Duet 3 Mainboard 6HC - initial production run.
243
32.7k
    A Former User @evan38109
    @evan38109 said in Duet 3 Mainboard 6HC - initial production run.:
    Is it just VIN?
    yeah
      dc42 administrators @evan38109
      Dumb question: what voltage do the 5A OUT1-3 receive, the ones intended for "extruder heaters or similar?" Is it just VIN?
      https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview#Section_Heating_Fans
      Yes.
        deckingman @T3P3Tony
        @t3p3tony said in Duet 3 Mainboard 6HC - initial production run.:
        @deckingman said in Duet 3 Mainboard 6HC - initial production run.:
        @t3p3tony
        Tony, there is a bit of a conflict in the documentation https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview.
        The picture of the boards has a graphic with the words "6x stepper drivers rated to 4A peak". But under "Features" the words say "Six high-current advanced TMC5160 stepper drivers: SPI controlled will all the latest Trinamic features. Maximum motor current 6.3A peak per phase (4.45A RMS)."
        As DC ran the thermal tests on an expansion board at 6.3A, I'm assuming the "4A" in the graphic is incorrect.
        Thanks Ian - its fixed now
        Still showing 4A here https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview
        undefined 1 Reply Last reply 13 Aug 2019, 08:59 Reply Quote 0
          wilriker @gtj0
          @gtj0 said in Duet 3 Mainboard 6HC - initial production run.:
          MonoDevelop doesn't support .NET Core projects using .csproj project files. It complains about the project file not having a ProjectGuid.
          It does so for me. Which versions of MonoDevelop and .NET Core do you use? I have MonoDevelop 7.8.3 and .NET Core 2.2.401 (with 2.2.6 Runtime).
          Manuel
          My Tool Collection
          undefined 1 Reply Last reply 12 Aug 2019, 13:35 Reply Quote 0
            A Former User @T3P3Tony
            @calvinx Thats the plan - just see if we can get them sorted in time for this initial batch.
            Thanks for the clarification.
            Whats the plan to cater for those that purchased the initial batch if you cant amass connectors and plugs in time ?
              Dougal1957
              @t3p3tony Tony how is the pr-orders going for the first batch I need to order one but won't be able to till the end of this week?
              Cheers
              Doug
              undefined 1 Reply Last reply 12 Aug 2019, 13:56 Reply Quote 0
                gtj0 @wilriker
                @wilriker said in Duet 3 Mainboard 6HC - initial production run.:
                .NET Core is the same but MonoDevelop is 5.10.0 which is what's packaged for Fedora. Upgrading to 7.8 fixed it. Thanks Manuel!
                  Danal @Dougal1957
                  @dougal1957 said in Duet 3 Mainboard 6HC - initial production run.:
                  Cheers
                  Doug
                  Also curious. I'll order one, just to support you guys, if there are enough left to stand a good chance of the order going through in this first batch.
                  undefined 1 Reply Last reply 13 Aug 2019, 09:01 Reply Quote 0
                    fotomas
                    The "Hardware overview" of the Duet 3 says "Ethernet for future expansion", I am guessing that this is a typo and the board has an ethernet connection not using WiFi?
                    undefined 1 Reply Last reply 12 Aug 2019, 19:49 Reply Quote 0
                      deckingman @fotomas
                      @fotomas The RPi has an RJ45 Ethernet which is what will be used for the web server etc. So my guess (and it is just a guess) would be that it's not typo but is indeed an additional Ethernet connector.
                      ? undefined 2 Replies Last reply 12 Aug 2019, 19:58 Reply Quote 0
                        A Former User @deckingman
                        @deckingman
                        You are correct the pi 3B+ also has wifi
                        @fotomas
                        I think you would benefit from reading and analyze and digest the documentation in greater detail, as guessing is the mother of all F******s
                          A Former User
                          The ethernet port has been covered earlier in this very thread..
                          https://forum.duet3d.com/post/104297
                          https://forum.duet3d.com/post/104241
                            dc42 administrators @deckingman
                            The Ethernet connector is there for 2 reasons:
                            1. For possible support of EtherCat in future.
                            2. We have a small number of OEMs who use Duet 2 in print farms, where one PC uploads GCode files to multiple Duets. They will need to replicate this with Duet 3. So there will be the possibility of running the Duet 3 in standalone mode with a local SD card and no RPi. Then the Ethernet port will be used to upload files, send commands and get status, just like the Duet 2. But we haven't yet decided whether to fit the SD card socket as standard to the initial production run.
                            undefined undefined 2 Replies Last reply 12 Aug 2019, 21:28 Reply Quote 0
                              gtj0 @dc42
                              @dc42 If you decide to not populate them, will the Duet3's be field upgradable if we decide we'd like that functionality? I.E. Is it just a matter of adding the magnetics/jack and the sd card holder?
                                T3P3Tony administrators @deckingman
                                @deckingman yes 4A but RMS now. David has tested over 4A RMS but I will keep the claim to 4 for now until we have done more testing
                                undefined 1 Reply Last reply 13 Aug 2019, 09:36 Reply Quote 0
                                  T3P3Tony administrators @Danal
                                  @danal @Dougal1957
                                  We still have some of the first batch unallocated. When we have sold out of that production run it will be out of stock on the website.
                                  The "normal" production run later this year will not be a pre-order.
                                  Cheers
                                  Tony
                                    DocTrucker @T3P3Tony
                                    ...yes 4A but RMS now.
                                    Does the gcode current limit now instruct the drivers to maintain an RMS value or use the value as a limit to chop the current at?
                                      DocTrucker
                                      Judging by the post on ecoansion board testing 4A RMS is roughly 5.7A peak, but I guess the exact relationship between RMS and peak will be related to drive voltage and the electrical properties of the motor.
                                      If the Duet 3 does still control at peak current does it report RMS or was that just read off the test rig equipment?
                                        M950 motor currents in RRF have always been peak. This is because when the original Duet 0.6 came out, instructions for setting potentiometers on stepsticks were given in terms of peak current, probably because the Allegro drivers that were generally used referred to peak currents in the datasheet.
                                        Trinamic mostly refers to RMS currents in their datasheet. Somewhat confusingly, Marlin has adopted RMS current in its current-setting commands for Trinamic drivers, even though builds of Marlin for boards with non-Trinamic drivers that support motor current setting (e.g. RAMBO) have almost certainly always used peak current.
                                        The maximum allowed M906 value in the latest RRF3 builds for Duet 3 is 6300.
                                          fotomas @dc42
                                          I am probably slow here but I have read the hardware overview and it is not clear if a Raspnerry Pi I needed to use the web interface?
                                          Has the duet 3 network.connectivity on it's own, wired or wireless?
                                          The hardware overview states the following, and what is referred as "It" marked in bold? The duet 3 or a Raspbeery Pi.
                                          The Duet 3 mainboard has a dedicated high speed SPI bus to a single board computer (SBC). The reference implementation is a Raspberry Pi 3B or newer. The SBC provides the user interface (via a browser based control application called Duet Web Control, or a third party application). It also provides a network interface via the local network or VPN depending on how it is configured.
                                          undefined 1 Reply Last reply 13 Aug 2019, 17:32 Reply Quote 0
                                          54 out of 243
