    423
    98.9k
    • Rommieundefined
      Rommie
      well sent my donation to Moriquendi last night and bought my piezo today so just need to print the parts and then get it all together and fitted I guess, have you got any config changes that is required DJ and wiring diagram to the duetwifi board if you could, thanks in advance
      • DjDemonDundefined
        DjDemonD
        I intend to edit this as it develops. This now refers to the Mk III version (http://www.thingiverse.com/thing:2069480)
        Edited 29-01-17
        Edited 22-01-17
        Edited 21-01-17
        Edited 20-01-17
        So when assembling ensure the top circular part is attached to the lower clamp parts fairly firmly, doesn't matter if it bends a bit, get the torque around equal on each side. Then firmly attach it to the effector. Make sure the clamp is sliding on the rods. There will be almost no nozzle wobble if the clamp slides on the rods but doesn;t rock laterally.
        Okay so I have these two gcodes, about 10 lines up from the bottom in my config.g
        M558 P1 F500 I1 X0 Y0 Z0 ;analogue piezo sensor output falls on contact, probing speed 500 mm/min
        G31 X0 Y0 Z0 P600 ;sensor is nozzle, offsets for probe (nozzle) and trigger value.
        M558 sets an analogue sensor using the z-probe connector with an inverted output i.e. drops as it contacts the surface. It does not home any of the axes. I have selected probing speed 500 mm/min which gives the bed a firm tap, this increases the gap between signal and noise from the piezo sensor.
        The G31 offsets are 0,0,0 although depending on how compliant the assembly is it might need a tiny offset for z. So Z could read 0.05 to 0.015. You are likely to need a slight positive offset to counteract the fact that the assembly squashes down slightly into the bed to trigger (like with FSR's). You can add this offset in your slicer if you prefer. I think David is implementing babystepping soon which will be great. P600 is the trigger value from 0 to 1000. I chose this value by connecting it up, setting the signal board (see below) then moving around a bit and seeing what value is displayed under z-probe on the web interface during travel moves and sudden jerks etc… I chose a value above this, to prevent false triggers.
        Wiring. On Moriquendi's board the piezo has a two pin connector. I believe + and - need to go the right way around, the piezos come with red and black wires. It seems initially as though the series resistor is not required - but watch this space.
        The other side has +, -, sig which go to the Duetwifi z-probe port. You need a 3 pin connector at Moriquendi's board and a 4 pin connector on the duetwifi.
        On the duetwifi the z probe connector has 4 pins looking from the front of the board (the side with the LED's and USB port), the closest pin is signal, the next is -, the 3rd is unused and the 4th is +.
        On the signal board there are two trim pots. Adjust them cautiously if the power is on, as you might with a step stick, I momentarily made contact with something with my screwdriver bit and it triggered a reboot on the duetwifi - no damage done but take care! As I have mine configured (which is slightly different to Moriquendi's instructions) I turn VR2 until the led just comes on, then around a quarter turn more. Then try a few upward presses on the hot end, if it flashes off/on convincingly you are probably there, if not try VR1 in a variety of positions and try a few more head moves and nozzle pushes. You're looking to minimise triggers under normal movement but get a solid off/on on the LED when you push up on the hotend. If you see a few slight flickers during head movement that's okay, as long as when you press up on the hotend you get a much more obvious off-on on the LED. Don't be tempted to set it up so that only a really hard push gives a change in the LED this won't be sensitive enough. Mark the trim pots when you have a good position, they are very sensitive.
        Alternatively you can set VR2 so the LED just turns off, which is Moriquendi's method, then adjust the sensitivity on VR1, it seems to reverse the logic so that the signal rises as the piezo is bent/triggered. If you prefer this mode then change I1 to I0 in M558. I have not found this mode to work as well but let me know if you do.
        I have these lines in bed.g before probing, please modify to suit your machine, basically its low motor current, low jerk and low acceleration.
        ;slow down movement to improve accuracy, improve probing and lmit damage in case of head crash
        M906 X500 Y500 Z500 E800 I60 ; Set low motor currents (mA) and increase idle current to 60%
        M201 X250 Y250 Z250 E1000 ; Accelerations (mm/s^2)
        M203 X15000 Y15000 Z15000 E3600 ; Maximum speeds (mm/min)
        M566 X100 Y100 Z100 E1200 ; Maximum instant speed changes mm/minute
        and these after
        ;restore speed settings to normal printing speeds
        M906 X1100 Y1100 Z1100 E800 I60 ; Set normal motor currents (mA) and increase idle current to 60%
        M201 X3000 Y3000 Z3000 E1000 ; Accelerations (mm/s^2)
        M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute
        So that the machine accelerates/decelerates and jerks much less for probing, improving accuracy and eliminating false triggers.
        Make sure you delete your config_override.g file and set the approximate height in m665 in config.g by jogging down and measuring the distance travelled. This assembly lowers your nozzle by around 15mm (Lykle's effector does not so ignore this bit) if you don't do this (or forget to delete config_override.g) you will crash your nozzle on the first run.
        Calibrate with the bed hot, but with the nozzle, depending on the toughness of your printing surface, either stone cold - in which case you will need a z offset when printing as the hotend will expand when heated. Do the paper grip test after calibration to determine how much z offset. Or with the nozzle at your full first layer temp - I don't use this as a head crash onto printbite with nozzle at 250 deg C melts a hole in it, perhaps brief contact doesn't but I don't want any more holes, so I use 160 deg C (below ooze temp for ABS) and have a +0.2mm z-offset which I set in slic3r. I set the nozzle to come up to 160 in start gcode before autocalibration at start of each print, then to first layer temp after probing. It's better to have the nozzle hot (at least above glass transition temp) in case there's a bit of filament on the end from the last print, which will just squash down to nothing.
        A video of how I have it setup, and it working is now on youtube, apologies for the low production value.
        https://www.youtube.com/watch?v=F3vi6BOi6sA
        All feedback and any grammatical/spelling errors let me know I will try to incorporate this into the thingiverse listing along with some idiots-guide assembly pics, and make a wiki page here/wherever needed.
        www.precisionpiezo.co.uk
        • Moriquendiundefined
          Moriquendi
          The other two pins next to the piezo input are designed for a remote LED, I found it useful so I included it. The three pins at the other end of the board are meant to be the connection to the controller, V+, Signal and GND. On my Smoothieboard endstop headers are these three pins so thats what was convenient for me. However the only difference is that the LED output has a 1k series resistor on board. The resistor in series with the piezo element doesn't appear to be critical.
          Moriquendi
          • Sakeyundefined
            Sakey
            Set mine up today ( thanks Moriquendi for the board) but having a problem with it outputting a signal to the duet I think. The led triggers fine by the looks of it when I tap the Nozzle ( on board and the external ) but i'm not getting a trigger. Is this something to do with the way i set up the Potentiometers or Duet?
              Moriquendi
              If the LED is flashing you should have a signal going to the duet. Check what kind of signal the Duet is expecting, active low or active high. I'm afraid I have no experience with the Duet so I can't help you with that but I'm sure someone else on here can.
              One other thing to mention is that a trigger event is very brief, on the order of miliseconds, you won't be able to check the output of the board with a g-code to report z-probe state. Have you tried asking for a z-probe and then tapping the sensor to see if the Duet registers the trigger?
              Moriquendi
              PS. I've just had a look at the Duet documentation and I think people may be configuring it incorrectly for this type of z-probe. The output of the piezo sensor board is digital, not analogue. It appears from DjDemonDs config above that he has configured the Duet to expect an analog signal. Does this make a difference? I don't know but it's worth a shot.
              • DjDemonDundefined
                DjDemonD
                Have been probing away and changing things for the last few hours now.
                Setting it as digital M558 P5 for me anyway is not working. If I leave it set to analogue M558 P1 I1, inverted output and set the piezo board by turning VR2 until the LED is just on with sensitivity fairly high (VR1), but use a trigger value of 600 it works. Its also worth setting a probing speed of 500mm/min M558 F500 so that the nozzle gives the bed a fairly sharp tap rather than descends very slowly which sometimes doesn't trigger.
                My probe settings currently are
                M558 P1 I1 F500 X0 Y0 Z0 ;analogue piezo sensor output falls on contact, probing speed, not used to home axes
                G31 X0 Y0 Z0 P600 ;sensor is nozzle and trigger value.
                You can monitor the "analogue" output on web interface. Setup as I have mine the value shows approx 215 when head is stationary, during normal travel moves it goes up to 400-500, on a sharp tap with the bed it goes above 600 often to 1000 (max - essentially digital ON). At this setting on the piezo board I can get reliable and sensitive triggers.
                Of course having faster probing speed is risky its harder to pull the power in case of a head crash there is less time to do so, suggest setting your stepper motor current to as low as you can go whilst still moving, so that these are less severe if they happen. However faster probing speed will show false triggers requiring slightly less sensitivity (VR1), so its useful in that respect.
                • DjDemonDundefined
                  DjDemonD
                  My bed.g if it helps:
                  [[language]]
                  ; Auto calibration routine for delta printers
                  M561					; clear any bed transform, otherwise homing may be at the wrong height
                  G28					; home the printer
                  G28					;home again in case of endstop problem
                  ;slow down movement to delineate bed touch from travel moves
                  G30 P0 X0.00 Y120.00 Z-99999 H0
                  G30 P1 X75.20 Y89.63 Z-99999 H0
                  G30 P2 X109.80 Y19.36 Z-99999 H0
                  G30 P3 X95.08 Y-54.89 Z-99999 H0
                  G30 P4 X38.37 Y-105.43 Z-99999 H0
                  G30 P5 X-40.44 Y-111.11 Z-99999 H0
                  G30 P6 X-103.92 Y-60.00 Z-99999 H0
                  G30 P7 X-118.18 Y20.84 Z-99999 H0
                  G30 P8 X-77.13 Y91.93 Z-99999 H0
                  G30 P9 X0.00 Y60.00 Z-99999 H0
                  G30 P10 X46.66 Y26.94 Z-99999 H0
                  G30 P11 X43.81 Y-25.29 Z-99999 H0
                  G30 P12 X0.00 Y-54.74 Z-99999 H0
                  G30 P13 X-51.96 Y-30.00 Z-99999 H0
                  G30 P14 X-51.96 Y30.00 Z-99999 H0
                  G30 P15 X0 Y0 Z-99999 S6
                  G29 S1					;load grid levelling mesh
                  M376 H10				;taper off compensation after 10mm
                  G1 X0 Y0 Z75 F3000			; get the head out of the way of the bed
                  M500					;save calibration to config_override.g
                  Remove the G29 if you aren't using grid levelling, and the M500 unless you want auto-save of results to config_override.g and obviously replace the G30 points with your preferred probing locations and number of factors.
                  • Sakeyundefined
                    Sakey
                    Its weird. Both P1 and P5 do more a less the same thing for me but get slightly less crashed heads with P5. When I send the command to probe and it tap the nozzle it will register the tap .
                    It's like seems to be a delay between the trigger of the sensor and duet reading the probe point before it pushes though the bed. I don't think its a sensitivity problem because sometimes it will trigger from just the movement of the effector.
                    • DjDemonDundefined
                      DjDemonD
                      Sounds like you've got everything there, its just a case of finding the sweet spot where it triggers well. I might do a few videos later showing how I have it setup. You might have the clamp/piezo assembly tightened too much, try loosening it off a tiny bit. There is a zone where you find the optimum between a tight assembly/less sensitivity/firm nozzle, and a loose assembly/high sensitivity/wobbly nozzle. I say this as there is no delay as I have it setup the lightest touch of the nozzle gives an above threshold trigger.
                      • Boyan Silyavskiundefined
                        Boyan Silyavski
                        A question. Why all this trouble and not use a simple conductive touch plate with an known thickness? Same like most DIY CNCs use? Hot end could be wired constantly , led could be implemented for visual check if working, prior to test. Costs absolutely nothing. Plate could be moved sequentially manually to predefined places on heat bed. Is this possible with the Duet board?
                          Moriquendi
                          Because the end of a hot end nozzle is not a good contact, it's frequently coated in a layer of gunky/charred plastic.
                          Moriquendi
                            T3P3Tony administrators
                            Boytan
                            It would be possible as it could be setup as a switch, and the firmware will accept any sort of trigger as an endstop. (The signal needs to be within the 3.3V range however that is manageable).
                            One issue is as Moriquendi described - inconsistant conductivity due to plastic buildup on the nozzle. The other issue is that many(most) bed surfaces are non conductive to you have to have the manual intervention of applying a conductive sheet to the bed.
                            • DjDemonDundefined
                              DjDemonD
                              Yes I'd love to use a electrified nozzle and at one point I used to print onto aluminium and considered it. Plastic on the nozzle isn't really an issue if you probe hot. But now I print onto printbite which is super convenient and permanent and about as conductive as ceramic. I'd say most people are using glass or polymer surfaces of some sort.
                              • DjDemonDundefined
                                DjDemonD
                                Updated the tuning guide (long post) above and included a video of how I have it setup which might make it easier to see what I'm on about. https://www.youtube.com/watch?v=F3vi6BOi6sA
                                  Awesome! I linked your post and the video from the Tutorials page:
                                  https://duet3d.com/wiki/Tutorials#Experimental_Features
                                  Although at the rate this is progressing it wont be experimental for much longer.
                                  • DjDemonDundefined
                                    DjDemonD
                                    Next iteration is to make the nozzle wobble disappear almost completely, I had in mind attaching the upper part of the piezo sensor module to the lower with small smooth rods (or delrin rods?) which would slide into the lower clamp part, and if metal, could be greased. This would result in a very firm nozzle constrained laterally but free to move upwards by a small amount to flex the piezo disc.
                                    • Dougal1957undefined
                                      Dougal1957
                                      DJ
                                      PTFE rod is quite cheap and would probably be a better choice than Delrin or steel (Has self Lubricating properties IIRC).
                                      a 500mm length of say 10mm Diam is about £2.50 from one of my local suppliers it is available in 4,5,6,8,10 mm diam plus a lot bigger as well.
                                      https://www.directplastics.co.uk/ptfe-rod
                                      Look forward to seeing your design for it lol
                                      Doug
                                      • DjDemonDundefined
                                        DjDemonD
                                        Well here's a preview:
                                        I've modded Lykles version as he did his in proper CAD with all the holes geometrically correct etc..
                                        Its pretty simple just 4 rods (in the only places they can go without redesigning the clamp (which is a bit beyond my cad skills TBH). Bonded at the top piece or interference fit, and then initially adapted to the clamp by manually filing the holes in the clamp lightly to achieve a fit that allows vertical movement but not lateral movement. Either that or drill the top holes to 4mm and the lower ones to 4.2mm or something like that. I'd grease them if it were steel but maybe won't need to with PTFE. My concern is maybe the PTFE will flex a little and reduce the stiffening effect I'm hoping for, which is why I was thinking delrin if not steel, which is also self-lubricating (although much more expensive and harder to get hold of).
                                        What do you think? Very much open to ideas for a better way to do this.
                                        • Zesty_Lykleundefined
                                          Zesty_Lykle
                                          Hmm, would the wobble be decreased if we used a bigger peizo sensor?
                                          In other words, have a wider base where the hot end is pressed into.
                                          Related, how big is the wobble and how does it show up in your printing quality?
                                          Lykle
                                          Design, make and enjoy life
                                          Co Creator of the Zesty Nimble
                                            Dougal1957
                                            Problem with Delrin is getting anything smaller than 10 mm Diam.
                                            a 500mm long piece of 10mm delrin is about £1.25 so is about half the price of PTFE but I can pop in and get it of the shelf so to speak
                                            Would it help if I went and got a length of each and sent you say 100mm of each to try.
                                            I would be tempted to drill the top at 10 but the bottom at 10.1.
                                            Doug
