    Firmware Retraction Tuning with Macros
    macros retraction
    9
    26
    10441
      You can find a more complete set of tuning macros here:
      https://forum.duet3d.com/topic/6181/tuning-macros-menus-accel-jerk-retraction-pressure-advance
      Retraction Tuning Macros
      I took some time today to whip up a set of macros that should make fine tuning your retraction settings much easier.
      They can be found here: DropBox Download for Retraction Tuning Zip file
      Here's how it works.
        1. First you must have firmware retraction enabled in your slicer.
          1a. In Slic3r PE, this can be found under Printer settings, General tab, Firmware retraction check box near the bottom of the right pane.
          1b. In Cura, you will need to use version 3.4+ and install the Printer Settings plugin from the tool box, and then unhide the firmware retraction setting for it to show up in the right menu bar. It'll show up under the Printer Settings menu at the bottom.
          1c. In Simplify3D you'll have to setup a post processing script to insert the G10/G11 retraction commands at the appropriate place https://thrinter.com/using-firmware-retraction-with-simplify3d/
        1. Download a retraction tuning model from Thingiverse.
          There are plenty of guides out there that give you an idea of what to start with.
        1. Slice the model with firmware retraction enabled and your usual print settings
        1. Use the macros provided to quickly step through the various parameters while the print is running and note how they affect stringing and layer seams.
          4b. There are a range of hopefully sensible values for both direct drive, and bowden tube setups.
          4c. Every time you choose a value the current settings are echoed back so you can find them in the console.
          4d. Warning Be careful with retraction distance. Using Bowden distances in a direct drive system will quickly pull your filament right out and possibly lead to a jam.
        1. Once you have things looking good, use the macro to report the current settings and enter it into your config.g to make them permanent.
        1. You can edit the "Return to defaults" macro with your usual retraction settings so you have something to quickly return to if you really mess it up.
      Let me know how it works out for you if you try it or if you find any errors. Speeds and distances are fairly granular but you might want to fine tune by hand further once you get into the ball park.
      In addition to retraction parameters there is also extruder acceleration, jerk and travel acceleration which you can tune. These can be particularly useful for eliminating blobbing and stringing.
      wilriker dakingofhearts2003 2 Replies Last reply Reply Quote 8
      • fma
        fma last edited by
        Thanks for sharing! Very usefull.
        But you used the wrong param in the un-retract speed macros (F instead of T).
        Frรฉdรฉric
        Phaedrux 1 Reply Last reply Reply Quote 1
          Phaedrux Moderator @fma last edited by Phaedrux
          @fma aww shoot! I was worried I'd make a mistake like that. That was a lot of files to create. I'll fix that up and replace the zip file.
          Thanks for catching that.
          EDIT: Fixed!
          • fma
            fma last edited by
            Thanks ๐Ÿ™‚
            Frรฉdรฉric
            • wilriker
              wilriker @Phaedrux last edited by
              @phaedrux said in Firmware Retraction Tuning with Macros:
              That will make my MK8 direct drive (extruder and hotend) into a bowden system according to your distinction. ๐Ÿ˜ I have to use 3.5-5mm depending on the material to print.
              Anyway also thanks from me for providing these!
              Only one little thing: your zip file contains a lot of MacOS X specific files and directories. You might want to remove them. This will effectively half the number of files and size of all files.
              Manuel
              My Tool Collection
                Phaedrux Moderator @wilriker last edited by Phaedrux
                @wilriker thanks for the catch on the Mac system files. They are of course not visible on my system. I just used the built in compressor. I'll use a tool with more options and update the file.
                Do you think there are a lot more direct drive extruders with distances larger than those I provided? Would it be worthwhile to add more or would the average person know they needed longer? I'm always trying to keep the mind set of a beginner. Maybe a file named "if you need longer look in Bowden folder"
                EDIT: Fixed!
                wilriker 1 Reply Last reply Reply Quote 1
                • wilriker
                  That's what I thought, so I also thought I just tell you. ๐Ÿ˜‰
                  Hard to tell. I would assume that most modern direct drive extruders would either use a V6 style hotend that cannot handle such long retractions very well. Also if someone uses an older model like a MK8 then they either have bought a super cheap Anet A8 (like me) or already know what they are doing for a long time.
                  I bought my printer based on an article in the Make Magazine where they also provided a list of things that definitely need to be replaced for safety reasons as well as some helpful upgrades. They also provided profile files for Cura that had 7mm retraction length with which I started.
                  Anyway, I think your idea about the file that tells people to look in the bowden directory in case they need longer retractions is a good middle ground.
                  Manuel
                  My Tool Collection
                  • Drammy
                    Drammy last edited by
                    @Phaedrux These are excellent! Well done and thank you for taking the time to share them!
                      I've updated the download link to include macros for tuning extruder acceleration, jerk, and travel acceleration.
                      Next up, macros for tuning XYZ acceleration and jerk.
                      brunofporto 1 Reply Last reply Reply Quote 3
                      • brunofporto
                        brunofporto @Phaedrux last edited by
                        Waiting for that ๐Ÿ˜„
                        • brunofporto
                          brunofporto last edited by
                          Just using it now to tune.Thank you for this! ๐Ÿ˜„ Much easier!
                          Phaedrux 2 Replies Last reply Reply Quote 0
                            Phaedrux Moderator @brunofporto last edited by
                            @brunofporto I've got the other files mostly done. Will upload them after some testing.
                              @brunofporto Here you go.
                              • gideon
                                gideon last edited by
                                @Phaedrux hi have a small question. should the g10 / 11 in the start script of simply3d or not. I'm now ready to fine-tune, and jpu marcos will certainly come in handy.
                                  Phaedrux Moderator @gideon last edited by Phaedrux
                                  @gideon I don't understand your question.
                                  Have you configured Simplify3D to use firmware retraction? Perhaps using this method? http://thrinter.com/using-firmware-retraction-with-simplify3d/
                                  • kilop
                                    kilop last edited by kilop
                                    @phaedrux I done this today but you need to add extra post processing to simplify 3d very important is to not to put 4.5mm (like in that tutorial ) but 4.5000
                                    {REPLACE "G1 E-4.5000 F4800\n" "G10\n"}
                                    {REPLACE "G1 E-0.0500 F4800\n" "G11\n"}
                                    {REPLACE "G1 E-0.0500 F1440\n" "G11\n"}
                                    {REPLACE "; inner perimeter" "; inner perimeter\nM204 S1500\nM205 X20 Y20"}
                                    {REPLACE "; outer perimeter" "; outer perimeter\nM204 S500\nM205 X7 Y7"}
                                    {REPLACE "; solid layer" "; solid layer\nM204 S700\nM205 X10 Y10"}
                                    {REPLACE "; infill" "; infill\nM204 S1500\nM205 X15 Y15"}
                                    {REPLACE "; support" "; support\nM204 S1500\nM205 X20 Y20"}
                                    {STRIP "; postProcessing"}
                                    and i also added some settings to start script for M207
                                    M207 S4.5 F4800 Z0 ; set retraction length / speed
                                    I'm just not sure why here is also M208 in this tutorial
                                    M208 S0 F480 ; set retraction recover speed / adjustments
                                    because for unretract speed is M207 Txxx
                                    and then run some test prints with 4 small objects
                                    and after using this scripts i ended up with
                                    M207 S4.50 R-0.10 F6000 T4800 Z0.1 ๐Ÿ™‚ for Ziro White PLA
                                      Phaedrux Moderator @kilop last edited by
                                      @kilop M208 sets unretract length in smoothie and Marlin apparently. Good catch.
                                      • kilop
                                        @phaedrux
                                        probably there could be also other option to change retraction generated by simplify 3d
                                        in g-code tab tick m101 m102 m103 option
                                        and in post process put this
                                        {REPLACE "M101" "G11"}
                                        {REPLACE "M103" "G10"}
                                        {STRIP "M102"}
                                        I will check this tomorrow at work ๐Ÿ™‚
                                        with that option will be easier to just copy and paste script ๐Ÿ˜„ to another profile
                                        • dakingofhearts2003
                                          dakingofhearts2003 @Phaedrux last edited by
                                          @phaedrux Can you point me to a thread or an article about how to set up firmware retraction ?
                                            Phaedrux Moderator @dakingofhearts2003 last edited by
                                            @dakingofhearts2003 Well you need to enable it in your slicer and then have a command in your config.g to configure your retraction settings.
                                            dakingofhearts2003 1 Reply Last reply Reply Quote 0
                                              @phaedrux I understand that part. Understanding those macros and how to alter them is what im looking for ...
                                                @dakingofhearts2003 Retraction settings are configured with M207
                                                https://duet3d.dozuki.com/Wiki/Gcode#Section_M207_Set_retract_length
                                                  @phaedrux I am having some serious issues that i don't think the retraction will help but i was going to do the retraction tuning anyway. Am i supposed to enable relative extrusion distances in the slicer ? And where do i start to deal with the issue of parts coming out smaller than they are supposed to. I can get them to print well but not dimensionally accurate...
                                                    @dakingofhearts2003 Probably best to start a new thread to address your issues.
                                                    • d0minik96
                                                      d0minik96 last edited by
                                                      Is there are wipe while retracting function in firmware retraction aswell?
