    PanelDue cant update
    PanelDue
    852
    • TPJensenundefined
      TPJensen
      Hi
      I have a panel due but I cant update the firmware.
      I have downloaded Bossa and as I read I have to use bossa in command line.
      So I have tried that also but that dont work....
      Can panelDue be updated by SD-card or another why Bossa or Bossac stinks
        A Former User
        Does your computer recognize the USB device?
        @tpjensen said in PanelDue cant update:
        No, there has been talk of being able to update the firmware from the Duet Web Control, but not yet supported and would likely require a normal update first in any case.
          What OS and what version of Bossa have you tried?
          What procedure for updating are you following?
          TPJensenundefined 1 Reply Last reply Reply Quote 0
          • TPJensenundefined
            TPJensen @Phaedrux
            @Phaedrux
            https://miscsolutions.wordpress.com/paneldue/
            I used this site under Testing the board and updating the firmware
            Bossa verion i used 1.9.1
              T3P3Tony administrators @TPJensen
              @TPJensen how does the board show up when plugged into your computer - as a comm port?
              TPJensenundefined 2 Replies Last reply Reply Quote 0
              • TPJensenundefined
                TPJensen @T3P3Tony
                This post is deleted!
                • TPJensenundefined
                  TPJensen @T3P3Tony
                  @T3P3Tony
                  It dont look like it is showing up... Paneldue turns ON and shows a panel due 1.20beta1 firmware
                    @TPJensen so no comm port detected at all?
                    • oliofundefined
                      oliof
                      IIRC the comm port only shows up after you erase the current firmware, which makes it a bit unnerving for newcomers to do the update (and the comm port is very temperamental when you cannot use the windows drivers for some reason).
                        T3P3Tony administrators @oliof
                        @oliof aahh good point, @TPJensen did you follow there steps pf the guide you linked to:
                        • Press and hold the Erase button of the PanelDue for at least one second. You can access this button by pressing the end of a straightened-out paper clip through the hole in the enclosure.
                        • Release the Erase button, then press and release the Reset button. If you have a version 2.0 board then the backlight will turn off.
                        • Identify the COM port number or port name of the PanelDue board on your PC. If you use Windows, you can do this via Start->Control Panel->System->Device Manager. Expand Ports (COM and LPT), and look for Bossa port. Make a note of the port number. If you can’t find the port, try repeating the Erase and Reset sequence, or disconnecting and reconnecting the USB cable, or try a different USB port on your computer. Note: the port number of the Bossa port for PanelDue will not be the same as the one you use when uploading firmware to Duet electronics.
                        • TPJensenundefined
                          TPJensen
                          Okay thanks to your all, I will try to erase the firmware tommorow when I have more time.
                          I hope it will go smooth.
                          It is a weird way paneldue have to update.
                          • TPJensenundefined
                            TPJensen @T3P3Tony
                            @T3P3Tony
                            okay now it find it as com5
                            But cant get the program to update to paneldue
                            here is what I do and what comes up
                            C:\Users\jense>C:\Program Files (x86)\BOSSA\bossac.exe" --port=COM5 -e -w -v -b D:\PanelDue-v2-7.0C.bin
                            'C:\Program' is not recognized as an internal or external command,
                            operable program or batch file.
                              A Former User @TPJensen
                              @TPJensen said in PanelDue cant update:
                              wrong use of "
                              try "C:\Program Files (x86)\BOSSA\bossac.exe" --port=COM5 -e -w -v -b D:\PanelDue-v2-7.0C.bin
                                droftarts administrators
                                The single quote mark " is messing up the command. It's probably easiest to cd (change directory) to the folder that contains bossac, then you don't have to worry so much about getting the path right.
                                cd "C:\Program Files (x86)\BOSSA\"
                                Then run it from there with
                                bossac.exe --port=COM5 -e -w -v -b D:\PanelDue-v2-7.0C.bin
                                @bearer beat me to it!
                                • TPJensenundefined
                                  TPJensen
                                  @bearer @droftarts
                                  Thank you that worked 👍
                                  can I on the paneldue set TEMP with onscreen keybord or macros ?
                                  or is the only thing to do is use
                                  -5 -1 SET +1+5 ?
                                    Phaedrux Moderator @TPJensen
                                    @TPJensen You can set temps using macros or the onscreen keyboard if you wish.
                                    • TPJensenundefined
                                      TPJensen @Phaedrux
                                      @Phaedrux said in PanelDue cant update:
                                      How fo I get it to use the onscreen keyboard for TEMP ? I only get -5 -1 SET +1+5 if I choose the temp
                                        A Former User
                                        you don't get a keyboard for the temp, you get a console for generic g-code.
                                          If you hold your fingernail on the +5 it will auto-repeat, allowing you to go from 0 to printing temperature quite quickly.
                                          • TPJensenundefined
                                            TPJensen @dc42
                                            @dc42 said in PanelDue cant update:
                                            Super that works.. Thank you
