    RepRapFirmware 3.0beta 11 released
    Beta Firmware
    13
    72
    3.5k
      A Former User
      now I tried (beta11) to jenk the cable during G30 and
      10/23/2019, 10:05:32 PM 	G30
      Error: Z probe already triggered at start of probing move
      this error is probbly 'cause my probing is configured (don't remembe where) to touch out 2 times so when it started the second round it was still triggered..
      do you want me to measure length of the impulse BLT sends when is triggered? I read somewhere that original v3 bltouch might be too fast for some firmware to detect.. should be simple to capture.
      • stereoundefined
        stereo
        Do all home X, Y work fine? Am I the only one? show homex.g
        On beta10
        G91 ; relative positioning
        G1 Z5 F6000 H2 ; lift Z relative to current position
        G1 H1 X-335 F1800 ; move quickly to X axis endstop and stop there (first pass)
        G1 X5 F6000 ; go back a few mm
        G1 H1 X-335 F360 ; move slowly to X axis endstop once more (second pass)
        G1 Z-5 F6000 H2 ; lower Z again
        G90 ; absolute positioning
        work good.
        On beta11 goto Z5,Z-5,X5.. but does not go to the microswitch.
          dc42 administrators @stereo
          @stereo said in RepRapFirmware 3.0beta 11 released:
          On beta10
          work good.
          Please post your config.g file. Which Duet are you using?
          stereoundefined 1 Reply Last reply Reply Quote 0
          • stereoundefined
            stereo @dc42
            M574 X1 S1 P"io0.in" or
            M574 X1 S0 P"io0.in"
            on beta11 always triggered YES.
            IF RUN "M574 Y2 S0","M574 X1 S0" work fine NO...
            normal config on beta10:
            Duet3
              A Former User @dc42
              @dc42 FOUND THE CAUSE OF THE BUG 😄
              This is ZPROBE.IN in beta10 (bltouch disconnected)
              as you can see ~3V with some ugly 50Hz garbage that should not interfere
              but this is ZPROBE.IN in beta11 (bltouch disconnected)
              as you can see it's floating around 1V at 50Hz so I'd say ZPROBE.IN is HIZ at this point and there is no pullup enabled... I don't see on schematic where zprobe_in becomes zprobe_mcu, are you using external pullup or you just need to configure it as in with pullup enabled .. anyhow .. there's no pullup on zprobe.in with beta11
                A Former User
                found the zprobe_in to zprobe_mcu .. just 10k trough and 2n2 down .. so def port configuration missing 😄
                and I also found the commit that introduced the bug:
                src/Endstops/LocalZProbe.cpp:42
                https://github.com/dc42/RepRapFirmware/blame/c25d73194252791ceb479ced79ffc77b31c810fe/src/Endstops/LocalZProbe.cpp#L42
                you switched it from PinAccess::readWithPullup; to PinAccess::read;
                Nuramoriundefined 1 Reply Last reply Reply Quote 0
                  A Former User
                  This will probbly work ok with bltouch v2 or v1 as they have 0/1 output, v3/v3.1 is open drain output so it can only pull low. Not sure why you switched from readWithPullup to read, but maybe create a new probe type with pullup, or should we add external pullup if this is to remain without one on the port?
                  • Nuramoriundefined
                    Nuramori @A Former User
                    @smece sadly, I saw your posts 3 minutes too late :p.
                    Thought my errant height map was a fluke due to a part swap. I dug a nice groove into my test spring plate (luckily I always use a sacrificial test plate whenever I change anything on the printer, hardware or software).
                    Moving back to 10 brought everything back to “normal”.
                      @smece said in RepRapFirmware 3.0beta 11 released:
                      Thanks for tracking this down. I removed implicit enabling of pullup resistors in beta 11 because it meant that you couldn't turn them off. If you want to enable the pullup resistor, you need to be explicit by using C"^zprobe.in" in your M558 command.
                      The BLTouch that I test with is the older version that drives the output high when triggered, that's why I didn't see the problem during testing.
                      I'll update the documentation to make this clear.
                      A Former User? 1 Reply Last reply Reply Quote 2
                        A Former User @dc42
                        @dc42 said in RepRapFirmware 3.0beta 11 released:
                        Perfect, this solves the problem. Everything works ok now.
                        M558 P9 C"^zprobe.in" H5 F120 T3000 A2
                        M950 S0 C"exp.heater3"
                        G31 P100 X35 Y0 Z2.2
                        • fmaundefined
                          fma
                          I just installed RRF3.0beta11 on my DuetWifi2, and I have troubles configuring Fans. In my config.g file, I have:
                          M950 F0 C"heater1" Q100    ; Fan 0 (water pump) is connected to heater 1, PWM at 100Hz
                          M950 F1 C"heater2" Q100    ; Fan 1 (Berd air pump) is connected to heater 2, PWM at 100Hz
                          M950 F2 C"duex.fan3" Q100  ; Fan 2 (Leds) is connected to heater 2, PWM at 100Hz
                          M950 S0 C"fan0"            ; Servo 0 is connected to "fan0" pin
                          M563 P0 D0 H1 F1 S"Manual"  ; Define tool 0 using Drive 0, Heater 1 and Fan 1
                          But I don't see any fan controls in DWC2... What I missed?
                          I also would like to know:
                          • how to setup thermostatic control for a fan
                          • how to name a fan
                          Thanks,
                          PS: the tool is working fine.
                          Frédéric
                          • gtj0undefined
                            gtj0 @fma
                            @fma You still need M106 commands...
                            This is for a Duet3 but
                            ; Fans & LEDs
                            M950 F0 C"out7" Q25000
                            M106 P0 C"PartCooling" S0  H-1
                            M950 F1 C"out8" Q25000
                            M106 P1 C"HotEnd" T45 H1
                            M950 F2 C"out9" Q100
                            M106 P2 S255 B0 C"Bed LED"
                            • fmaundefined
                              fma
                              Ok, I see. Thanks!
                              Frédéric
                              • fmaundefined
                                fma
                                I also have the homing issue G0/G1: insufficient axes homed.
                                But it does not happen all the time. It can home fine, then it does not. I can't find a pattern, it can happens at different stages...
                                I'm using a Duet2Wifi.
                                Here are my congif.g and all homing files:
                                ; Configuration file for Duet WiFi
                                M111 S0  ; Debugging off
                                G21      ; Work in millimetres
                                G90      ; Send absolute coordinates...
                                M83      ; ...but relative extruder moves
                                M555 P2  ; Set firmware compatibility to look like Marlin
                                M667 S1  ; Select CoreXY mode
                                M208 X-60:302 Y-100:305 Z0:320 U-1000:1000  ; Set axis limits
                                M584 X0 Y1 Z2 E5 U6                         ; Remap axes
                                M569 P0 S1                                  ; Drive 0 goes forwards
                                M569 P1 S1                                  ; Drive 1 goes forwards
                                M569 P2 S0                                  ; Drive 2 goes reverse
                                M569 P5 S0                                  ; Drive 5 goes reverse
                                M569 P6 S1                                  ; Drive 6 goes forward
                                M350 X16 Y16 Z16 E16 U16 I1                 ; Configure microstepping with interpolation
                                M92 X66.667 Y66.667 Z1417.323 E530 U140     ; Set steps per mm
                                M203 X30000 Y30000 Z1200 E3600 U3600        ; Set maximum speeds (mm/min)
                                M201 X1000 Y1000 Z100 E3000 U3000           ; Set accelerations (mm/s^2)
                                M566 X900 Y900 Z60 E600 U600                ; Set maximum instantaneous speed changes (mm/min)
                                M906 X1750 Y1750 Z1750 E750 U1250 I30       ; Set motor currents (mA) and motor idle factor in per cent
                                M84 S30                                     ; Set motors idle timeout
                                ; Endstops (must be defined after any M584 command)
                                M574 X2 S1 P"xstop"  ; X min active high endstop switch
                                M574 Y2 S1 P"ystop"  ; Y min active high endstop switch
                                M574 Z1 S1 P"zstop"  ; Z min active high endstop switch
                                ; Sensors
                                M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 R4700               ; bed temperature sensor uses 'bedtemp' pin
                                M308 S1 P"duex.e2temp" Y"thermistor" T100000 B4725 C7.06e-8 R4700  ; E0 temperature sensor uses 'deux.e2temp' pin
                                M950 H0 C"bedheat" T0          ; heater 0 uses the 'bedheat' pin and sensor 0
                                M143 H0 S120                   ; Set maximum heater 0 temperature to 120°C (not yet supported)
                                M307 H0 A105.6 C627.9 D1.5 B0  ; Auto-tune values for heater 0
                                M950 H1 C"duex.e2heat" T1      ; heater 1 uses the 'duex.e2heat' pin and sensor 1
                                M143 H1 S280                   ; Set maximum heater 1 temperature to 280C (not yet supported)
                                M950 F0 C"e0heat" Q100000           ; Fan 0 connected to 'e0heat' pin, PWM at 100KHz
                                M106 P0 C"Part cooling"             ; Part cooling fan uses fan 0
                                M950 F1 C"e1heat" Q100000           ; Fan 1 connected to 'e1heat' pin, PWM at 100KHz
                                M106 P1 C"Water pump" T45 H1 X0.25  ; Thermostatic fan uses fan 1, monitor heater 1, max PWM 25% (6V out of 24V)
                                M950 F2 C"duex.fan3" Q100           ; Fan 2 connected to 'duex.fan3' pin, PWM at 100Hz
                                M106 P2 C"Leds"                     ; Leds uses fan 2
                                ; Servos
                                M950 S0 C"fan0"  ; Servo 0 connected to 'fan0' pin
                                G10 P0 X0 Y0 Z0             ; Set tool 0 axis offsets
                                G10 P0 R190 S190            ; Set initial tool 0 active and standby temperatures
                                M207 S1.5 F2400             ; Set retraction length (G10/G11)
                                M572 D0 S0.08               ; Pressure advance
                                M550 PDuetWifi  ; Set machine name
                                M551 Pxxxxxx    ; Set password
                                M552 S1         ; Enable network
                                ; Access point is configured manually via M587 by the user
                                M586 P0 S1      ; Enable HTTP
                                M586 P1 S1      ; Enable FTP
                                M586 P2 S0      ; Disable Telnet
                                ; Misc
                                M912 P0 S-13  ; Calibrate CPU temp.
                                M106 P2 S0.1  ; Turn leds on 10%
                                ; homeall.g
                                ; called to home all axes
                                M98 P0:/sys/homexy.g
                                M98 P0:/sys/homez.g
                                M98 P0:/sys/homeu.g
                                ; homexy.g
                                ; called to home the X and Y axis
                                G1 Z1 F1200 H2  ; lift Z
                                G1 X325 Y325 F1800 H1  ; course home X or Y
                                G1 X325 H1             ; course home X
                                G1 Y325 H1             ; course home Y
                                G1 X-5 Y-5 F6000       ; move away from the endstops
                                G1 X325 F300 H1        ; fine home X
                                G1 Y325 H1             ; fine home Y
                                G1 Z-1 F1200 H2  ; lower Z
                                ; homez.g
                                ; called to home the Z axis
                                G1 Z-325 F600 H1  ; course home Z
                                G1 Z5 F1200       ; move away from the endstop
                                G1 Z-325 F120 H1  ; Fine home Z
                                ; homeu.g
                                ; called to home the U axis
                                G92 U0
                                Thanks for you help.
                                Frédéric
                                deckingmanundefined JoergS5undefined 2 Replies Last reply Reply Quote 0
                                  deckingman @fma
                                  @fma You need to put your M584 before M667 and M208. Look at the order dependencies here https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping. Also, it probably won't make any difference but M667 is deprecated and you should really be using M669 instead of M667.
                                  • fmaundefined
                                    fma
                                    Ok, thanks. I applied all these corrections, but I still have the issue.
                                    I tried to removed the U axis: not better.
                                    Frédéric
                                      deckingman @fma
                                      @fma Then I guess what's needed is some way of reproducing the problem - it's always difficult to diagnose when there is an element of "randomness" involved.
                                      Unfortunately, I'm unable to help much more because I can't home my printer at all. Some of my end stops are on expansion boards and RRF 3 firmware doesn't yet work for homing with end stops on expansion boards.
                                      • JoergS5undefined
                                        JoergS5 @fma
                                        @fma said in RepRapFirmware 3.0beta 11 released:
                                        I would propose as reason:
                                        means X maximum distance is 362, Y is 405, but you home only 325 each in
                                        , so depending on your current position you reach one of the endstops or not, assumed, 0 position is not defined after turning the printer on. I would change to
                                        G1 X500 Y500 F1800 H1
                                        and the followong two also to be sure they reach the endstops..
                                        • JoergS5undefined
                                          JoergS5
                                          This post is deleted!
                                          • JoergS5undefined
                                            JoergS5
                                            If G1 X325 Y325 F1800 H1 reaches X immediately, M208 defines X/Y position as 302/305, but in reality Y may be at -100. So it will not reach the endstop with the following Y move, even when the first line reached an endstop. So better 500 for the following two lines also.
