probe.
                                Try adding this to the end of your config.g to clear any BLTouch errors and retract the pin just in case.
                                ; BLTOUCH PREP
                                G4 S1
                                M280 P7 S160 I1 		; Alarm Release and Push-Pin UP just in case it's in alarm and deployed
                                G4 S1
                                M402				; Retract probe just in case it's down
                                You've still got some probe settings duplicated in the endstops and zprobe section.
                                • Stevoundefined
                                  Stevo
                                  Thank you that's done the trick !
                                  • Stevoundefined
                                    Stevo
                                    Evening all,
                                    Just wanted to ask when the printer has finished its task how / where do I ask it to lower the bed and come back to the homing corner minima on x and y to cool print head down bearing in mind my origin is the centre of the build plate.
                                    M104 S0 ;Turn off extruder heater
                                    G91 ;Relative positioning
                                    G1 Z 10 E-5 F300 ; Lower bed by 10mm and retract filament by 5mm
                                    G1 S1 Y-150 X-150 F500 ;Move nozzle 150mm home direction out of the way of finished print.
                                    M84 ;Motors off
                                    G90 ;Absolute positioning
                                    • zaptaundefined
                                      zapta
                                      Does this help? https://forum.duet3d.com/topic/6760/stop-g
                                      • Stevoundefined
                                        Stevo @zapta
                                        @zapta thank you !
                                        • Stevoundefined
                                          Stevo
                                          Evening all just wondered if one of you kind folk could cast an eye over my config file to see if it could be improved in any way please speeds and placement of codes within the file.
                                          As always your comments greatly received
                                          M550 P"CORE XY" ; Set machine name
                                          M92 X80.00 Y80.00 Z1600.00 E415.00 ; Set steps per mm
                                          G31 P25 X2 Y32 Z0.0 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
                                          ; BLTOUCH PREP
                                          G4 S1
                                          G4 S1
                                          G31 P500 X32 Y2 Z0.96 ; Set Z probe trigger value, offset and trigger height
                                          ; BLTOUCH PREP
                                          G4 S1
                                          G4 S1
                                            deckingman @Stevo
                                            @stevo If I was being really pedantic I'd say that you have disabled thermostatic mode for your part cooling fan (M106 P0 H-1) which is fine, but the comment after says "Thermostatic control is turned on" (should say "off").
                                            But I'm not feeling pedantic so I won't make that comment.
                                            Seriously, nothing leaps out as being obviously amiss. I think you are at the stage of playing around with things to see if the end result looks any better or can be printed faster without degrading quality. One good thing about Duet is that you can play around with things "one the fly".
                                            If you want, you can give your heaters and fans names for example such as "Hot end" rather than the default "heater 1" (M305 "S") or "Part fan" rather than "fan 0" (M106 "C").
                                            You could try firmware retraction (G10 /G11). It won't work any better than your slicer but you can play around with it "on the fly" which is a far easier way to tune the retraction settings.
                                            You could also play around with pressure advance (M572).
