    Bad print issues
    16
    640
    • Elliotundefined
      Elliot @DocTrucker
      @DocTrucker
      "Have you just copied the instant speed (jerk) setting exactly or adjusted to account for the change on units?"
      I'm sorry I don't understand. I adjusted the jerk in cura base don what others have said online is a good number to use. (bit of a noob here).
      ; generated by RepRapFirmware Configuration Tool on Thu Sep 06 2018 21:21:12 GMT-0700 (Pacific Daylight Time)
      M550 Pe3 ; Set machine name
      M552 S1 ; Enable network
      ;*** Access point is configured manually via M587
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; Drive 0 goes backwards
      M569 P1 S0 ; Drive 1 goes backwards
      M569 P3 S0 ; Drive 3 goes backwards
      M92 X80.00 Y80.00 Z400 E95 ; Set steps per mm
      M566 X1000 Y1000 Z100 E30000 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 Z500 E1500 ; Set maximum speeds (mm/min)
      M201 X300 Y300 Z100 E5000 ; Set accelerations (mm/s^2) was 500 you changed it to 300 for stall guard
      M906 X500 Y500 Z500 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S300 ; Set idle timeout
      M208 X-5.5 Y-10 Z0 S1 ; Set axis minima
      M208 X258.5 Y246 Z260 S0 ; Set axis maxima
      M574 X1 Y1 S1 ; Set active high endstops
      M574 Z1 S2 ; Set endstops controlled by probe
      M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
      M307 H4 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
      M558 P9 H2.5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
      G31 P25 X-31 Y0 Z1.86 ; Set Z probe trigger value, offset and trigger height
      M557 X50:185 Y50:185 S65 ; Define mesh grid
      ;M305 P1 X150 T"K" ; Set THERMOCOUPLE parameters for heater 1 X150 is the right channel (terminal block) on the daughterboard. X151 is the right channel.
      M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S345 ; Set temperature limit for heater 1 to 345C
      M106 P0 S0 I0 B0.5 F250 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 B0.5 F500 L255 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Minimum Speed is 1/3 aka 87 Thermostatic control is turned on triggered at nozzle temp 45;
      M106 P2 S0 I0 B0.5 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      ; Custom settings
      ;M591 D0 P5 C3 R10:300 E3.0 S1 ; Duet3D laser sensor for extruder drive 0 is connected to endstop input 3 (E0), tolerance 10 to 120%, 3mm comparison length
      • Vetiundefined
        Veti
        @Elliot said in Bad print issues:
        B4138 is the default and not correct for your printer
        please have a look at the ender 3 guide
        https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37
        • lodgerundefined
          lodger
          These look very default too. i run mine at 750 X and Y and 900 E . I can not remember what i run Z at thou.
          Elliotundefined 1 Reply Last reply Reply Quote 0
          • Elliotundefined
            Elliot @lodger
            @lodger I went through the setup again this is my new config file. I am still getting pauses in the print that causes blobs.
            M550 P"My Printer" ; set printer name
            M569 P0 S0 ; physical drive 0 goes backwards
            M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
            M566 X600.00 Y600.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X9000.00 Y9000.00 Z600.00 E6000.00 ; set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z120.00 E5000.00 ; set accelerations (mm/s^2)
            M906 X800 Y800 Z800 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            G31 P25 X-31 Y0 Z2.412 ; Set Z probe trigger value, offset and trigger height
            M305 P0 T98801 B4185 C0 R4700 ; Set thermistor + ADC parameters for heater 0
            M305 P1 T98801 B4185 C0 R4700 ; Set thermistor + ADC parameters for heater 1
            ; Custom settings
            M918 P1 E4 ; Enable 12864 LCD with 1 menu item per encoder click
              Phaedrux Moderator @Elliot
              In your first config you had extruder jerk at 30000, and the second one it was 300. I think 3000 is probably a better value.
              I suspect that the issue may be in the Cura profile.
              Maybe give this profile a try. Ender3.curaprofile.txt
              You'll have to remove the .txt extension
              • EasyTargetundefined
                EasyTarget
                For the 'Pause and blob' part of this; can I ask which Cura version you use? Is it 4.1? if so, upgrade..
                This sounds horribly similar to the very frustrating lightspeed bug where:
                • The printer is not pausing, it's just taking 20s to travel 0.1mm in Z
                • Reasons for this are somewhat comical (at least to me, I've worked with developers a lot and the facepalm factor caused by this commit is quite high)
                Disaster? The original Printeye is dying with RRF 3.5 (M208 depreciated).
                PrintPy2024 to the rescue!
                MicroPython based; with simple wiring and and no custom PCB.
                • Elliotundefined
                  Elliot @EasyTarget
                  @EasyTarget I am using cura 4.2.1 is there anything I can do to stop the z-axis from taking so long to travel?
                  EasyTargetundefined 1 Reply Last reply Reply Quote 0
                    EasyTarget @Elliot
                    You have already fixed it by running 4.2.1, this bug only affected v4.1.0, and only for certain types of Cartesian printer definitions. It bit me badly and sounded similar, hence the question.
                    • Elliotundefined
                      Elliot @EasyTarget
                      @EasyTarget So if I am running 4.2.1 and still having this issue, it is most likely not cura and a printer setting?
                      • PaulHewundefined
                        PaulHew
                        @Phaedrux wrote the manual for the ender3 config. Also his Cura profile is good starting point.
                        Have you followed it from beginning to end especially the calibration of extruder steps and flow rate and put the correct value in Cura under Material - Flow?
                        Is it a standard Ender3 with no modifications apart from the BLT?
                        Also what filament type are you printing with? PLA or PET-G
                        I know it is a lot of questions, but I made mistakes when I set my Ender3 up, but now it runs smooth as silk thanks to Phaedrux and others on this site.
                        • Elliotundefined
                          Elliot @PaulHew
                          @PaulHew Yes, I also just tried on Simplify3d.
                          It is a standard ender 3 with a BlTouch.
                          I am using PLA.
                          Do you mean these manuals:
                          https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38
                          https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40
                          If not can you please point me in the right direction.
                          Thanks
                          • PaulHewundefined
                            PaulHew
                            Yes, you have the right manuals.
                            Not up on S3D, Could not justify the £140
                            Check your retraction settings in Cura, try 1.5mm retract 40 speed.
                            Also you might want to print a temp tower and a retraction test., you could be running too hot and not enough retraction.
                            I do not know what experience you have and I hope I am not teaching you to suck eggs!
                            Teaching Tech on You Tube had some How-to s on Retraction and the likes, worth checking out. Also Chep's YouTube videos are helpful also.
                            MakersMuse also on retraction, helped me get rid of the strings.
                            Dont expect miricles on your first prints, but the manual Phaedrux wrote was a god send, and I still use bits of it like the calibration on my
                            RailCore II.
                            It took about about week of tweaking after swapping over to the Maestro board to get something semi decent.
                            Also make sure both sides of the Gantry that the hotend sits on are the same height and that the rollers are 'snug' so there is no slop. Again there are you tube videos on this.
                            As my signature states, I am not running much of the original printer.
                            Bondtech do a nice hot end conversion kit for Creality.
                            • Elliotundefined
                              Elliot @PaulHew
                              @PaulHew I am in the 30-day money-back period of S3D. I thought I would try it if it helped my prints.
                              No not at all, I am constantly learning and you provided some good places/points to look at.
                              It's just a bit frustrating. My Ender 3 on stock board was making better prints than what I am getting now. Just wondering how much more tinkering it will take to get to where I was already.
                              The one thing that I tell my self is nice about the Duet WIFI now is the WIFI aspect of it. However, event that seems very temperamental and it can take around 30 mins to get connected to it and then it randomly drops the connection.
                              • poohzazaundefined
                                poohzaza
                                just want to help you can try my config i have a bltouch and e3d hotend and bontech gear exetruder 3:1 you can use my config as and starting point i use an ender 3 pro
                                here is my config
                                ; generated by RepRapFirmware Configuration Tool v2.0.3 on Tue Sep 10 2019 09:03:05 GMT+0700 (Indochina Time)
                                M550 P"enderpooh" ; set printer name
                                M551 P"do you want to know" ; set password
                                M552 S1 ; enable network
                                M586 P0 S1 ; enable HTTP
                                M586 P1 S1 ; enable FTP
                                M586 P2 S0 ; disable Telnet
                                M350 X256 Y256 Z16 E16 I0 ; configure microstepping without interpolation
                                M92 X1280.00 Y1280.00 Z400.00 E410 ; set steps per mm
                                M566 X8.00 Y8.00 Z0.40 E5.00 ; set maximum instantaneous speed changes (mm/min)
                                M203 X6000.00 Y6000.00 Z6000.00 E1200.00 ; set maximum speeds (mm/min)
                                M201 X200.00 Y200.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
                                M906 X700 Y700 Z760 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                                M208 X230 Y230 Z250 S0 ; set axis maxima
                                M307 H4 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
                                M558 P9 H9 F120 R0.2 T18000 ; set Z probe type to bltouch and the dive height + speeds
                                G31 P25 X41 Y-12 Z0.55 S35 ; set Z probe trigger value, offset and trigger height
                                M557 X125:271 Y25:200 S0 P3:3
                                ; probe locoation
                                M557 P1 X41 Y25
                                M557 P2 X120 Y25
                                M557 P3 X200 Y25
                                M557 P4 X200 Y135
                                M557 P5 X120 Y135
                                M557 P6 X41 Y135
                                M557 P7 X41 Y200
                                M557 P8 X120 Y200
                                M557 P9 X200 Y200
                                M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
                                M106 P0 S0 I0 F500 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                M106 P1 X100 T50 H1 S0 I0 F500
                                ; Custom settings are defined
                                M911 S22.8 R23.5
                                ;M915 P0:1 S8 H185 F1 R3
                                M591 D0 P2 C3 S1
                                M572 D0 S0.5
                                M376 H10
                                M592 D0 A0.01 B0.0005
                                and i just use stock cura profile and remove max feed rate and travel accellration
                                and add g29 s0 for auto bed leveling
