crc32appender now needed for RRF?
Firmware developers
1.7k
    gtj0
    @wilriker I see you have a pull request open for it in Duet3Expansion but we also need it for RRF. Is this your own code or did it come from somewhere else?
    undefined 1 Reply Last reply 5 Oct 2019, 05:38 Reply Quote 0
      wilriker @gtj0
      @gtj0 That's my own code. And there was some confusion on where to put the PR. At first I had it in the RRF repo, then realized it's only used in the expansion board firmware (at that time), so moved it over. Then @dc42 told me it will be used in RRF as well but I forgot to move it back. 🤦
      Manuel
      My Tool Collection
      undefined 1 Reply Last reply 5 Oct 2019, 07:23 Reply Quote 0
        JoergS5 @wilriker
        @wilriker How about putting it into RRFLibraries, where support algorithms are gathered.
        undefined 1 Reply Last reply 5 Oct 2019, 10:10 Reply Quote 0
          dc42 administrators @JoergS5
          @JoergS5 said in crc32appender now needed for RRF?:
          RRFlibraries is just code for linking with other projects. RepRapFirmware already has a separate Tools folder.
            smoki3
            Is there a possibility to get it working on a mac?
            undefined 1 Reply Last reply 9 Oct 2019, 14:19 Reply Quote 0
              wilriker @smoki3
              @smoki3 I will add one in a moment to the repo. Meanwhile use this one in my Dropbox.
              Manuel
              My Tool Collection
                smoki3
                how to add it in eclipse?
                undefined 1 Reply Last reply 9 Oct 2019, 14:45 Reply Quote 0
                  gtj0 @smoki3
                  @smoki3 said in crc32appender now needed for RRF?:
                  For now, you can copy it to any directory in your PATH. Eclipse will automatically pick it up.
                    smoki3
                    I copied it to the root folder of the RepRapFirmware directory. Does not work
                    undefined 1 Reply Last reply 9 Oct 2019, 14:55 Reply Quote 0
                      gtj0
                      @wilriker Your commit to add it needs to add the appropriate Tools/crc32appender directories to the PATH in Eclipse or we'll have to manually copy it to a system directory.
                      undefined 1 Reply Last reply 9 Oct 2019, 15:14 Reply Quote 1
                        gtj0 @smoki3
                        It has to be a directory in your $PATH.
                        undefined 1 Reply Last reply 9 Oct 2019, 15:06 Reply Quote 0
                          smoki3 @gtj0
                          @gtj0
                          I get this:
                          /bin/sh: crc32appender: command not found
                          dont know where my $PATH is
                          undefined 1 Reply Last reply 9 Oct 2019, 15:11 Reply Quote 0
                            wilriker @smoki3
                            @smoki3 in the command line type
                            echo $PATH
                            it should give you a colon-separated list of directories where the system looks for executables by default.
                            Manuel
                            My Tool Collection
                            undefined 1 Reply Last reply 9 Oct 2019, 15:20 Reply Quote 0
                              wilriker @gtj0
                              @gtj0 said in crc32appender now needed for RRF?:
                              I just realized that this will be very complicated since the binaries all have the same name but need to be different for the different operating systems.
                              Manuel
                              My Tool Collection
                              undefined 1 Reply Last reply 9 Oct 2019, 15:24 Reply Quote 0
                                smoki3 @wilriker
                                @wilriker
                                echo $PATH
                                /usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin:/Users/kevin/.android-sdk-macosx/platform-tools/:/Users/kevin/Library/platform-tools/
                                I added it to the /usr/local/bin
                                but it does not work in ecplise.
                                In the terminal it works
                                  gtj0 @wilriker
                                  @wilriker said in crc32appender now needed for RRF?:
                                  You may be able to rename the directories to match some Eclipse or environment variable. I think there's a variable in Eclipse named "platform" or something close then you could add the path as ${workspace_dir}/Tools/crc32appender/${platcorm}
                                  Not sure if those are the exact variable names.
                                    I just put in the same /bin directory that I put miscellaneous binaries in, which is already on my PATH. This is under Windows 10 x64.
                                      gtj0
                                      @smoki3 I also put it in /usr/local/bin and it worked from Eclipse. Did you restart Eclipse? You shouldn't have to but it may help.
                                      You can also try running "make" manually...
                                      From the output directory (Duet2_RTOS, Duet3_V06, etc), run make clean and make and see if that works.
                                      undefined 1 Reply Last reply 9 Oct 2019, 16:51 Reply Quote 0
                                        gtj0
                                        @wilriker These look like they could be good variables to use:
                                        HostOsName
                                        OsType
                                        target.os
                                          smoki3 @gtj0
                                          @gtj0
                                          Its funny, in the terminal it is working with make... In eclipse not
                                          I figured out that eclipse only uses:
                                          But on the mac we dont have permissions to add files to these folders
                                          Any why to add another path to $PATH?
                                          undefined 1 Reply Last reply 9 Oct 2019, 21:23 Reply Quote 0
                                          8 out of 29
