    Having problems with Anycubic Kossel Linear Plus calibration
    calibration
    7.6k
    • SnakeSPundefined
      SnakeSP @Veti
      @veti Yes, i know PT100 requres daughterboard, but it should be most accurate. I'm really tired of temperature sensors calibrations 🙂
      PT1000 is cheaper, but i will need to change the heating cube at least because i haven't found PT1000 in 3 mm capsule, only in 4 mm.
      Did calibration with S7:
      6:14:15 PMM666
      Endstop adjustments X-0.72 Y1.04 Z-0.32, tilt X-0.03% Y-0.20%
      6:14:07 PMM665
      Diagonals 274.863:274.863:274.863, delta radius 136.095, homed height 287.654, bed radius 115.0, X 0.469°, Y -0.907°, Z 0.000°
      6:13:58 PMG32
      Calibrated 7 factors using 16 points, deviation before 0.132 after 0.024
      Don't think that 274.863 for rod will do any good, too big difference with reality.
      Stayed at 266.5 for now. X is 100.32 mm (for 100 mm in model), Y is 100.97 mm. Will try M579 to compensate.
      • SnakeSPundefined
        SnakeSP @Danal
        @danal In fact Marlin never gave really accurate dimensions. Y and Z were fine (less than 0.1 mm deviations), but X was always 1% more than it should be. This was with 267mm rod length. I assume that was due to inaccurate printer build. That's why a have rebuilt whole frame from scratch. And at the same time changed MB to Duet to move to 32 bit and 24 V for faster printing.
        Now the X and Y dimesions errors are close, so looks like this can be compensated with M579.
        As for Haydn's rods: too expensive right now for me. But i'm working on selfmade magball arms to test (with cylinder magnets in rod and steel balls on effector and carriages).
        • Danalundefined
          Danal
          Unless you've posted newer files that I missed...
          Your config-override contains:
          M665 L271.500 R135.224 H287.541 B115.0 X0.505 Y-0.998 Z0.000
          @snakesp said in Having problems with Anycubic Kossel Linear Plus calibration:
          Got it. Sounds good.
          Cool! Magnetic joints really do help this printer. Of course, measure them as best you can after you build them (maybe even take them to a local school, or maker space, or...).
          SnakeSPundefined 1 Reply Last reply Reply Quote 0
          • SnakeSPundefined
            SnakeSP @Danal
            @danal
            config-override.g now has the following:
            M665 L266.500:266.500:266.500 R133.832 H287.529 B115.0 X0.460 Y-0.913 Z0.000
            M666 X-0.711 Y1.035 Z-0.324 A-0.03 B-0.20
            The main thing for rods is to build them at the same jig, so they are totally egual in length. But yes, length measures are important too.
            • Vetiundefined
              Veti @SnakeSP
              https://www.precisionpiezo.co.uk/product-page/pt1000-sensor
              • SnakeSPundefined
                SnakeSP @Veti
                @veti Thanks
                • Vetiundefined
                  Veti @SnakeSP
                  @snakesp
                  also https://de.aliexpress.com/item/32859917151.html?spm=a2g0x.12010612.8148356.9.667521f6v8RTfh
                  • SnakeSPundefined
                    SnakeSP
                    Got PT100 sensor. So now i'm almost sure the nozzle temperature is shown correctly.
                    However i'm still not even near to solving the first layer problem...
                    Started from scratch and removed everything to defaults. Meazured Z probe trigger height. Strangely enough now it is 15.845 mm (but measurements are consistent at x0y0). But it is different at other points. So changed bed.g to reflect those differences.
                    Autocalibration showed:
                    Calibrated 6 factors using 16 points, deviation before 0.007 after 0.006
                    and was consistent after several attempts.
                    So i conclude that printer is now calibrated.
                    Out of PLA so moved to PETG at 60x240 for first layer and 60x220 at subsequent layers.
                    But when i try to print i get first layer smashed into the bed just as before. After 2-3 layers it delaminates from table.
                    Tried using babystep +0.05 - no changes except that first layer is not smashed into table that hard as before.
                    With babystep up to +0.15 got something looking like normal extrusion but it delaminated from bed also.
                    Really out of ideas once again...
                    • Danalundefined
                      Danal
                      Given the babystep, it sounds like you are close.
                      Try:
                      G28
                      G0 Z5
                      G1 Z0 F800
                      And see if the nozzle is JUST touching the bed. Paper should drag but not get stuck. If this is off, change the probe height and recalibrate. Keep doing this until paper just drags after the above three commands.
                      If this works, as a double check, starting from the Z0 above, enter more commands, to check at a different spot on the bed:
                      G0 Z5
                      G0 Y50
                      G1 Z0
                      Still "just touching?"
                      Let us know.
                      • infiniteloopundefined
                        infiniteloop @SnakeSP
                        @SnakeSP
                        It’s a good approach to play with babystepping until you get a proper first layer. @Danal is right, you are close. And don’t be shy to go even higher: sometimes it is better to lay the filament smoothly onto the surface instead of pressing it into the bed.
                        Then, as @Veti posted (on 1st of September), „if i need to adjust it with microstepping to get a good first layer i update the offset with the microstepping used“. Good advice.
                        Delamination on subsequent layers is a different story: One reason may be the specific filament you use. More often, the upper layers cool down too quickly, so try to set your temperature to 240 deg. for all layers. Next, turn down the part cooling fan and see what happens then. Finally, you can try to close the sides of your printer, PETG doesn’t like fresh air.
                        • SnakeSPundefined
                          SnakeSP @Danal
                          @Danal
                          Got these results (with bed at 60C):
                          x0y0 - a bit too high
                          x-50y0 - ok
                          x-50y-50 - too low
                          x-50y50 - a bit too high
                          x0y50 - ok
                          x50y50 - ok
                          x50y0 - ok
                          x50y-50 - a bit too low
                          So looks like the bed is slightly tilted? Tried recalibrating with S8 and got this:
                          M665 L266.500:266.500:266.500 R133.769 H287.544 B115.0 X0.385 Y-1.246 Z0.000
                          M666 X-1.295 Y1.179 Z0.116 A0.34 B0.21
                          But the check results are exactly the same.
                          @infiniteloop Looks like just babystepping won't be enough here as there is a problem with probing results described above.
                          • Danalundefined
                            Danal
                            OK, you can try to physically level the bed a little.
                            Whether you do or not, do this:
                            1. Get the Z-Probe offset as correct as possible at X0Y0
                            2. Run a calibration. Maybe several.
                            3. Run a mesh bed probe. Be sure and put the G-Code to activate bed mesh in your slicer start script (I don't remember the exact code and don't have a printer near at this moment).
                            Also, if you test by hand again, like above, be sure mesh is active when you test.
                            You may have to repeat these steps a couple of times. But it all starts with correct probe offset (at X0Y0).
                            • Vetiundefined
                              Veti
                              can you post the picture of a bed mesh level? G29
                              • Danalundefined
                                Danal @Veti
                                @Veti said in Having problems with Anycubic Kossel Linear Plus calibration:
                                YES!! @SnakeSP Please post.
                                • SnakeSPundefined
                                  SnakeSP @Danal
                                  @Danal @Veti
                                  Changed Z probe offset so calibration now gives good output at x0y0 - can just drag paper under the nozzel.
                                  Made bed mesh.
                                  Rebooted printer and loaded bed mesh.
                                  But tests with going to Z0 give the same result as before even with bed mesh compensation.
                                  • Vetiundefined
                                    Veti
                                    that bed would account for the slight irregularities that you are seeing. so you will need to print with mesh bed levelling enabled.
                                    check with M122 that the bed was actually loaded and is active.
                                    • SnakeSPundefined
                                      SnakeSP @Veti
                                      @Veti
                                      M122:
                                      Hiccups: 0, FreeDm: 169, MinFreeDm: 163, MaxWait: 26536ms
                                      so mesh is enabled. Then why the nozzle height is good at center but too low at x-50 y-50 for example? I thought with mesh enabled nozzle height should be more accurate at all points.
                                      One more thing, on loading bed mesh (G29 S1) i get this:
                                      Warning: the height map was loaded when the current Z=0 datum was not determined probing. This may result in a height offset.
                                      What am i missing?
                                      • Vetiundefined
                                        Veti
                                        just checking, but you did generate a new heightmap when i asked you to run the G29?
                                        • SnakeSPundefined
                                          SnakeSP @Veti
                                          @Veti
                                          Yes, this is a new map. I run S8 autocalibration when adjusted Z probe height. Rebooted printer. Checked that with z0 paper can be just dragged under the nozzle in bed center after that.
                                          After that i run G28 and G29 S0 P"heightmap.csv"
                                          When finished i check that the map is generated (can be viewed in DWC).
                                          Rebooted printer again. Run G28 and G29 S1. Check that z0 is good at bed center. Move to x-50 y-50 and check z0 again - it occurs too low (paper is stuck under the nozzle).
                                          M122 shows that mesh is active at that moment.
                                          • Vetiundefined
                                            Veti
                                            @SnakeSP said in Having problems with Anycubic Kossel Linear Plus calibration:
                                            x-50y0 - ok
                                            x-50y-50 - too low
                                            hmm. i am thinking there might be a slight effector tilt that shows up due to the distance from the probing point to the nozzle.
                                            if you are willing to invest an euro this is what i have swapped to as a probe on my kossel linear plus.
                                            https://de.aliexpress.com/item/32838312776.html
                                            its cheap and has nearly no offset.
