crc32appender now needed for RRF?
Firmware developers
1.7k
    JoergS5 @wilriker
    @wilriker How about putting it into RRFLibraries, where support algorithms are gathered.
    undefined 1 Reply Last reply 5 Oct 2019, 10:10 Reply Quote 0
      dc42 administrators @JoergS5
      @JoergS5 said in crc32appender now needed for RRF?:
      RRFlibraries is just code for linking with other projects. RepRapFirmware already has a separate Tools folder.
        smoki3
        Is there a possibility to get it working on a mac?
        undefined 1 Reply Last reply 9 Oct 2019, 14:19 Reply Quote 0
          wilriker @smoki3
          @smoki3 I will add one in a moment to the repo. Meanwhile use this one in my Dropbox.
          Manuel
          My Tool Collection
            smoki3
            how to add it in eclipse?
            undefined 1 Reply Last reply 9 Oct 2019, 14:45 Reply Quote 0
              gtj0 @smoki3
              @smoki3 said in crc32appender now needed for RRF?:
              For now, you can copy it to any directory in your PATH. Eclipse will automatically pick it up.
                smoki3
                I copied it to the root folder of the RepRapFirmware directory. Does not work
                undefined 1 Reply Last reply 9 Oct 2019, 14:55 Reply Quote 0
                  gtj0
                  @wilriker Your commit to add it needs to add the appropriate Tools/crc32appender directories to the PATH in Eclipse or we'll have to manually copy it to a system directory.
                  undefined 1 Reply Last reply 9 Oct 2019, 15:14 Reply Quote 1
                    gtj0 @smoki3
                    It has to be a directory in your $PATH.
                    undefined 1 Reply Last reply 9 Oct 2019, 15:06 Reply Quote 0
                      smoki3 @gtj0
                      @gtj0
                      I get this:
                      /bin/sh: crc32appender: command not found
                      dont know where my $PATH is
                      undefined 1 Reply Last reply 9 Oct 2019, 15:11 Reply Quote 0
                        wilriker @smoki3
                        @smoki3 in the command line type
                        echo $PATH
                        it should give you a colon-separated list of directories where the system looks for executables by default.
                        Manuel
                        My Tool Collection
                        undefined 1 Reply Last reply 9 Oct 2019, 15:20 Reply Quote 0
                          wilriker @gtj0
                          @gtj0 said in crc32appender now needed for RRF?:
                          I just realized that this will be very complicated since the binaries all have the same name but need to be different for the different operating systems.
                          Manuel
                          My Tool Collection
                          undefined 1 Reply Last reply 9 Oct 2019, 15:24 Reply Quote 0
                            smoki3 @wilriker
                            @wilriker
                            echo $PATH
                            /usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin:/Users/kevin/.android-sdk-macosx/platform-tools/:/Users/kevin/Library/platform-tools/
                            I added it to the /usr/local/bin
                            but it does not work in ecplise.
                            In the terminal it works
                              gtj0 @wilriker
                              @wilriker said in crc32appender now needed for RRF?:
                              You may be able to rename the directories to match some Eclipse or environment variable. I think there's a variable in Eclipse named "platform" or something close then you could add the path as ${workspace_dir}/Tools/crc32appender/${platcorm}
                              Not sure if those are the exact variable names.
                                I just put in the same /bin directory that I put miscellaneous binaries in, which is already on my PATH. This is under Windows 10 x64.
                                  gtj0
                                  @smoki3 I also put it in /usr/local/bin and it worked from Eclipse. Did you restart Eclipse? You shouldn't have to but it may help.
                                  You can also try running "make" manually...
                                  From the output directory (Duet2_RTOS, Duet3_V06, etc), run make clean and make and see if that works.
                                  undefined 1 Reply Last reply 9 Oct 2019, 16:51 Reply Quote 0
                                    gtj0
                                    @wilriker These look like they could be good variables to use:
                                    HostOsName
                                    OsType
                                    target.os
                                      smoki3 @gtj0
                                      @gtj0
                                      Its funny, in the terminal it is working with make... In eclipse not
                                      I figured out that eclipse only uses:
                                      But on the mac we dont have permissions to add files to these folders
                                      Any why to add another path to $PATH?
                                      undefined 1 Reply Last reply 9 Oct 2019, 21:23 Reply Quote 0
                                        dc42 administrators @smoki3
                                        The Windows version of Eclipse lets you set up the search path within Eclipse. Does the Mac version offer the same?
                                        • bondusundefined
                                          bondus
                                          What does this tool do? I still get the .bin I want.
                                          I get an error when building:
                                          arm-none-eabi-objcopy -O binary "C:\eclipse\Firmware\RepRapFirmware\DuetM_RTOS/DuetMaestroFirmware.elf" "C:\eclipse\Firmware\RepRapFirmware\DuetM_RTOS/DuetMaestroFirmware.bin" && crc32appender "C:\eclipse\Firmware\RepRapFirmware\DuetM_RTOS/DuetMaestroFirmware.bin"
                                          c:/program files/gnu arm eclipse/build tools/2.6-201507152002/bin/sh: crc32appender: not found
                                          Building again the error goes away, there is an depency error in the makefiles.
                                          undefined 1 Reply Last reply 21 Feb 2020, 05:14 Reply Quote 0
