Mid air printinting
The reason for -1 in my config is if i want to play with baby stepping to get the correct "squish" up or down the negative number allows me to to that.
As for tall prints its not an issue, these printers will never have perfectly straight lead screws and contraining them at the top means any bend has to show up somewhere and thats in the print. if you allow the lead screw to move about on the X,Y planes it doesnt matter, all that matters is the Z axis which is lift up or down and the weight of the carriage keeps the lead screw nuts where the are supposed to be and the carriage wheels on the X gantry keep everything where it is supposed to be, I even have the leadsrew nuts loosened off a tiny amount on X carriage mounts to allow the nuts to float around on the X,Y planes.
@CaLviNx can you confirm with me these configs are still valid for a Chiron ? Im about to tackle mine with a Duet ethernet
I am running a duet 2 WiFi with a titan direct drive, the files I posted haven't been changed but will represent a WiFi with a titan and e3d v6.
@CaLviNx great im using a Titan Aero / Volcano combo only change for wifi to ethernet is ip configuration. Can i ask how did you wire your Z ?? repurposed E1 ?
Yes for the second Z I remapped E1 I did away with the two z optical end stops and used an IR sensor you can see all this from looking at the config.g
Using independent motor/drivers allow you to use compensation too. -
@CaLviNx ok seriously confused, if there 2 Z connectors on the board why does one need to remap E1 ? guess im not understanding the why it needs remapoping and you cant just use the 2 Z connectors
@dingo007
The two z connectors are powered from one driver. This results in half the amps available for each z motor.Remapping one z motor to E1 allows for independent motor control. You can then use your z probe to level your X carriage to your bed.
@jay_s_uk ahhhh got it... now it all makes sense! Thanks
@jay_s_uk said in Mid air printinting:
Not correct. As Duet Z connectors are wired in series, not parallel, amps remaining same. What they need more is voltage, so when using 2 Zconnectors it is recommended to use 24V for VIN.
@aidar ah, ok. Thanks
@CaLviNx ok slightly confused about the SDcard and LCD panel, no longer needed right so dont bother trying to wire them in??
Correct it's now surplus to requirements,
You only keep the motors, the wiring to the motors x and y end stops, and everything going upto the hotend of course.
As there is TWO psu's wire the "laptop" style one to the duet then feed the signal for the heated bed back out to the chiron's on board mostfet and leave the psu that supplies it alone.
@CaLviNx okay last silly question is there a guide for using independent motor/drivers allowing the use of compensation too. i take it it is not the same as automatic bed leveling! Sorry a little new to this 3D stuff and got a bastard chiron riddled with issue out of the box. working to get it happy.
You need to follow the dozuki it covers exactly what you want, also if you examine the content of my config.g that shows you everything I did to get the Chiron up running including both z motor locations.
Here is a look under the hood of how I wired everything up
@CaLviNx ahaah..! so you removed everything but the Duet and the power board and wired everything direct. Got it. even removed the fan ?
So question, where did these 3D printed mounts come from for the Duet? and the Block mount for where the other wire p[anel head was you have a 3D printed cover on it. I guess its just treat it like a normal machine and wire it all direct then. I really appreciate the photo, it clear up alot of the questions. Also curious you mentioned Titan Aero ? What mount did you print? was if from thingiverse ? -
@dingo007 said in Mid air printinting:
So question, where did these 3D printed mounts come from for the Duet? and the Block mount for where the other wire p[anel head was you have a 3D printed cover on it. I guess its just treat it like a normal machine and wire it all direct then. I really appreciate the photo, it clear up alot of the questions. Also curious you mentioned Titan Aero ? What mount did you print? was if from thingiverse ?The internal cooling fan was a noisy waste of time.
As for where ALL the printed parts came from, well they came from ME, I designed and printed everything because most of the things I have found on thingiverse are dimensionally inaccurate and the STL's turn out to be such a mess that they needs hours of fixing, so much so that I usually ended up re-drawing them so it made logical sense to just draw my own models up and that way I knew they were going to be right.
The Mount was one I drew up for an ender 3 that I modified to suit the Chiron as im using a Tita with a E3D V6 NOT An Aero. As you can see also I purposefully made the IR Sensor bracket to be a "weak point" so that if there a wiring failure or such like and the head goes nuts the IR sensor bracket will break away and not damage anything if it collides with the print.
@CaLviNx jeeeezzz you should post this on thingiverse the mount i have from thingiverse for the duet https://www.thingiverse.com/thing:3284835 was a no fit out of the gate, just wasted plastic. id be interested in your duet files if your willing to share them. looks like a great job. ive had to reply on thingiverse as im not CAD capable. embedded systems engineering is my strength, design nope.... right now im working on rewiring the bottom side based on your photo. great big help. the mount https://www.thingiverse.com/thing:3154521 for my Aero is what i have currently planned.
Two problems with posting on Thingiverse....
Most of the files no longer exsist, I drew them up, printed them and I dont think I kept them, purely because they did their job and are no longer required, many of the simple brackets took just a few minute to draw up, I did this as I was wiring things up and worked out what I needed to do the job.
In all honesty I dont post anything I design on thingiverse, because I cant be bothered with the hassle, I have seen other guys post stuff that some people cant get to print, the people who cant get the part to print then bitch that the part is rubbish, so no im not doing that because I know the parts print for me, and that is all that matters.
Here is the latest copy of my operational Config files, please use at your own risk, what works for me may not work for you, please study them carefully
