Driver 0: short-to-ground
945
    droftarts administrators
    Hmm. You could try downgrading the firmware, but I doubt it will make a difference. It does sound like the driver may have died, but it can be hard to know for certain. I don't quite understand what you are saying with:
    @kostasbmw said in Driver 0: short-to-ground:
    when i move x or y they move like sideways....but they move...i have to retrieve config.g file(s0 s1)
    Do the motors not move correctly?
    You could remap the drives to avoid using X for now. I notice you have no M584 command in your config.g, but this shouldn't matter as you currently have everything mapped as standard. If you add:
    M584 X4 Y1 Z2 E3
    M569 P4 S0 ; X on E1
    to the beginning of your "Drives" section, and plug X motor into E1, that should get you up and running.
      kostasbmw
      @droftarts said in Driver 0: short-to-ground:
      M584 X4 Y1 Z2 E3
      you right i wrote backwards
      short to ground reported by driver 0
        kostasbmw
        ok i m getting somewhere for now with no errors...
        the only thing i get wrong is that when i go Ymax (to the back of printer) with a +10 it goes forward....the X is ok + to the right and - to the left
        thanks Ian anyway it was a big help for now because my budget is very low at the moment...
          Veti
          see
          https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter
          for movement config
          undefined 1 Reply Last reply 19 Nov 2019, 17:45 Reply Quote 1
            kostasbmw @Veti
            @Veti thanks all ok
            now the endstops
            Ian saved the day
              kostasbmw
              ok after all this endstops (mechanical 2 wire) they light up but dont work.......the config has changed a little due to bltouch,movement is
              perfect but no endstops...they respond in system properties....
              @droftarts
              after yesterdays change to E1 from X is there something else ?? do i have to move the X endstop to E1 endstop??
              Drives
              M584 X4 Y1 Z2 E3
              M569 P4 S1 ; X on E1
              M569 P0 S1 ; Drive 0 goes backwards blv: its was S1
              M569 P3 S1 ; Drive 3 goes backwards WAS 0
              M92 X200 Y200 Z400 E405.18 ; Set steps per mm for Bondtech.
              M566 X600 Y600 Z24 E300 ; Set maximum instantaneous speed changes (Jerk) (mm/min)
              M203 X20000 Y20000 Z600 E2000 ; Set maximum speeds (mm/min)
              M201 X3000 Y3000 Z100 E5000 ; Set accelerations (mm/s^2)
              M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              ; Pressure advance
              ; M572 D0 S0.05 ; disabled Pressure advance
              M208 X-23 Y0 Z0 S1 ; Set axis minima
              M208 X320 Y321 Z350 S0 ; Set axis maxima
              M574 X1 Y2 S1 ; X home to min. Y home to max. Normally Closed limit switches.
              M574 Z1 S2 ; Define Z to use Probe. Home to Min
              undefined 1 Reply Last reply 20 Nov 2019, 11:33 Reply Quote 0
                droftarts administrators @kostasbmw
                Yes! Sorry, forgot to say. It's just X that isn't working? The other should be unchanged.
                  kostasbmw
                  the endstops connected but not stopping movement of the x or y axis
                    Veti
                    it only stops the movement during homing. not normal moves.
                    to manually check use M119
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M119_Get_Endstop_Status
                      kostasbmw
                      it does not in any way
                      8:43:01 AM
                      M119
                      Endstops - X: at min stop, Y: at max stop, Z: not stopped, Z probe: not stopped
                        Veti
                        check the wiring of the endstops.
                        see if they are connected correctly.
                        until you can see them trigger with m119 it wont work.
                        post a picture of the endstop and the connection on the duet.
                          kostasbmw
                          IMG_5653.JPG IMG_5662.JPG )
                          pictures of board and endstop
                            Veti
                            post M119 with endstop triggered and without triggered.
                            also host your homex.g
                              kostasbmw
                              home x and y solved ......i changed the wiring and now the endstops work
                              crazy.....i m going through the cable to see for a broken part
                              also i moved back to original position the x endstop because the drive for x is on E1....and i had the endstop above E1
                              so far so good...untill next problem
                              thanks for your time @Veti
                              • undefined UnderDoneSushi referenced this topic 30 Dec 2021, 18:01
                              15 out of 19
