    Wifi/Web Console issues
    2.6k
    • Shaunundefined
      Shaun @T3P3Tony
      @t3p3tony I can only get it connected when i run YAT
      M552 s0
      m587 s"name" p"password"
      M552 s1
      Then it connects, try the web console which honestly struggles. WHen i manage to get into the settings to confirm that M552 S1 is set in the config.g it returns a "make sure your device is connected"
      When i shut down and then transfer to the printer, wifi doesnt even come on. I get no blue light once i move the board.
      Ive cleared the saved details and then set them using M587, i have even tried DHCP and Static details.
      • Shaunundefined
        Shaun @A Former User
        @bearer
        M587 gives me my SID, IP. gateway is 0.0.0.0 and subnet is 0.0.0.0
        Can remember what M122 was. can get it as soon as i get home.
        Latest firmware, as part of the troubleshooting i did was to follow the instruction to update both firmware from this link.
        https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
        Shaunundefined 1 Reply Last reply Reply Quote 0
        • Shaunundefined
          Shaun @Shaun
          @shaun m552 s0
          ok<LF>WiFi module started<LF>
          m115#
          FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2<LF>ok<LF>
          • Shaunundefined
            Shaun @Shaun
            @shaun === Diagnostics ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later<LF>Board ID: 08DGM-9T6BU-FG3SN-6J9F4-3SD6R-TUZHF<LF>Used output buffers: 1 of 24 (1 max)<LF>=== RTOS ===<LF>Static ram: 25680<LF>Dynamic ram: 93244 of which 0 recycled<LF>Exception stack ram used: 304<LF>Never used ram: 11844<LF>Tasks: NETWORK(ready,548) HEAT(blocked,1236) MAIN(running,4256) IDLE(ready,160)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:02:42 ago, cause: software<LF>Last software reset at 2019-08-26 16:36, reason: User, spinning module GCodes, available RAM 6564 bytes (slot 1)<LF>Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0440f000 BFAR 0xe000ed38 SP 0xffffffff Task 0xffffffff<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms, max retries 0<LF>MCU temperature: min 31.9, current 32.9, max 33.0<LF>Supply voltage: min 1.7, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power goo<Warning: Maximal number of bytes per line exceeded! Check the end-of-line settings or increase the limit in the advanced terminal settings.>
            • Shaunundefined
              Shaun
              OK
              So today ive started all over. literally clean slate. I am now able to get the wifi connected pretty quickly, the webconsole is responding nicely. only 1 problem... When i remove the board after shutting down Yat and powering it by the printer the wifi doesnt come back on. No blue light.
              Ive had to actually edit the config.json to get this far. now from my eye everythign looks right.
              Config.json:
              "network": {
              "enabled": true,
              "mac_address": "",
              "name": "CR10",
              "password": "",
              "ssid": "Spiffy",
              "ssid_password": "nicetry", (not really my password)
              "dhcp": true,
              "ip": "192.168.0.20",
              "netmask": "255.255.255.0",
              "gateway": "192.168.0.1",
              "protocols": {
              "http": true,
              "ftp": false,
              "telnet": false
              M115:
              M552 S1 is in the config.g file.
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              Still cannot get the wifi to online and join.
              • Shaunundefined
                Shaun @T3P3Tony
                @t3p3tony Are you technical support for the product?
                  T3P3Tony administrators @Shaun
                  @shaun said in Wifi/Web Console issues:
                  M552 s0
                  M552 s1
                  Can you run M122, from YAT, one the wifi is connected. It should show what the DB of the wifi signal you are getting.
                  When you put it in the printer, is that now in a metal enclosure, or is the printer further form the wifi router?
                  T3P3Tonyundefined Shaunundefined 2 Replies Last reply Reply Quote 0
                    A Former User
                    Need to configure line endings in YAT or use another terminal btw.
                    when you start editing config.json its probably time to move off the web configurator and stick to only editing config.g as well; duet boards does not read config.json.
                      T3P3Tony administrators @T3P3Tony
                      @Shaun I just see you have posted part of M122 above. If you set YAT to use the correct line endings you will get nicer output that wont be truncated.
                      Go to Terminal/Settings/Text Settings and change the EOL sequence to <LF>.
                        A Former User
                        (OT, when YAT is the recommended terminal, I'd change the firmware EOL to be compatible with the default settings of YAT)
                          T3P3Tony administrators @A Former User
                          @bearer good point, or at least send both.
                          • Shaunundefined
                            Shaun @T3P3Tony
                            @t3p3tony Let me clarify, WIFI now connects when i run M552 S0 then M552 S1. Webconsole also responds pretty quickly.
                            When moving the board to the printer i power it without connecting it or placing it into anything. Simply laying it down in the foam from inside the shipping box. The wifi blue light doesnt even blink once.
                            Signal strength isnt a problem, i checked the strength many times as i use to have the Pi there without any issues.
                            Do you have any suggestions in getting the wifi fired up without having to send code to the board via YAT
                            • Shaunundefined
                              @bearer I hear you, but i only managed to get a stable connection once i added her SID and Password to Config.json so its clearly reading from it. I dont have those details in the Config.g.
                              • Shaunundefined
                                Shaun @T3P3Tony
                                @t3p3tony said in Wifi/Web Console issues:
                                Noted
                                  A Former User @Shaun
                                  No.
                                  yes, thats correct, after you enter the details with M587 it is stored in the wifi modules flash memory. which is part of the reason the documentations tells you not to use M587 (to store wifi details) in config.g, the wifi module is not enabled at the time config.g is executed and saving the wifi details every time would put unnecessary wear on the wifi flash memory.
                                  Shaunundefined 1 Reply Last reply Reply Quote 1
                                  • Shaunundefined
                                    @bearer said in Wifi/Web Console issues:
                                    No.
                                    OK, so could you help me figure out why the wifi is not even coming on when i power the board? At which point is M552 S0 read from Flash?
                                    Phaedruxundefined A Former User? 2 Replies Last reply Reply Quote 0
                                    • MrsDelishundefined
                                      MrsDelish
                                      M552 S0 = turn off networking, you do not want that in your config.g if you want networking.
                                      config.g that contains this should connect if a ssid and pw is previously set.
                                      gcode wiki M552
                                        Phaedrux Moderator @Shaun
                                        What is the power supply? Do the rest of the lights and everything else come on?
                                        When it is powered by the PSU, can you connect via USB as well and send M122 with the correct YAT line endings and report what the diagnostic replies with?
                                        • Shaunundefined
                                          Shaun @Phaedrux
                                          @phaedrux said in Wifi/Web Console issues:
                                          Ill get this when i get home, PSU is as per vendor recommendations.
                                          Red light by the USB power port, 2 more lights to the left of that. No blue wifi light.
                                            Understood.
                                            With the line endings of YAT changed we will be able to see the end of the diagnostic report which contains the wifi section. Without that we're kind of blind as to what's going on.
                                            Can you also include the contents of config.g from the /sys folder on the SD card?
                                            That contains your current configuration and what you will be editing going forward. It can be edited from the web interface once you can get reliably connected to it. Until then it may require pulling the SD card unfortunately.
