    Cannot print anymore
    35
    4.3k
    • Dougal1957undefined
      Dougal1957
      @Zatsit:
      Funny: Exactly the same problem, today at about the same time!
      I was using version 1.17 downloaded on January 2 on a fresh DuetWifi.
      Many successfull prints since, before suddenly the extruder went crazy at the beginning of an print (endless retracted-unretracted-retracted), then the DuetWebControl said "Communication error" and then died completely. Can not make it alive since: the page does not respond.
      No power problems, no abnormal temperature. The red light next to the SD card is always on. I do not remember if it's normal or not …
      I tried to switch to 1.17b, changing the bin files in the / sys directory of the SD card. No luck for now.
      P.S.
      I also can not access DuetWifi via USB.
      The Windows drivers for the USB port that I downloaded (duet.inf and duetinf.cat) no longer work normally. Their re-installation results in the installation on the COM7 port of a component named "Bossa Program Port", and not "Duet 3DPrinter ...".
      Examination of the "Bossa Program Port" shows that this is some Arduino stuff. What is that doing there? In any case, nothing good ...
      As a result, I can not send any code to DuetWifi.
      Any idea?
      If you are now seeing a bossa programing port it means you have erased the firmware you need to visit the emergency recovery section of the Wiki to get the info to recover your board.
      • Zatsitundefined
        Zatsit
        It is possible that I pressed the "Erase" button by believing to press "Reset", during the abnormal behavior of the extruder.
        According to the documentation, this could corrupt or erase the firmware. Does this make sense?
        In this case, I have to apply "Backup procedure #3" specified in the documentation, right?
        P.S. Thanks Dougal1957 ! I will do that.
        I find it strange that it is as easy to erase the firmware …
        Creator of Zatsit, the delta printer with none assembly
        • Zesty_Lykleundefined
          Zesty_Lykle
          To me it feels like a software problem. It is not just the extruder stepper going crazy, the web server crashes as well.
          It would be nice to be able to have some sort of error logging, so we can trace what is happening.
          I would be more than willing to run a debugging version, if it would help to figure this out.
          Lykle
          Design, make and enjoy life
          Co Creator of the Zesty Nimble
          • Zatsitundefined
            Zatsit
            In my case, the web server probably crashed as a consequence of the fact that I probably pressed the "Erase" button. We do not have proof that he would have crashed if not …
            • Zatsitundefined
              Zatsit
              After applying Backup # 3, everything is now normal. I can print from Wifi and from USB.
              It remains to understand the abnormal behavior of the extruder motor, but the key is that everything works again.
              Thank you to all of you !
                @Zatsit:
                The reason for the extruder problem is probably as I explained a few posts back here https://www.duet3d.com/forum/thread.php?pid=7011#p7011.
                  Zesty_Lykle
                  Things are getting worse. Adding M83 to the startup code messed up my prints.
                  Removing it made things even worse. Now I cannot print at all any more, even when the file is accepted.
                  It prints a little while and then the extruder shoots back to its previous positions. Net result, no filament coming out.
                  I am switching back to 1.15 for now, but keeping the micro sd card intact, so I can still test if and when needed.
                  Lykle
                    T3P3Tony administrators
                    Lykle
                    Can you give a bit more information, what do you mean by "shoots back to previous positions" ( how much is retracted?). What slicer are you using? Does the error start occuring at the same point in the gcode file?
                    Regarding M82/M83 these obviously need to match what your slicer is set to. Can you share the first 20 or 30 lines of the gcode file you are using.
                      @Zesty_Lykle:
                      1. Are you slicing with relative or absolute extrusion?
                      2. Is your slicer putting any M82 or M83 commands near the start of the gcode file it generates?
                        Zesty_Lykle
                        Oh I have a different issue now, I cannot upload a file. I changed back to 1.15 using the 1.15 sd card I had, and the M997 commands
                        Printing a files stored on my SD card works, but uploading doesn't gives an error after the upload has completed.
                        I will switch back to the 1.17b again and see if that problem has been removed, then I can start looking at the retractions.
                        I am using S3D and the Relative extrusion distances was not set. I have now set it. And have included M83 to my startup code.
                        Correct?
                        Edit: OK, back in 1.17b and can upload files again.
                        Lykle
                          Zesty_Lykle
                          Phew, that is a relief!
                          Printing again. I checked everything and switched on Relative extrusion distances.
                          Uploaded the file and started printing.
                          As I am trying out a new print surface I had to cancel and restart the print all the time. That worked like a charm, no more issues with the extruder stepper.
                          Now, why this suddenly started to happen I have no idea. Only thing I can think of is that I have been switching factory files a lot lately. (correct, I have no idea!)
                          Thanks David and Tony for your help.
                          Lykle
                          • ShadowXundefined
                            ShadowX
                            That is why I stop upgrading the firmware now unless I have an issue that the revised firmware fixes. If it already works, I stop upgrading just to get to the latest and greatest bugs.
                              Shadow, while being at the cutting edge is not always a good idea I agree, in this particular case it was not an issue in 1.17b but a absolute vs relative extrusion mismatch
                              • InSanityundefined
                                InSanity
                                @ShadowX:
                                Haaa, I've already had to unsolder and soler in a new processor, I'll be the guinea pig. I'm also a software engineer by trade so I expect bugs. If everything works perfect the product life cycle was Way too long and should have been shelved long ago.
                                Jeff
                                Duet WiFi Powered FFCP with E3D legends hotend system. BLTouch grid leveling.
                                  Zesty_Lykle
                                  Sorry, it is happening again.
                                  This time after I completed a print. Redid something in the model, reprinted it and boom, server crashed and extruder stepper going back and forth.
                                  I have M83 in my start file, in fact it is in there twice I saw. So retried with only 1, no difference.
                                  I had to switch off the printer and leave it for 10 mins before it would print normally again. Switching it off, waiting 10 sec's and switching it on again, did not solve it.
                                  Lykle
                                    deckingman
                                    @Lykle,
                                    I notice that way back near the top of the first page of this thread, you gave your start gcode which has this line
                                    M80 ; lights on
                                    What is that all about? A quick look at the wiki tells me that M80 is used to turn an ATX power supply on from standby. Have you got some sort of lights that run from a separate power supply? Could this line be screwing things up for you? Can you comment it out and see if that fixes the issue?
                                      Zesty_Lykle
                                      Good point.
                                      Lykle
                                        Lykle please send a link to your gcode, and config.g cheers
                                        Tony
                                          Zesty_Lykle
                                          Hi Tony,
                                          Here you go.
                                          https://www.dropbox.com/s/53k0jzpjyzs4qxa/3D%20Printing.rar?dl=0
                                          Lykle
                                          • ShadowXundefined
                                            ShadowX
                                            @deckingman:
                                            @Lykle,
                                            M80 ; lights on
                                            I think the "M80; lights on" goes back to Lykle's BI V2.5 printer default settings before he upgraded to DuetWifi. The BI printers running the Rumba board used the ATX on/off commands (M80/M81) to turn on and off the LED lights. Repetier had a nice button on the screen, so they hijacked that command as the LED switch.
