    retracts over Firmare or PrusaSlicer?
    3.7k
    • AS-3D Druckundefined
      AS-3D Druck
      Hello as the Topic name already says do i ask my self is it better to let the Slicer du the retracts or the Firmware?
      Cause i got a Bowden Extruder and the pure lenght of the Tube is about 840mm +/- and it oozes a lot and i hope Firmware retracts are better.
      Can someone pls tell me if this is the case or not?
      (Bondtech QR 2.85/3mm and e3D Bowden Hotend for 2.85mm Filament)
      Best regards
      AS-3D Druck / Andre
        I would use firmware retraction and pressure advance. The only reason to use slicer retraction is for using the coasting and wiping features, which usually don't work as well as pressure advance anyway.
        Firmware retraction is also much easier to tune because you can control it during a print.
        https://forum.duet3d.com/topic/5993/firmware-retraction-tuning-with-macros
          deckingman @AS-3D Druck
          @AS-3D-Druck In operational terms, both the slicer and firmware do the same thing. That is to say, both will run the extruder in reverse by an amount at a certain speed. Firmware retraction will also allow you to optionally use "Z hop" and set a different "un-retract" speed and distance but most slicers do this too. However, as @Phaedrux said, using firmware retraction does give you the ability to change parameters while a print is in progress, which is much easier than re-slicing and re-printing repeatedly. Also as @Phaedrux said, you may well benefit from using pressure advance which will likely allow you to use less retraction, regardless of whether you use the slicer or firmware to do those retractions.
          • garyd9undefined
            garyd9
            I'll throw a different opinion into the mix: I prefer slicer retractions to firmware retractions. My reason is that when I slice a model, I have a group of settings tailored to a type of filament. This includes nozzle/bed temperatures, speeds, and retraction distance/speeds.
            I don't think it's possible to configure a slicer to send per filament retraction distances/speed/zhop in the header of a gcode file, and then only to use firmware retraction while printing the actual model. (In other words, I don't think I can configure a slicer to send the proper M207 command (to configure retract lengths/speeds/z-hop) even with macros when it's set to do G10/G11 for firmware retract.)
            That implies that for each print, I'd have to configure some filament specific things in the slicer, and different filament specific things via printer macros or console - which is just one more thing for me to forget.
            Please note that I typed that I don't THINK its possible. If there's a way to have Cura (the slicer I use) send it's profile configured retraction distances/speeds/zhop via M207, AND to use firmware retraction, but to NOT actually also do software retraction/zhop, then I'm not aware of it... I also doubt S3D would support it. For other slicers, I don't know.
              Phaedrux Moderator @garyd9
              @garyd9 said in retracts over Firmare or PrusaSlicer?:
              In Prusa Slicer it's easy to configure this in the filaments tab in the custom gcode section. I really wish this was more common.
              For Cura you'd have to add it to the start gcode of the printer config and change it to suit every print since it doesn't have any filament specific settings unfortunately. S3D support for firmware retraction is a little weirder still.
              There's also the option of using the DWC filaments functionality and using the load and unload filaments commands that can load specific config options for each.
              I used to configure separate retraction for different filaments but once it was dialed in it seemed like it didn't really make a difference. I'll watch the first few layers of the print and if need be I'll modify the retraction, pressure advance, temp, flow, etc in real time.
              mkudziaundefined 1 Reply Last reply Reply Quote 0
              • mkudziaundefined
                mkudzia @Phaedrux
                @phaedrux
                Actually you can easily specify different firmware retractions and different pressure advance settings inside of duet.
                I suggest setting different filaments in the Duet Web Portal and within the config.g of the filament you can specify
                M572 D{state.currentTool} whatever
                M207 D{state.currentTool} whatever
                And then in your tXpost.g add M703
                That trigger executing the filament specific config.h after tool has been selected.
                Setting the filament profiles in duet may seem like extra effort but it also simplifies automated load and unload long term 🙂
                • Nordleundefined
                  Nordle
                  What happens if I set up firmware retraction and use different retraction settings in a slicer?
                  Alex.crundefined 1 Reply Last reply Reply Quote 0
                  • Alex.crundefined
                    Alex.cr @Nordle
                    @Nordle
                    If your slicer is configured to use slicer based retraction it will use the updated parameters from the slicer using straight line g code. Specifying retractions with a simple G1 Exxx Fyyy type commands. If you use firmware retraction in the slicer it will send G10 and G11 commands to perform the retraction; RRF will then interpret those and use the parameters from M207.
                    Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
