    Driver 0: short-to-ground
    970
    • kostasbmwundefined
      kostasbmw
      anything , someone ............i have recheck the whole thing ..........................connected motors or disconected i get the same message....
        To be clear: are you saying that with nothing connected to the X motor connector of the Duet, you get the Driver 0 short to ground error message?
        Is that driver chip (the middle one) getting hot?
        Could the underside of the Duet be shorting against anything?
          droftarts administrators
          No, that's not normal.
          M564 on it's own only reports whether movement is allowed. Send M564 H0 to allow moves of axes that have not been homed, or set a position with G92 Xnn Ynn Znn.
          Did you turn off the printer before moving the stepper motor wiring? While the Trinamic drivers cope with disconnection better than the Allegro drivers on old boards, it's still possible to damage a driver by disconnecting a motor and reconnecting it with the driver powered up.
          You say you have checked your wiring. Did you do a continuity test at the motor connector, checking for continuity on each pair of contacts? Or tried another motor on this connection? If it's a particular motor and everything else seems okay, the pins in the housing use a spring contact to connect to the pins on the Duet, which can get folded back and lose it's connection.
          Is it just the X axis or do other axes not work? If it's all the axes, check the fuses on the Duet are okay.
          M587 S"kostas" P"11111111" ; Configure access point. You can delete this line once connected
          Remove or comment out M587 from your config.g. This is stored in the WiFi module's flash memory. Getting it to store this information each time the printer is turned on will eventually degrade the flash memory unnecessarily. It's also a security risk. See the last 'Important' note on this page: https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M587_Add_WiFi_host_network_to_remembered_list_or_list_remembered_networks
            kostasbmw
            ok
            no temp rising...around 28-29c
            no short under the board i used plywood,no wires go under
            yes nothing connected i get the same message if i click to move the x or y axis
            no with everything connected when i move Z no error messages appear
            when i move x or y they move like sideways....but they move...i have to retrieve config.g file(s0 s1)
            i have checked the motor wiring pairs...i have done this a lot of times
            i have the duet wifi for 9 months with no issues running on the same power supply 24v,the only change was 0,9 motors for x and y and 1.8 for z.
            should i go back to factory settings or downgrade to test???
              Hmm. You could try downgrading the firmware, but I doubt it will make a difference. It does sound like the driver may have died, but it can be hard to know for certain. I don't quite understand what you are saying with:
              @kostasbmw said in Driver 0: short-to-ground:
              Do the motors not move correctly?
              You could remap the drives to avoid using X for now. I notice you have no M584 command in your config.g, but this shouldn't matter as you currently have everything mapped as standard. If you add:
              M584 X4 Y1 Z2 E3
              M569 P4 S0 ; X on E1
              to the beginning of your "Drives" section, and plug X motor into E1, that should get you up and running.
                kostasbmw
                @droftarts said in Driver 0: short-to-ground:
                M584 X4 Y1 Z2 E3
                you right i wrote backwards
                short to ground reported by driver 0
                  kostasbmw
                  ok i m getting somewhere for now with no errors...
                  the only thing i get wrong is that when i go Ymax (to the back of printer) with a +10 it goes forward....the X is ok + to the right and - to the left
                  thanks Ian anyway it was a big help for now because my budget is very low at the moment...
                  • Vetiundefined
                    Veti
                    see
                    https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter
                    for movement config
                    kostasbmwundefined 1 Reply Last reply Reply Quote 1
                      kostasbmw @Veti
                      @Veti thanks all ok
                      now the endstops
                      Ian saved the day
                        kostasbmw
                        ok after all this endstops (mechanical 2 wire) they light up but dont work.......the config has changed a little due to bltouch,movement is
                        perfect but no endstops...they respond in system properties....
                        @droftarts
                        after yesterdays change to E1 from X is there something else ?? do i have to move the X endstop to E1 endstop??
                        Drives
                        M584 X4 Y1 Z2 E3
                        M569 P4 S1 ; X on E1
                        M569 P0 S1 ; Drive 0 goes backwards blv: its was S1
                        M569 P3 S1 ; Drive 3 goes backwards WAS 0
                        M92 X200 Y200 Z400 E405.18 ; Set steps per mm for Bondtech.
                        M566 X600 Y600 Z24 E300 ; Set maximum instantaneous speed changes (Jerk) (mm/min)
                        M203 X20000 Y20000 Z600 E2000 ; Set maximum speeds (mm/min)
                        M201 X3000 Y3000 Z100 E5000 ; Set accelerations (mm/s^2)
                        M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
                        M84 S30 ; Set idle timeout
                        ; Pressure advance
                        ; M572 D0 S0.05 ; disabled Pressure advance
                        M208 X-23 Y0 Z0 S1 ; Set axis minima
                        M208 X320 Y321 Z350 S0 ; Set axis maxima
                        M574 X1 Y2 S1 ; X home to min. Y home to max. Normally Closed limit switches.
                        M574 Z1 S2 ; Define Z to use Probe. Home to Min
                          droftarts administrators @kostasbmw
                          Yes! Sorry, forgot to say. It's just X that isn't working? The other should be unchanged.
                            kostasbmw
                            the endstops connected but not stopping movement of the x or y axis
                            • Vetiundefined
                              Veti
                              it only stops the movement during homing. not normal moves.
                              to manually check use M119
                              https://duet3d.dozuki.com/Wiki/Gcode#Section_M119_Get_Endstop_Status
                                kostasbmw
                                it does not in any way
                                8:43:01 AM
                                M119
                                Endstops - X: at min stop, Y: at max stop, Z: not stopped, Z probe: not stopped
                                • Vetiundefined
                                  Veti
                                  check the wiring of the endstops.
                                  see if they are connected correctly.
                                  until you can see them trigger with m119 it wont work.
                                  post a picture of the endstop and the connection on the duet.
                                    kostasbmw
                                    IMG_5653.JPG IMG_5662.JPG )
                                    pictures of board and endstop
                                    • Vetiundefined
                                      Veti
                                      post M119 with endstop triggered and without triggered.
                                      also host your homex.g
                                        kostasbmw
                                        home x and y solved ......i changed the wiring and now the endstops work
                                        crazy.....i m going through the cable to see for a broken part
                                        also i moved back to original position the x endstop because the drive for x is on E1....and i had the endstop above E1
                                        so far so good...untill next problem
                                        thanks for your time @Veti
                                        • UnderDoneSushiundefined UnderDoneSushi referenced this topic
