Board cannot update firmware
Firmware installation
8
23
4.1k
    T3P3Tony administrators
    When you placed the files directly on the SD card did you put them in the /sys subfolder?
    have you had a look here:
    https://duet3d.com/wiki/Updating_main_firmware
    and here:
    https://duet3d.com/wiki/Updating_WiFi_firmware_or_DuetWebControl_files
    It should not be looking for "duetfirmware.bin"
      Dougal1957
      Think the Clue might be that the Op did the DWC First this is probably why the rest is failing The WiKi does explicitly state the order of upgrade is Duet Fw followed by WiFi Server followed by DWC.
        GeckoBox3D
        I think that might be the case Dougal, although I don't know how to uninstall the DWC or where to find the old version. I did not see this in the Wiki till after I followed the recent firmware update thread by Chrishamm which had the link for the DWC first, and then the firmware.
        Otherwise, yes I have placed it in the .sys folder and there are no other sessions open. Other browsers give the same error.
          It should still work from USB, even if DWC is not working properly due to a firmware mismatch.
          Can you confirm you have the files named correctly? you originally said there was an error finding the firmware file, even from usb.
            GeckoBox3D
            I kept the name the same as what I downloaded, and tried renaming it to what it wanted to find in the error message.
            For reference, this is "Duetwififirmware-1.17b.bin" and "duetwififirmware.bin"
              please can you do a cut and paste of the M997 response, I think capitalisation is important so try with the files names as they are here:
                GeckoBox3D
                I'm using M997 S0…. it responds with
                SENT: M997 S0
                RECEIVED: Error: Firmware binary "DuetWiFiFirmware.bin" not found
                  InSanity
                  Sounds like you file needs to be named exactly "DuetWiFiFirmware.bin" with the same exact capitalization.
                  Jeff
                  Duet WiFi Powered FFCP with E3D legends hotend system. BLTouch grid leveling.
                    GeckoBox3D
                    I have tried that, and it doesn't work. I have updated my old duet board using the downloaded file names before. I also doubt that is the issue, as if it was everyone else who downloaded the latest update would have this problem.
                    Does anyone know how to start from scratch and reupload firmware?
                      InSanity
                      I used backup procedure #3 when I replaced my main CPU on the board. See link:
                      Updating main firmware
                      Jeff
                        If you upload new firmware via DWC and accept DWC's offer to install it, then DWC will do the file renaming for you. If you copy the new firmware file to the SD card any other way, then you need to rename the file to the correct name yourself.
                          @dc42:
                          That I did not know. How clever is it (just strip the last characters in the file name or inspect the binary header for what firmware type it is?)
                            GeckoBox3D
                            I will be using the software in back up procedure 3 tonight to bring the board back to life… However I might suggest that incompatible firmware/DWC/wifiserver releases should come with a warning message to stop incompatible installs. Having the wiki is great, but it feels backwards to have to find important info in it after you make the mistake....
                              InSanity
                              @GeckoBox3D:
                              You may actually have to downgrade the firmware and then update DWC and WiFIServer then upgrade as needed.
                              Jeff
                                @GeckoBox3D:
                                If you send M997 manually then the file names in /sys must be exactly right, e.g. DuetWiFiFirmware.bin.
                                The general rule is:
                                1. Install new main firmware. This is always compatible with the previous version of DWC and DuetWiFiServer - although not necessarily compatible with much older versions of DWC.
                                2. Install the new DuetWiFiServer, if there is a new one.
                                3. Finally, install the new DWC.
                                In what way did it "not work" when you renamed the downloaded firmware file to DuetWiFiFirmware.bin and sent M997 S0 ?
                                  GeckoBox3D
                                  It did exactly the same as explained above, if I try to upload it via the DWC it says 'error' in the loading bar (same as any upload including .stl files for printing), and if I upload it via usb I get the "DuetWifiFirmware.bin not found" message. This is with and without renaming the files.
                                    See backup procedure #1 at https://duet3d.com/wiki/Updating_main_firmware.
                                      thooijer
                                      Last night , experienced almost the same thing.
                                      Updated in the wrong order via the web interface.
                                      Could see a message that renaming failed in the web interface.
                                      Adding the new DuetWifiFirmware.bin to the sd card in the sys folder then M997 S0 would wipe the DuetWifiFirmware.bin file and
                                      gave the error :Firmware binary "DuetWiFiFirmware.bin" not found.
                                      Procedure 3 did the trick, updated to the latest firmwares and webinterface now.
                                        GeckoBox3D
                                        @thooijer:
                                        Exactly the same for me as well. Renaming files did not work at all, no matter what interface I used. Quite a pain though, I feel like there should be a warning message for installing non-compatible firmwares.
                                          hum3
                                          Another in the heffalump trap!
                                          I had loaded the Web Interface first. Fix was like procedure 1.
                                          • Power down and extracted the uSD card
                                          • Copy and rename the latest set of files
                                          • Reinserted card and powered on
                                          • Send the command on the web interface M997 S0 this upgraded the firmware
                                          • Then upgraded the WIFI server using the web server
                                          Looking better - so back to rebuild the Ormerod 1. Such quiet motors - lovely.,
