    Driver 0: short-to-ground
    989
    • kostasbmwundefined
      kostasbmw
      today i transfered my duet to a new corexy build and before i go on i wanted to test the movement..after connecting i had movement but in the wrong way...so i sent a m564 to check each motor separately...Z all ok disconected z wiring plug in X movement but i get the short to ground driver 0 error.....unplugged everything and click on x to move i get the same message.....is that normal?????note that i running the 2.04 firmware
      m122
      MCU temperature: min 23.8, current 27.9, max 28.2
      Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: short-to-ground standstill, SG min/max 0/1023
      Driver 1: standstill, SG min/max 0/1023
      Driver 2: standstill, SG min/max 82/232
      the config file
      ; generated by RepRapFirmware Configuration Tool on Tue Oct 09 2018 13:27:56 GMT+0300
      M80 ; Turns on the ATX power supply
      M667 S1 ; Select CoreXY mode
      M550 PBLV mgn Cube ; Set machine name
      M552 S1 ; Enable network
      M587 S"kostas" P"11111111" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; Drive 0 goes backwards blv: its was S1
      M569 P1 S0 ; Drive 1 goes backwards blv: its was S1
      M569 P3 S1 ; Drive 3 goes backwards WAS 0
      M92 X200 Y200 Z400 E405.18 ; Set steps per mm for Bondtech.
      M566 X600 Y600 Z24 E300 ; Set maximum instantaneous speed changes (Jerk) (mm/min)
      M203 X20000 Y20000 Z600 E2000 ; Set maximum speeds (mm/min)
      M201 X3000 Y3000 Z100 E5000 ; Set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      ; Pressure advance
      ; M572 D0 S0.05 ; disabled Pressure advance
      M208 X-23 Y0 Z0 S1 ; Set axis minima
      M208 X320 Y321 Z350 S0 ; Set axis maxima
      M574 X1 Y2 S1 ; Set active high endstops edit: Y endstop is high(max).
      ; Filament sensor
      M591 D0 P1 C3 S1 ; Set Filament sensor Simple type (High) for extruder drive 0, connected to endstop input 3 (E0)
      M574 Z1 S2 ; Set endstops controlled by probe
      M307 H1 A372.3 C109.6 D4.6 B0 ; Set PID for hotend values
      M307 H0 A99.1 C453.2 D2.2 B0 ; Set PID for heated bed values
      M558 P1 H5 F200 T9000 I0 R0.5 ; Set Z probe type mini ir sensor
      G31 P500 X-2 Y-16.4 Z1.043 ; Set Z probe trigger value, offset and trigger height
      M557 X30:270 Y30:270 S80 ; Define mesh grid
      M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
      M143 H0 S100 ; Set temperature limit for heater 0 to 100C
      M305 P1 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S260 ; Set temperature limit for heater 1 to 260C
      M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T35 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H1 T35 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S21 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      M564 H0 ; Let the Jog buttons work blv: added to allow jog buttons
      thanks
        kostasbmw
        anything , someone ............i have recheck the whole thing ..........................connected motors or disconected i get the same message....
          To be clear: are you saying that with nothing connected to the X motor connector of the Duet, you get the Driver 0 short to ground error message?
          Is that driver chip (the middle one) getting hot?
          Could the underside of the Duet be shorting against anything?
            droftarts administrators
            No, that's not normal.
            M564 on it's own only reports whether movement is allowed. Send M564 H0 to allow moves of axes that have not been homed, or set a position with G92 Xnn Ynn Znn.
            Did you turn off the printer before moving the stepper motor wiring? While the Trinamic drivers cope with disconnection better than the Allegro drivers on old boards, it's still possible to damage a driver by disconnecting a motor and reconnecting it with the driver powered up.
            You say you have checked your wiring. Did you do a continuity test at the motor connector, checking for continuity on each pair of contacts? Or tried another motor on this connection? If it's a particular motor and everything else seems okay, the pins in the housing use a spring contact to connect to the pins on the Duet, which can get folded back and lose it's connection.
            Is it just the X axis or do other axes not work? If it's all the axes, check the fuses on the Duet are okay.
            Remove or comment out M587 from your config.g. This is stored in the WiFi module's flash memory. Getting it to store this information each time the printer is turned on will eventually degrade the flash memory unnecessarily. It's also a security risk. See the last 'Important' note on this page: https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
              kostasbmw
              ok
              no temp rising...around 28-29c
              no short under the board i used plywood,no wires go under
              yes nothing connected i get the same message if i click to move the x or y axis
              no with everything connected when i move Z no error messages appear
              when i move x or y they move like sideways....but they move...i have to retrieve config.g file(s0 s1)
              i have checked the motor wiring pairs...i have done this a lot of times
              i have the duet wifi for 9 months with no issues running on the same power supply 24v,the only change was 0,9 motors for x and y and 1.8 for z.
              should i go back to factory settings or downgrade to test???
                Hmm. You could try downgrading the firmware, but I doubt it will make a difference. It does sound like the driver may have died, but it can be hard to know for certain. I don't quite understand what you are saying with:
                @kostasbmw said in Driver 0: short-to-ground:
                Do the motors not move correctly?
                You could remap the drives to avoid using X for now. I notice you have no M584 command in your config.g, but this shouldn't matter as you currently have everything mapped as standard. If you add:
                M584 X4 Y1 Z2 E3
                M569 P4 S0 ; X on E1
                to the beginning of your "Drives" section, and plug X motor into E1, that should get you up and running.
                  kostasbmw
                  @droftarts said in Driver 0: short-to-ground:
                  M584 X4 Y1 Z2 E3
                  you right i wrote backwards
                  short to ground reported by driver 0
                    kostasbmw
                    ok i m getting somewhere for now with no errors...
                    the only thing i get wrong is that when i go Ymax (to the back of printer) with a +10 it goes forward....the X is ok + to the right and - to the left
                    thanks Ian anyway it was a big help for now because my budget is very low at the moment...
                    • Vetiundefined
                      Veti
                      see
                      https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter
                      for movement config
                      kostasbmwundefined 1 Reply Last reply Reply Quote 1
                        kostasbmw @Veti
                        @Veti thanks all ok
                        now the endstops
                        Ian saved the day
                          kostasbmw
                          ok after all this endstops (mechanical 2 wire) they light up but dont work.......the config has changed a little due to bltouch,movement is
                          perfect but no endstops...they respond in system properties....
                          @droftarts
                          after yesterdays change to E1 from X is there something else ?? do i have to move the X endstop to E1 endstop??
                          Drives
                          M584 X4 Y1 Z2 E3
                          M569 P4 S1 ; X on E1
                          M569 P0 S1 ; Drive 0 goes backwards blv: its was S1
                          M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
                          ; Pressure advance
                          M574 X1 Y2 S1 ; X home to min. Y home to max. Normally Closed limit switches.
                          M574 Z1 S2 ; Define Z to use Probe. Home to Min
                            droftarts administrators @kostasbmw
                            Yes! Sorry, forgot to say. It's just X that isn't working? The other should be unchanged.
                              kostasbmw
                              the endstops connected but not stopping movement of the x or y axis
                              • Vetiundefined
                                Veti
                                it only stops the movement during homing. not normal moves.
                                to manually check use M119
                                https://duet3d.dozuki.com/Wiki/Gcode#Section_M119_Get_Endstop_Status
                                  kostasbmw
                                  it does not in any way
                                  8:43:01 AM
                                  M119
                                  Endstops - X: at min stop, Y: at max stop, Z: not stopped, Z probe: not stopped
                                  • Vetiundefined
                                    Veti
                                    check the wiring of the endstops.
                                    see if they are connected correctly.
                                    until you can see them trigger with m119 it wont work.
                                    post a picture of the endstop and the connection on the duet.
                                      kostasbmw
                                      IMG_5653.JPG IMG_5662.JPG )
                                      pictures of board and endstop
                                      • Vetiundefined
                                        Veti
                                        post M119 with endstop triggered and without triggered.
                                        also host your homex.g
                                          kostasbmw
                                          home x and y solved ......i changed the wiring and now the endstops work
                                          crazy.....i m going through the cable to see for a broken part
                                          also i moved back to original position the x endstop because the drive for x is on E1....and i had the endstop above E1
                                          so far so good...untill next problem
                                          thanks for your time @Veti
                                          • UnderDoneSushiundefined UnderDoneSushi referenced this topic
