    crc32appender now needed for RRF?
    Firmware developers
    1.8k
    • gtj0undefined
      gtj0
      @wilriker I see you have a pull request open for it in Duet3Expansion but we also need it for RRF. Is this your own code or did it come from somewhere else?
      • wilrikerundefined
        wilriker @gtj0
        @gtj0 That's my own code. And there was some confusion on where to put the PR. At first I had it in the RRF repo, then realized it's only used in the expansion board firmware (at that time), so moved it over. Then @dc42 told me it will be used in RRF as well but I forgot to move it back. 🤦
        Manuel
        My Tool Collection
        • JoergS5undefined
          JoergS5 @wilriker
          @wilriker How about putting it into RRFLibraries, where support algorithms are gathered.
            dc42 administrators @JoergS5
            @JoergS5 said in crc32appender now needed for RRF?:
            RRFlibraries is just code for linking with other projects. RepRapFirmware already has a separate Tools folder.
            • smoki3undefined
              smoki3
              Is there a possibility to get it working on a mac?
              • wilrikerundefined
                wilriker @smoki3
                @smoki3 I will add one in a moment to the repo. Meanwhile use this one in my Dropbox.
                Manuel
                My Tool Collection
                • smoki3undefined
                  smoki3
                  how to add it in eclipse?
                  • gtj0undefined
                    gtj0 @smoki3
                    @smoki3 said in crc32appender now needed for RRF?:
                    For now, you can copy it to any directory in your PATH. Eclipse will automatically pick it up.
                    • smoki3undefined
                      smoki3
                      I copied it to the root folder of the RepRapFirmware directory. Does not work
                      • gtj0undefined
                        gtj0
                        @wilriker Your commit to add it needs to add the appropriate Tools/crc32appender directories to the PATH in Eclipse or we'll have to manually copy it to a system directory.
                        wilrikerundefined 1 Reply Last reply Reply Quote 1
                        • gtj0undefined
                          gtj0 @smoki3
                          It has to be a directory in your $PATH.
                          smoki3undefined 1 Reply Last reply Reply Quote 0
                          • smoki3undefined
                            smoki3 @gtj0
                            @gtj0
                            I get this:
                            /bin/sh: crc32appender: command not found
                            dont know where my $PATH is
                            • wilrikerundefined
                              wilriker @smoki3
                              @smoki3 in the command line type
                              echo $PATH
                              it should give you a colon-separated list of directories where the system looks for executables by default.
                              Manuel
                              My Tool Collection
                              • wilrikerundefined
                                wilriker @gtj0
                                @gtj0 said in crc32appender now needed for RRF?:
                                I just realized that this will be very complicated since the binaries all have the same name but need to be different for the different operating systems.
                                Manuel
                                My Tool Collection
                                • smoki3undefined
                                  smoki3 @wilriker
                                  @wilriker
                                  echo $PATH
                                  /usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin:/Users/kevin/.android-sdk-macosx/platform-tools/:/Users/kevin/Library/platform-tools/
                                  I added it to the /usr/local/bin
                                  but it does not work in ecplise.
                                  In the terminal it works
                                  • gtj0undefined
                                    gtj0 @wilriker
                                    @wilriker said in crc32appender now needed for RRF?:
                                    You may be able to rename the directories to match some Eclipse or environment variable. I think there's a variable in Eclipse named "platform" or something close then you could add the path as ${workspace_dir}/Tools/crc32appender/${platcorm}
                                    Not sure if those are the exact variable names.
                                      I just put in the same /bin directory that I put miscellaneous binaries in, which is already on my PATH. This is under Windows 10 x64.
                                      • gtj0undefined
                                        gtj0
                                        @smoki3 I also put it in /usr/local/bin and it worked from Eclipse. Did you restart Eclipse? You shouldn't have to but it may help.
                                        You can also try running "make" manually...
                                        From the output directory (Duet2_RTOS, Duet3_V06, etc), run make clean and make and see if that works.
                                        • gtj0undefined
                                          gtj0
                                          @wilriker These look like they could be good variables to use:
                                          HostOsName
                                          OsType
                                          target.os
                                          • smoki3undefined
                                            smoki3 @gtj0
                                            @gtj0
                                            Its funny, in the terminal it is working with make... In eclipse not
                                            I figured out that eclipse only uses:
                                            But on the mac we dont have permissions to add files to these folders
                                            Any why to add another path to $PATH?
