    RepRapFirmware 3.0beta 11 released
    Beta Firmware
    13
    72
    3.6k
      A Former User @dc42
      @dc42 said in RepRapFirmware 3.0beta 11 released:
      It works for me. Tested using a BLTouch connected to zprobe.in and exp.heater3, G31 P value set to 100.
      hm, that's not good
      It's possible that you have a G31 command in config-override.g.
      I did not create it, I don't see it trough web interface..
      btw you don't need the M401 and M402 commands in your homez file, because probe deployment/retraction is done automatically (this has been the case for many firmware versions).
      so G30 auto deploy/retract? nice.. but I'm now more concerned that after G30 I touch the probe, the probe detects me, bed still moves, the probe deploy again, touch again, detect again, deploy again .. bed still moving etc etc.. so no bed stop and no retraction happening at all (G30 not finishing) .. exactly the same config on b10 works, b11 don't. tried G31 P10, P100, P200 .. It's not a working printer (yet) so not a big deal but if there's anything I can help debug lemme know 🙂 (I can hook up oscilloscope or .. ) .. this is supposedly original bltouch v3 .. but "original" when bltouch is can be tricky 😞 ... I have 2 "original" (from "original aliexpress store" paid original price), I have 2-3 clones too that I can try also .. might be the timing issue and not only the trigger level?
      • Danalundefined
        Danal
        @smece said in RepRapFirmware 3.0beta 11 released:
        If you don't see it via the web interface, it is likely not there.
        But just to help understand the full picture: That file is created and/or updated when you issue an M500. That is often documented in other firmware as "save settings to EEPROM". Duets do not have EEPROM, so they save settings to /sys/config-override.g
        Anyway, sounds like you don't have one.
          A Former User
          @Danal thanks for explanation! ... did not do M500 yet 😄 since this is a work in progres conversion to duet, and I never used duet before, i'm trying to setup everything directly in main config's for now 😄 .. that's also why I started with RRF3 and not gone with stable version 😄 (still don't have thermistors nor heaters in the hotends so..)
            @smece, just to confirm:
            • You are using RRF3 on a Duet WiFi
            • You have connected the BLTouch white wire to IN on the ZProbe connector, and the black wire to GND on the ZProbe connector
            • You are getting a reading of 0 for the Z probe in DWC
            • If you disconnect the BLTouch from the Z probe connector, you get a reading of 250 for the Z probe
            • If you send G31 without parameters, it reports the P parameter is 100 (or whatever you set it to, less than 250)
            • You had the BLTouch working with firmware 3.0beta10
            Is that all correct?
            A Former User? 2 Replies Last reply Reply Quote 0
            • stereoundefined
              stereo
              On update 10->11 not work homex(y)(all) files. Change S1 to H1..
              G91 ; relative positioning
              G1 H1 X-355 F1800 ; move quickly to X axis endstop and stop there (first pass)
              no reaction to the command at least earlier moved where necessary.
              Immediately provide 0.
              G91
              G1 X-5
              NOT WORK TO! IF X = 0
                A Former User @dc42
                No, Duet2Ethernet, RRF3.0beta10 works, RRF3.0beta11 does not
                not sure if duet wifi is the same board (I guess it is, with the net module difference, but can't be sure)
                Yes
                Yes
                No clue what was DWC showing but when I disconnect zprobe (just the zprobe.in and gnd, was not touching the power and servo) and shoot G31 I get
                Current reading 250
                So I assume DWC is doing same and showing 250
                Yes
                Yes, it's on beta10 now and works flawlesly
                When on beta10 I disconnect probe
                DWC shows 1000
                G31 shows
                G31
                Current reading 1000, threshold 100, trigger height 2.20, offsets X35.0 Y0.0
                rebooting now into beta11
                DWC showing 250
                G31:
                G31
                Current reading 250, threshold 100, trigger height 2.20, offsets X35.0 Y0.0
                connecting connector back
                DWC showing 0
                G31:
                G31
                Current reading 0, threshold 100, trigger height 2.20, offsets X35.0 Y0.0
                executing
                G0X0Y0
                G30 ; so no deploy/retract as you said
                bed start closing in as expected, I trigger the bltouch with finger, bed continues to move bltouch deploy again I trigger again it deploys aga I trigger again ... bed moves ... I powercycle the printer
                  A Former User
                  now I tried (beta11) to jenk the cable during G30 and
                  10/23/2019, 10:05:32 PM 	G30
                  Error: Z probe already triggered at start of probing move
                  this error is probbly 'cause my probing is configured (don't remembe where) to touch out 2 times so when it started the second round it was still triggered..
                  do you want me to measure length of the impulse BLT sends when is triggered? I read somewhere that original v3 bltouch might be too fast for some firmware to detect.. should be simple to capture.
                  • stereoundefined
                    stereo
                    Do all home X, Y work fine? Am I the only one? show homex.g
                    On beta10
                    G1 Z5 F6000 H2 ; lift Z relative to current position
                    G1 H1 X-335 F1800 ; move quickly to X axis endstop and stop there (first pass)
                    G1 X5 F6000 ; go back a few mm
                    G1 H1 X-335 F360 ; move slowly to X axis endstop once more (second pass)
                    G1 Z-5 F6000 H2 ; lower Z again
                    G90 ; absolute positioning
                    work good.
                    On beta11 goto Z5,Z-5,X5.. but does not go to the microswitch.
                      dc42 administrators @stereo
                      @stereo said in RepRapFirmware 3.0beta 11 released:
                      On beta10
                      work good.
                      Please post your config.g file. Which Duet are you using?
                      stereoundefined 1 Reply Last reply Reply Quote 0
                      • stereoundefined
                        stereo @dc42
                        M574 X1 S1 P"io0.in" or
                        M574 X1 S0 P"io0.in"
                        on beta11 always triggered YES.
                        IF RUN "M574 Y2 S0","M574 X1 S0" work fine NO...
                        normal config on beta10:
                        Duet3
                          A Former User @dc42
                          @dc42 FOUND THE CAUSE OF THE BUG 😄
                          This is ZPROBE.IN in beta10 (bltouch disconnected)
                          as you can see ~3V with some ugly 50Hz garbage that should not interfere
                          but this is ZPROBE.IN in beta11 (bltouch disconnected)
                          as you can see it's floating around 1V at 50Hz so I'd say ZPROBE.IN is HIZ at this point and there is no pullup enabled... I don't see on schematic where zprobe_in becomes zprobe_mcu, are you using external pullup or you just need to configure it as in with pullup enabled .. anyhow .. there's no pullup on zprobe.in with beta11
                            A Former User
                            found the zprobe_in to zprobe_mcu .. just 10k trough and 2n2 down .. so def port configuration missing 😄
                            and I also found the commit that introduced the bug:
                            src/Endstops/LocalZProbe.cpp:42
                            https://github.com/dc42/RepRapFirmware/blame/c25d73194252791ceb479ced79ffc77b31c810fe/src/Endstops/LocalZProbe.cpp#L42
                            you switched it from PinAccess::readWithPullup; to PinAccess::read;
                            Nuramoriundefined 1 Reply Last reply Reply Quote 0
                              A Former User
                              This will probbly work ok with bltouch v2 or v1 as they have 0/1 output, v3/v3.1 is open drain output so it can only pull low. Not sure why you switched from readWithPullup to read, but maybe create a new probe type with pullup, or should we add external pullup if this is to remain without one on the port?
                              • Nuramoriundefined
                                Nuramori @A Former User
                                @smece sadly, I saw your posts 3 minutes too late :p.
                                Thought my errant height map was a fluke due to a part swap. I dug a nice groove into my test spring plate (luckily I always use a sacrificial test plate whenever I change anything on the printer, hardware or software).
                                Moving back to 10 brought everything back to “normal”.
                                  Thanks for tracking this down. I removed implicit enabling of pullup resistors in beta 11 because it meant that you couldn't turn them off. If you want to enable the pullup resistor, you need to be explicit by using C"^zprobe.in" in your M558 command.
                                  The BLTouch that I test with is the older version that drives the output high when triggered, that's why I didn't see the problem during testing.
                                  I'll update the documentation to make this clear.
                                  A Former User? 1 Reply Last reply Reply Quote 2
                                    A Former User @dc42
                                    Perfect, this solves the problem. Everything works ok now.
                                    M558 P9 C"^zprobe.in" H5 F120 T3000 A2
                                    M950 S0 C"exp.heater3"
                                    G31 P100 X35 Y0 Z2.2
                                    • fmaundefined
                                      fma
                                      I just installed RRF3.0beta11 on my DuetWifi2, and I have troubles configuring Fans. In my config.g file, I have:
                                      M950 F0 C"heater1" Q100    ; Fan 0 (water pump) is connected to heater 1, PWM at 100Hz
                                      M950 F1 C"heater2" Q100    ; Fan 1 (Berd air pump) is connected to heater 2, PWM at 100Hz
                                      M950 F2 C"duex.fan3" Q100  ; Fan 2 (Leds) is connected to heater 2, PWM at 100Hz
                                      M950 S0 C"fan0"            ; Servo 0 is connected to "fan0" pin
                                      M563 P0 D0 H1 F1 S"Manual"  ; Define tool 0 using Drive 0, Heater 1 and Fan 1
                                      But I don't see any fan controls in DWC2... What I missed?
                                      I also would like to know:
                                      • how to setup thermostatic control for a fan
                                      • how to name a fan
                                      Thanks,
                                      PS: the tool is working fine.
                                      Frédéric
                                      • gtj0undefined
                                        gtj0 @fma
                                        @fma You still need M106 commands...
                                        This is for a Duet3 but
                                        ; Fans & LEDs
                                        M950 F0 C"out7" Q25000
                                        M106 P0 C"PartCooling" S0  H-1
                                        M950 F1 C"out8" Q25000
                                        M106 P1 C"HotEnd" T45 H1
                                        M950 F2 C"out9" Q100
                                        M106 P2 S255 B0 C"Bed LED"
                                        • fmaundefined
                                          fma
                                          Ok, I see. Thanks!
                                          Frédéric
                                          • fmaundefined
                                            fma
                                            I also have the homing issue G0/G1: insufficient axes homed.
                                            But it does not happen all the time. It can home fine, then it does not. I can't find a pattern, it can happens at different stages...
                                            I'm using a Duet2Wifi.
                                            Here are my congif.g and all homing files:
                                            ; Configuration file for Duet WiFi
                                            M111 S0  ; Debugging off
                                            G21      ; Work in millimetres
                                            G90      ; Send absolute coordinates...
                                            M83      ; ...but relative extruder moves
                                            M555 P2  ; Set firmware compatibility to look like Marlin
                                            M667 S1  ; Select CoreXY mode
                                            M208 X-60:302 Y-100:305 Z0:320 U-1000:1000  ; Set axis limits
                                            M584 X0 Y1 Z2 E5 U6                         ; Remap axes
                                            M569 P0 S1                                  ; Drive 0 goes forwards
                                            M569 P1 S1                                  ; Drive 1 goes forwards
                                            M569 P2 S0                                  ; Drive 2 goes reverse
                                            M569 P5 S0                                  ; Drive 5 goes reverse
                                            M569 P6 S1                                  ; Drive 6 goes forward
                                            M350 X16 Y16 Z16 E16 U16 I1                 ; Configure microstepping with interpolation
                                            M92 X66.667 Y66.667 Z1417.323 E530 U140     ; Set steps per mm
                                            M203 X30000 Y30000 Z1200 E3600 U3600        ; Set maximum speeds (mm/min)
                                            M201 X1000 Y1000 Z100 E3000 U3000           ; Set accelerations (mm/s^2)
                                            M566 X900 Y900 Z60 E600 U600                ; Set maximum instantaneous speed changes (mm/min)
                                            M906 X1750 Y1750 Z1750 E750 U1250 I30       ; Set motor currents (mA) and motor idle factor in per cent
                                            M84 S30                                     ; Set motors idle timeout
                                            ; Endstops (must be defined after any M584 command)
                                            M574 X2 S1 P"xstop"  ; X min active high endstop switch
                                            M574 Y2 S1 P"ystop"  ; Y min active high endstop switch
                                            M574 Z1 S1 P"zstop"  ; Z min active high endstop switch
                                            ; Sensors
                                            M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 R4700               ; bed temperature sensor uses 'bedtemp' pin
                                            M308 S1 P"duex.e2temp" Y"thermistor" T100000 B4725 C7.06e-8 R4700  ; E0 temperature sensor uses 'deux.e2temp' pin
                                            M950 H0 C"bedheat" T0          ; heater 0 uses the 'bedheat' pin and sensor 0
                                            M143 H0 S120                   ; Set maximum heater 0 temperature to 120°C (not yet supported)
                                            M307 H0 A105.6 C627.9 D1.5 B0  ; Auto-tune values for heater 0
                                            M950 H1 C"duex.e2heat" T1      ; heater 1 uses the 'duex.e2heat' pin and sensor 1
                                            M143 H1 S280                   ; Set maximum heater 1 temperature to 280C (not yet supported)
                                            M950 F0 C"e0heat" Q100000           ; Fan 0 connected to 'e0heat' pin, PWM at 100KHz
                                            M106 P0 C"Part cooling"             ; Part cooling fan uses fan 0
                                            M950 F1 C"e1heat" Q100000           ; Fan 1 connected to 'e1heat' pin, PWM at 100KHz
                                            M106 P1 C"Water pump" T45 H1 X0.25  ; Thermostatic fan uses fan 1, monitor heater 1, max PWM 25% (6V out of 24V)
                                            M950 F2 C"duex.fan3" Q100           ; Fan 2 connected to 'duex.fan3' pin, PWM at 100Hz
                                            M106 P2 C"Leds"                     ; Leds uses fan 2
                                            ; Servos
                                            M950 S0 C"fan0"  ; Servo 0 connected to 'fan0' pin
                                            G10 P0 X0 Y0 Z0             ; Set tool 0 axis offsets
                                            G10 P0 R190 S190            ; Set initial tool 0 active and standby temperatures
                                            M207 S1.5 F2400             ; Set retraction length (G10/G11)
                                            M572 D0 S0.08               ; Pressure advance
                                            M550 PDuetWifi  ; Set machine name
                                            M551 Pxxxxxx    ; Set password
                                            M552 S1         ; Enable network
                                            ; Access point is configured manually via M587 by the user
                                            M586 P0 S1      ; Enable HTTP
                                            M586 P1 S1      ; Enable FTP
                                            M586 P2 S0      ; Disable Telnet
                                            ; Misc
                                            M912 P0 S-13  ; Calibrate CPU temp.
                                            M106 P2 S0.1  ; Turn leds on 10%
                                            ; homeall.g
                                            ; called to home all axes
                                            M98 P0:/sys/homexy.g
                                            M98 P0:/sys/homez.g
                                            M98 P0:/sys/homeu.g
                                            ; homexy.g
                                            ; called to home the X and Y axis
                                            G1 Z1 F1200 H2  ; lift Z
                                            G1 X325 Y325 F1800 H1  ; course home X or Y
                                            G1 X325 H1             ; course home X
                                            G1 Y325 H1             ; course home Y
                                            G1 X-5 Y-5 F6000       ; move away from the endstops
                                            G1 X325 F300 H1        ; fine home X
                                            G1 Y325 H1             ; fine home Y
                                            G1 Z-1 F1200 H2  ; lower Z
                                            ; homez.g
                                            ; called to home the Z axis
                                            G1 Z-325 F600 H1  ; course home Z
                                            G1 Z5 F1200       ; move away from the endstop
                                            G1 Z-325 F120 H1  ; Fine home Z
                                            ; homeu.g
                                            ; called to home the U axis
                                            G92 U0
                                            Thanks for you help.
                                            Frédéric
                                            deckingmanundefined JoergS5undefined 2 Replies Last reply Reply Quote 0
