    CR-10S5 Firmware
    Firmware installation
    15
    145
    8.2k
    • Gost101undefined
      Gost101
      All of the endstops switch to NO upon being at zero, however the endstop is not stoping the axis from wanting to move after the endstop has been triggered. They Y motor moves now perfectly, seemed to be a loose wire on the connector attached to the motor.
        Endstops are only active when doing a homing move with G1 S1
        • Gost101undefined
          Gost101
          Cool beans, that is the next task. I need to fix the homing functions next, as they don't move the intended motor. I'm also still having a probelm with syncing the z axis. Going down is fine, however going up will produce a stair case affect (one motor will spin while the other doesnot then the motors switch and do the same thing)
          • Gost101undefined
            Gost101
            All of the homing functions are fixed, I'm at a restaurant right now, but I will post the config and home files when I get back. Is there a way to make the z move fast on the way down, but slow on the way up?
            • Gost101undefined
              Gost101
              Home ALL homeall (1).g
              ; homeall.g
              ; called to home all axes
              ; generated by RepRapFirmware Configuration Tool v2.0.3 on Wed Sep 11 2019 20:24:24 GMT-0600 (Mountain Daylight Time)
              ; Y
              G91               ; relative positioning
              G1 S1 Y-505 F1800 ; move quickly to Y axis endstop and stop there (first pass)
              G1 Y5 F6000       ; go back a few mm
              G1 S1 Y-505 F360  ; move slowly to Y axis endstop once more (second pass)
              G90               ; absolute positioning
              ; X
              G1 S1 X-505 F1800 ; move quickly to X axis endstop and stop there (first pass)
              G1 X5 F6000       ; go back a few mm
              G1 S1 X-505 F360  ; move slowly to X axis endstop once more (second pass)
              ; Z
              M92 Z400.00      ; Move Z Fast
              G1 S1 Z-505 F3000 ; move Z down until the endstop is triggered
              G92 Z0            ; set Z position to axis minimum (you may want to adjust this)
              G1 Z1 F6000       ; go back a few mm
              M92 Z80		  ; Move Slow
              G1 S1 Z-505 F400 ; move slowly to X axis endstop once more (second pass)
              Home X homex.g
              ; homex.g
              ; called to home the X axis
              Home Y homey.g
              ; homey.g
              ; called to home the Y axis
              Home Z homez (1).g
              ; homez.g
              ; called to home the Z axis
              M92 Z80		  ; Move Slow
              • Gost101undefined
                Gost101
                I just got my BLTouch in today, but I will have to print out the mount once this can print.
                What I have to do next:
                Either figure out:
                Why my hot end thermister is not working.
                -Possibly rewire
                Why my hotend will not heat up.
                -Possibly rewire
                -Wait for the new one to arrive: Here
                Figure out how to use a filament sensor
                Replace Main Hotend fan for a Noctua fan: Here
                  Phaedrux Moderator @Gost101
                  @Gost101 said in CR-10S5 Firmware:
                  M92 Z80 ; Move Slow
                  Nope, this isn't right. You're changing the steps per mm value for the axis, which isn't changing the speed it's changing how far it's moving per rotation. Not sure what the intention is there.
                    When you switch to a z probe you can follow the guidance here for setting up the probe and the Z homing macro:
                    https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_Z_using_a_Z_probe
                    https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
                    • Gost101undefined
                      Gost101
                      Is there a way to make the axis move faster besides changing the steps/mm?
                        Change the feed rate of the move.
                        • Gost101undefined
                          Gost101
                          Which command is that?
                            That's the F parameter of the G1 moves
                            • Gost101undefined
                              Gost101
                              Here is the latest config files.
                              I need to print the BLTouch mount before I can begin using it.
                              Everything heats up, however I'm having trouble with the e3D Volcano extruding (I just bough a Bondtech Extruder to hopeful solve this as the stock extruder is skipping. I will try to see if the hotend is clogged, I don't think it is due to being a e3D nozzle X.
                              Everything works at the moment, so I will attempt a benchy.
                              Config.g: config.g
                              ;config.g
                              ; Created by Gost101 on Saturday, September 28th, 2019 at 18:00 MST (6:00PM for Civs).
                              ; This firmware discussion can be found on duet fourm: https://forum.duet3d.com/topic/11964/cr-10s5-firmware/37
                              ; Contact gost1017@gmail.com for more help.
                              G90                                      ; send absolute coordinates...
                              M83                                      ; ...but relative extruder moves
                              M550 P"A.C.E."                           ; set printer name
                              M669 K0                                  ; select Cartesian mode
                              M551 P"12345"                            ; set password
                              M552 S1                                  ; enable network
                              M586 P0 S1                               ; enable HTTP
                              M586 P1 S0                               ; disable FTP
                              M586 P2 S0                               ; disable Telnet
                              M569 P0 S1                               ; X physical drive 0 goes forwards
                              M569 P1 S1                               ; Y physical drive 1 goes forwards
                              M569 P2 S0                               ; Z physical drive 2 goes backwards
                              M569 P3 S1                               ; E physical drive 3 goes forwards
                              M584 X0 Y1 Z2 E3                         ; set drive mapping
                              M350 X16 Y16 Z16 E16 I1                  ; configure microstepping with interpolation
                              M92 X80.00 Y78.00 Z400.00 E420.00        ; set steps per mm
                              M566 X900.00 Y900.00 Z1400.00 E120.00    ; set maximum instantaneous speed changes (mm/min)
                              M203 X6000.00 Y6000.00 Z1400.00 E1200.00 ; set maximum speeds (mm/min)
                              M201 X500.00 Y500.00 Z1400.00 E250.00    ; set accelerations (mm/s^2)
                              M906 X800 Y800 Z8000 E800 I30            ; set motor currents (mA) and motor idle factor in per cent
                              M84 S30                                  ; Set idle timeout
                              M208 X0:500 Y0:500 Z0:500                ; set axis maxima
                              M574 X1 Y1 Z1 S1                         ; set active high endstops
                              M558 P0 H5 F120 T6000                    ; disable Z probe but set dive height, probe speed and travel speed
                              M557 X15:215 Y15:195 S20                 ; define mesh grid
                              M305 P0 T100000 B4138 R4700              ; set thermistor + ADC parameters for heater 0
                              M143 H0 S120                             ; set temperature limit for heater 0 to 120C
                              M305 P1 T100000 B4138 R4700              ; set thermistor + ADC parameters for heater 1
                              M143 H1 S280                             ; set temperature limit for heater 1 to 280C
                              M106 P0 S0 I0 F500 H-1                   ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                              M106 P1 S1 I0 F500 H1 T45                ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                              M563 P0 D0 H1 F0                         ; define tool 0
                              G10 P0 X0 Y0 Z0                          ; set tool 0 axis offsets
                              G10 P0 R0 S0                             ; set initial tool 0 active and standby temperatures to 0C
                              Home All: homeall.g
                              ; homeall.g
                              ; Created by Gost101 on Saturday, September 28th, 2019 at 18:00 (6:00PM for Civs).
                              ; Y-Axis
                              G1 S1 Y-505 F3000  ; move quickly to Y axis endstop and stop there (first pass)
                              G1 Y5 F1000        ; go back a few mm
                              ; X-Axis
                              ; Z-Axis
                              G1 S1 Z-505 F10000 ; move Z down until the endstop is triggered
                              G1 Z3 F800         ; go back a few mm
                              G1 S1 Z-505 F80    ; move slowly to X axis endstop once more (second pass)
                              Home X: homex.g
                              ; homex.g
                              Home Y: homey.g
                              ; homey.g
                              Home Z: homez.g
                              ; homez.g
                              ; This firmware discussion can be found on duet fourm: https://forum.duet3d.com/topic/11964/cr10s5-firmware/37
                              ;G91                 ; relative positioning
                              ;G1 S2 Z5 F100       ; lift Z relative to current position
                              ;G90                 ; absolute positioning
                              • JamesMundefined
                                JamesM
                                Your thermistor settings are wrong for both your bed and hotend.....The bed should be M305 P0 T100000 B3950 R4700 and the volcano if it has the E3D cartridge thermistor should be M305 P1 T100000 B4725 C7.060000e-8 R4700
                                • Gost101undefined
                                  Gost101
                                  Thanks, I changed that before this print: ![alt text]IMG_20190929_174503.jpg alt text
                                  • Gost101undefined
                                    Gost101
                                    I've got a lot of tweaking to do.
                                      It's not... THAT bad... I guess.
                                      • Gost101undefined
                                        Gost101
                                        The e3D volcano keeps getting clogged. In between the nozzle and the Capricorn tube there is a little gap that wont close and the filament expands into that and wont let me extrude. I purchased the bontech extruder to hopefully overpower the clog. Any thoughts on what to do?
                                          jay_s_uk
                                          When holding the bowden tube firmly in place, fit the little clip. This should prevent the bowden tube from moving and the gap opening.
                                          If you don't have a clip, fit a tie wrap to keep the bowden fitting in the heat sink in its highest position.
                                          • Gost101undefined
                                            Gost101
                                            I have a clip, however this dose not work. Confusion?????
