    Core-XY based on Rat Rig V-Core and Duet 2 Ethernet
    My Duet controlled machine
    15
    176
    27.6k
    • snoozerundefined
      snoozer
      I really took some time off the printer and started from scratch with the Titan Aero mount including the piezo and having a detachable extruder from the base plate. Some preliminary work is shown below. Base plate and bolted on extruder mount with a flat part for the piezo, it can be seen slightly visible. A couple of guides for the PTFE tube and wiring. A bit of a support for a wire guide will bolt on to the back that's what the M3 nuts are for. On the side is also the mount for my (still) mechanical end stop. Playing with it in hand pushing down on a surface it is VERY sensitive but wont know for sure until its mounted.
      After all that I have to say I am not sure I would use a Titan Aero next time. I find the mount requires just to much asymmetric shapes and it is not easy to get the nozzle centered. Also what I have notices is yes, it is very compact vertically but its not ideal horizontally. Have been looking at the BMG M extruder now with Mosquito hotend, that looks way easier due to the symmetry of everything and yes its way more expensive...... next printer 😉
      Regards Jan
      My Printers:
      #1 Prusa i3 MK3 kit all stock (Retired)
      #2 Rat Rig V-Core Core-XY (Almost finished but fully usable)
      My Experiments:
      https://www.thingiverse.com/snoozer17/designs
        Have you considered using an underslung mount for the Aero? Like this? https://www.thingiverse.com/thing:2849355
        It rotates the Aero 90 degrees and has the motor riding under the rail.
        snoozerundefined 1 Reply Last reply Reply Quote 0
        • snoozerundefined
          snoozer @Phaedrux
          @Phaedrux
          I would find that a waste of build height to be honest, That vertical compactness of the Titan Aero was THE main reason why I got it. The BMG./Mosquito design could be placed mostly above the gantry to maintain build height. I think that I have to accept the limitations at this point. What annoys me the most is that the belt fastening/tensioning is part of the hotend/extruder mount. In any future design I would make sure mechanics are independent of hotend and other components.
          Have FuN!
          Jan
          Regards Jan
          My Printers:
          My Experiments:
          • snoozerundefined
            snoozer
            Right, I am back to my 1st design (Orange PLA further up in a pic), all I am gaining on the Y axis would be 7mm with the new design or so, cant be bothered. The underslung mount and some others similar lose significant Z height, I prefer not to follow down that road. On top of those issues I have not yet received my machined cast Aluminium plate. The supplier in the UK did not want to send to IRL so I used Parcel Wizard in NI with a UK Address. The supplier had all the details correct as confirmed by mail BUT left some details out on the shipment so now DPD can not associate the delivery to my Parcel Wizard Account....... emails back and forth now for a week...... I nothing happens I order a new plate from IRL this time.
            I have been looking a lot more into the Mosquito Magnum and the BMG M, I see a lot of advantages mechanically with that entire idea, The heat-break no longer has to deal with any mechanical load and no more frustration on nozzle changes with spinning heatblock. The nozzle change drama is what stops me from using bigger nozzles on big prints, I hardly ever need fine detail, just strong and fast is what I need most times. The downside is the price, the lot with extruder, hotend, heater etc comes to approx 380 Euro. Have to sleep a few nights over that.
            So all in all a bunch of delays by choice and inflicted from outside.
            Jan
            Regards Jan
            My Printers:
            My Experiments:
            • OBELIKSundefined
              OBELIKS
              I hope snoozer and mods don't mind, RatRig has a sale for this kit ATM
              P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
              Original Prusa i3 MK3S
              • snoozerundefined
                snoozer
                Hello after a long time,
                summer is over and social life is returning to a lower level of intensity. I have not touched the printer all summer, was just to much RL stuff going on. Back at it now since a few days.
                So the state of play right now:
                • Precision Piezo is set up and working
                • Still original print bed
                • Optical end stops in progress as we speak.
                The piezo probe took me some time to get working. The issue I had mostly was it would not trigger at low speed but super sensitive on acceleration and even walk by. For now I ended up wedging the piezo between the V-Core metal carrier and the printed hotend mount. My attempts with a "pocket" for the piezo failed every time and location. I have a bit faster moves now for probing on the Z axis but slowed the X and Y right down between probe points for mesh levelling. Probing the entire bed now can take approx 10 min but thats OK cause it works SUPER good and I don't need to do it every time anyway. The microswitch based end stops for X and Y click, even that click sets off the piezo, so I finally have to get on with my optical end stops. Printing holders now and wipers to pass through.
                A more serious mechanical issue with the RatRig design is the fact that I have 2 independent yet from the same driver driven steppers. During my probing fails that caused the entire bed to go out of level alignment. For now to quick fix that issue I print sleeves that go over the Z lead screws to have a fixed level point at the bottom to align this. For a permanent solution I will upgrade to the 3x lead screws and also join the motors with a drive belt, the 3rd lead screw having the belt drive only from the other 2 motors. I may have issued with weight in the end. the aluminium plate with the glass print surface is over 5kg (weighing scales max), so I might have to upgrade the motors or use one big motor to drive the 3 lead screws, not sure yet.
                Anyway, I am back on track and I see a linear rail version of this on the horizon. RatRig have that in the pipe.
                Have FuN!
                Jan P.
                Regards Jan
                My Printers:
                My Experiments:
                • grizewaldundefined
                  grizewald
                  I just finished my upgrade to the V2 hardware and three Z motors. I drive them separately so that I can use the Duet firmware's auto levelling. Of course, I needed to get a Duex expansion board so that I had enough stepper drivers.
                  Before, when I had two Z motors, I could also drive them separately and keep the bed level on the X axis.
                  Any reason why you don't use this feature?
                  Fitting the Orion to my V-Core was simple. I created a custom hot end mount which was designed to fit with the parts that Idris has made available on Thingiverse: Precision Piezo Orion Parts
                  Basically, I used the E3D groove clamp for the hot end and incorporated the essential elements of the corresponding top into the design of my hot end mount. The essential elements are simply four 3mm holes arranged on 26mm centres for the screws which go into the clamp and a 15mm wide conical depression above the Orion board which allows it to flex when the clamp transmits pressure on the nozzle to the board.
                  I'm currently working on a new design for the mount so that the clamp for the hot end can be screwed on from below. As it is now, I need to use 50mm long M3 screws which go all the way through the mount from the top and that's not exactly ideal.
                  • snoozerundefined
                    snoozer
                    @grizewald , thanks for the suggestion. The reason I don't use independent motor drives is that I am convinced once the belts are in place on the lead screws like in @deckingman's printer there is simply no need to drive them separate. I am using a (or will be once I have it machined) 10mm aluminium plate as heated bed and 5mm float glass. I think it will be very rigid. The maximum height difference would come from the pitch of the lead screw over one notch of the belt. I am very confident that can be dealt with with the mesh bed levelling. Also now that I have seen they will have a linear rail version of the RatRig soon (November / December apparently) I don't want to spend any money on the extension board, I rather build the new version once I have this one done.
                    Re piezos, I am not using a E3D V6, I have a Titan Aero, my mount would be very different. The reasons behind that choice have been mainly the gain in build height and less leverage on the nozzle due to the shorter compacter design. My next build will NOT have a Titan Aero again, in fact I probably go away from E3D and look at the BMG-M with the Mosquito hotend. I had issues with clogging (had the fan speed to low) and the extruder is often missing steps at higher speeds (not a pancake motor). So for now I am OK with the piezo cowboy style mount cause it works. I will revisit that once I have the print bed finished. I am not happy with my hotend mount anyway, its very hard to service. I would love a modular (possibly magnetic) mount.
                    Anyway, optical end stops 1st, proper bed next.
                    Regards
                    Jan P.
                    Regards Jan
                    My Printers:
                    My Experiments:
                    deckingmanundefined grizewaldundefined 2 Replies Last reply Reply Quote 0
                      deckingman @snoozer
                      @snoozer said in Core-XY based on Rat Rig V-Core and Duet 2 Ethernet:
                      Not even that. To get the bed level, simply slacken the grub screws on the pulleys and turn each individual screw. Once level, tighten the grub screws and that's it until you take the printer apart. Built correctly (and it's not difficult or expensive to do) there is no need for any flatness or level compensation - ever.
                      • snoozerundefined
                        snoozer
                        I have just put all parts for the print bed on my bench here. I can't remember what I have read re isolation now. Looking from top down what would be the best order of layers:
                        1. Aluminium plate (bed)
                        2. Heater
                        3. Glass fiber reinforced aluminium foil
                        4. mineral wool
                        5. Cork
                        6. Mechanical layer to keep it all in place.
                        I am not clear about the aluminium, would that be 1st after the heater or last before the mechanical layer ? I would use the original old RatRig print bed as mechanical layer to close of the bottom I think.
                        Thanks
                        Jan P.
                        PS: I would use the aluminium 1st after the heater to reflect heat back rather than absorb in the other materials. Just my logic which may be wrong ofc.
                        Regards Jan
                        My Printers:
                        My Experiments:
                        grizewaldundefined 1 Reply Last reply Reply Quote 0
                          grizewald @snoozer
                          I concur with your logic. My bed is, from top to bottom:
                          PEX sheet.
                          Spring steel sheet.
                          Magnet sheet.
                          4mm aluminium bed.
                          Silicone heating pad.
                          Aluminium tape.
                          2mm cork sheet.
                          With high temperature double sided adhesive between the various layers.
                          It heats up quickly and the temperature at bottom of the cork surface is less than half thar of the top of the spring steel sheet.
                            grizewald @snoozer
                            Ah... very different indeed.
                            I have a Mosquito hot end which has just arrived. Once I have printed various parts, I'll be replacing the E3D V6.
                            My reason for getting the Mosquito is the ease and simplicity of nozzle changes. It's just a one handed operation and can be done with the hot end cold.
                            Changing nozzles on a V6 is such a fraught process that I just don't want to do it. Sadly, there are many times when a different sized nozzle would be much more appropriate than a generic 0.4mm one and I was getting to the point of contemplating building a quick change carriage and have three of four complete assemblies to swap in and out. A crazy expensive solution just to work around the horrors of wielding an adjustable wrench in one hand, a spanner in the other and trying to avoid serious burns, a cracked heat break, damaged sensor wires and a host of other traps!
                            Maybe this is E3D's master plan? We all need to buy five hot ends so we can swap nozzles easily! 😉
                            • snoozerundefined
                              snoozer
                              @grizewald , yes, quick change hotend was on my list as well but its for now way to complex to get done nice with 3d printed parts. If I ever get a little milling machine maybe but not for now. I agree re the Mosquito, the nozzle is only one aspect, the mechanical build just seems much better quality and I am totally off the titan extruder, BMG M and Mosquito is my next bigger plan (Probably for the linear rail RatRig coming in December)
                              Anyway, I have finally my nice and heavy (maybe to heavy) aluminium bed mounted. I am still running on 2 steppers and it does work quiet OK but I had to increase the motor current to 2A and cant let it drop below 50% in idle to maintain position reliable. The glass plates are a dream to work with, SO easy to have a few of them, let cool down, print off, clean and ready to go while the next print is already on the way. I do have to tweak a few things by the looks of it. In compare to the Prusa PEI plate the lines of filament don't seen to blend into each other that well. I am at the very beginning now on glass, so I am sure I get there. Mesh bed levelling is MUCH better now, the piezo seems to respond very well to the hard glass on the solid mounted aluminium plate, much better than the spring loaded thin old bed with the Prusa surface. With the weight of this bed now I really need to have the lead screws linked. The bed drops when I switch of the printer and its does not drop quiet equal on both sides. For now I have a mechanical support where I drive the bed to before I power down so it rests on that instead of uncontrolled dropping.
                              I have done a few more iterations of a new hotend mount for piezo use. Also includes the Andromeda piezo in one of the designs but all of them have in common that they dont react to gradual pressure application. Sudden pressure yes but not if I drive Z to slow. I am not sure yet how to overcome that.
                              So the next on the list is:
                              • 3rd lead screw RatRig upgrade
                              • Belt drive for Z axix
                              • Improvements to bed insulation and glass hold down clamps
                              • learn printing on glass 😉
                              Have Fun !
                              Jan P.
                              Regards Jan
                              My Printers:
                              My Experiments:
                              • snoozerundefined
                                snoozer
                                I have that RatRig upgrade ordered along with longer lead screws and bearings, 3GT pulleys, idlers etc..... Have to find thrust bearings now and closed loop belts of suitable length.
                                Also just noticed as a very nice side effect of having a 230V AC bed heater now I can use a fanless 24V PSU. But I have to find a way to attach as thermistor to the glass surface. It does take a lot of time for the heat to come trhough the 10mm aluminium plate and the 5mm glass. Maybe just a "puck" style thing with the termistor embedded that I wire up to another termistor input to wait till its warm enough before starting the print. Was considering a small embedded termistor in the aluminium plate but that would still be way off.
                                Jan
                                Regards Jan
                                My Printers:
                                My Experiments:
                                  grizewald
                                  My bed is only 4mm thick, but on top of that I now have a Wham Bam flexible build system, so the magnet layer and the spring steel sheet do tend to add a little delay before the top of the print bed stack gets to the same temperature as the thermistor embedded in the heating mat. It's not really a problem though as I pre-heat before doing my initial Z probing, so by the time I actually print, the surface isn't far behind. I'm certainly not getting any adhesion problems and like your solution, if I'm impatient to start the next print, I can simply swap spring steel sheets and get printing again with the minimum of delay.
                                  I don't know how you can best deal with your bed assembly. The one disadvantage of glass is that it's a terrible conductor of heat, but I fear that if you put your thermistor on the glass that it might make it hard for the firmware to maintain good temperature control when the delay between applying heat and the thermistor registering it is so long.
                                  A piezo sensor is never going to react properly to a slow increase in pressure as it won't generate a spike of electricity from the sudden compression that it gets when the bed is driven at a decent speed. If you increase the sensitivity until even a slow press will trigger it, you'll just end up getting false positives from even things like talking or the noise from the steppers as they drive the bed up. I probe at 6mm/s, which isn't exactly fast, but it's reliable every time. If you can't drive the bed fast enough because it's so heavy, then it sounds like you need NEMA 23 steppers for the bed and a Duet 3 to be able to drive them with enough current.
                                  When I used to print on glass, it was very good for most types of filament. The only thing I didn't enjoy was having to spray the glass regularly with some kind of adhesive. It's important to do that away from the printer or otherwise the adhesive gets onto the lead screws and into the electronics. Not good for either!
                                  I've been using fanless supplies on my V-Core from the start. One 480W 24V unit just to drive the bed heater and a smaller 120W 24V unit to drive the rest of the printer. As I've recently added another stepper, the Duex 5 board and a 50W hot end heater, I decided to upgrade my smaller supply to a 240W 24V unit. That arrived today and the great thing about having the supplies mounted on a DIN rail was that it took me all of two minutes to swap the 120W supply for the new one. That really confirmed to me that it was a good idea to mount them that way.
                                  I'm still working with the Mosquito. My first mount (which has the Orion sensor on top) wasn't holding the Mosquito as well as it should, so I had to use my other printer to make a new one which makes use of the same mounting pattern as the one used on the BMG-M. The other problem is that it would print fine for the first 20 or so layers, but then it would jam due to heat creep in the heat break. The last one was with PLA and was such a bad jam that I had to dismantle the entire hot end so that I could put the block and heat break in the oven to cook out the PLA which had bonded to the walls of the heat break.
                                  After that, I needed to polish the inside of the heat break to bring it to a mirror finish with very low friction. The problem seems to be due to the puny 25mm fan which they supply for cooling the heat break. I have no idea how they came up with the suggestion of running the fan at 70% as even when I'd put it back to 100%, it still resulted in my final PLA jam after just 40 layers.
                                  Consequently, I've printed an adapter so that I can use an E3D 30mm fan instead. Once the boron nitride paste has fully set this evening, I'll be putting it all back together and testing again.
                                    Phaedrux Moderator @snoozer
                                    That's part and parcel of the piezo system. The trigger needs to be sharp and distinct. Going to slow and it can fail to register.
                                    The best way to combat the bed dropping at power down is to use lead screws with a finer pitch thread.
                                    • snoozerundefined
                                      snoozer
                                      Thanks @Phaedrux and @grizewald for your comments. Re z drive, I will use a single NEMA 23. I have received the V-Core 3 screw upgrade. They originally use it with 3 NEMA 17 and also suggest to drive them independent for bed levelling. I have decided against that. I have received my trust bearings now as well and have started to make up bearing blocks that mount instead of the steppers on the metal mounts. See pic.
                                      So the lead screw goes through the bottom of that prototype black block, next radial bearing and on top of the outer ring rests the thrust bearing which again takes the load from the clamp on belt pulley. So I will have two on the forward side and one centered in the back. All three lead screws then joined by a loop belt plus one idler for tensioning.. I am not yet sure if a triangular belt drive has enough engagement on the teeth of they pulleys, if not I have to add a few idlers that wrap the belt around the pulleys more for better engagement of teeth. I intend to drive the rear single lead screw from a top mounted NEMA 23 or if that is not practical use a very short belt loop to drive the lead screw from a separate pulley and the motor in the base of the printer, not yet sure which I do. When I bought the pulleys I assumed its easy to get 3mm pitch belt but turns out that is not really the case, I have to make a mock up 1st now to see what length I need. Also forgot to order the NEMA 23 and motor mount (silly me).
                                      Re piezo, guess that was kind of clear just I did not cop on to that, it needs a sharp impulse. Now with the glass bed it has never missed. Works very reliable now and wile bed levelling never probes on point more than 2 times, before it could take 4-6 times cause of the flexing nature of the flimsy light aluminium bed with the spring steel sheet. So for now I am all happy with the precision of the piezo. I will try again the other hotend mount with the build in Andromeda piezo.
                                      Oh that sounds bad with the Mosquito, are you working in hot environment ? What you write re cooling issues would suggest issues will come up in an enclosed printer. I would not mind a 40 or 50mm fan as long as they can run silent. Or even a blower could them be a compacter, less noisy option. For an enclosed printer it may even make sense to have some sort of light weight duct with external fan to get cool air from outside the enclosure. Just thinking out loud, not there yet. The Linear Rail version will get the BMG M and Mosquito.
                                      Have Fun.
                                      Jan
                                      PS: Re the termistor on top, that would not to control the heater but to delay the print start till the heat has gone through the materials. I find some way to implement that in the "Start G-code" section of the Slicer. IDK yet how I best implement that practically with a pocket cut in glass or whet ever, I probably have to experiment a bit.
                                      My 2 NEMA 17 can drive Z WELL fast enough to trigger the z-probe. I just don't want to have huge inertia behind it with high speed if I can avoid it and go slower.
                                      Regards Jan
                                      My Printers:
                                      My Experiments:
                                      • snoozerundefined
                                        snoozer
                                        @grizewald, about the glue spray. I always apply that in the shower. I usually wash the glass in the kitchen sink with hot water and dry it. Then apply the glue in the shower to prevent glue mist on all the surroundings. The fact float glass is super cheap and can be got in any size combined with the ease of printing so far I don't think I go back to anything else to be honest. Have not yet tried ABS and PA. I did PC, PLA, PETG. Carbon filled XT-CF20 all work great.
                                        Sorry I keep going on about this glass printing, I don't even bother sometime to wash the surface. I can see exactly where I printed before and just position the next part different in the Slicer, it is really so easy. For fun I just print one of my bearing blocks in ABS to give that a shot. I don't want to open my PA just now cause I have no dry box and its wet season here now......
                                        Jan P.
                                        Regards Jan
                                        My Printers:
                                        My Experiments:
                                          grizewald
                                          I'm looking forward to see how you finally implement your Z belt drive, it sounds like it will be ultra stable!
                                          I found out the major cause of my problems with the Mosquito. Even though I'd bought the filament I was using to test from a respected manufacturer who boasts "the smallest variance in the industry" for their filament diameter, I discovered that the new spools that I'd bought were anything but accurately manufactured!
                                          I discovered the problem when I was going to change filament. I asked the printer to unload the filament and when it started to retract the filament from the hot end, the extruder motor started skipping. My initial thought was that I'd got another jam with the filament bonded to the heat break, but when I removed the feed tube and pulled the filament up by hand, there was no resistance at all. It was when I then attempted to pull the filament back through the feed tube to the spool I discovered that it was almost completely jammed inside the tube. The feed tubes that I use from my dry box to the printer are standard 2mm internal diameter PTFE tubes. For it to jam in those means a significant size error.
                                          When I'd finally extracted the filament and got my calipers to it, it turned out that parts of the filament were 1.75mm in one direction and more than 1.9mm in the other! Needless to say, I'm having a conversation with the filament manufacturer.
                                          Having removed the out of tolerance filament from the equation, I'm now finding the Mosquito to be a rather exceptional hot end. I would never have imagined only needing 0.4mm of retraction to print PLA and even PETG with no oozing! The filament path through the entire hot end is very tightly constrained, much more so than in an E3D V6, even with Capricorn tubing. This leads to exceptional feed and retract accuracy, but also means that even slightly out of spec filament has the possibility to jam the hot end solid, as it did to cause the jam I mentioned earlier which forced me to dismantle the hot end to clear it.
                                          I think what's needed is a laser filament diameter monitor to stop out of spec filament getting as far as the hot end!
                                            T3P3Tony administrators @grizewald
                                            @grizewald said in Core-XY based on Rat Rig V-Core and Duet 2 Ethernet:
                                            or a 1.76mm hole in something that wont wear too quickly before the hotend.
                                            grizewaldundefined 1 Reply Last reply Reply Quote 1
