Problem with Magnetic Sensor
Filament Monitor
1.9k
    DarylMcM
    Changed length of measurement to 12mm and things improved somewhat. Updated sensitivity also.
    Noted a fluctuation in the mag parameter being reported.
    5:57:31 PM
    M591 D0
    Duet3D magnetic filament monitor on input 3, disabled, sensitivity 27.21mm/rev, allow 30% to 130%, check every 12.0mm, version 3, mag 131 agc 69, measured sensitivity 27.31mm/rev, min 58% max 110% over 32428.9mm
    5:56:25 PM
    M591 D0
    Duet3D magnetic filament monitor on input 3, disabled, sensitivity 27.21mm/rev, allow 30% to 130%, check every 12.0mm, version 3, mag 132 agc 69, measured sensitivity 27.31mm/rev, min 58% max 110% over 32039.7mm
      DarylMcM
      14 hours later and About 100 meters of filament to go on this 445 meter job. After tweaking sensitivity, ratios, extruder rate, print speed and closely visually monitoring print quality, I found the filament monitor setting that work with this less than satisfying wood PLA filament.
      They are not ideal, but unless one is down with running about 75 % print speed, this is what worked. Slowing the print speed increased the min reported back up to upper 60s percentage.
      Extrusion at 100%, speed at 100% (80mm/sec max), temp mid range of filament noted temp range (200c in this case) and the following:
      **8:23:33 AM
      M591 D0
      Duet3D magnetic filament monitor on input 3, enabled, sensitivity 28.02mm/rev, allow 20% to 130%, check every 12.0mm, version 3, mag 131 agc 70, measured sensitivity 27.91mm/rev, min 28% max 113% over 13183.3mm
      (From M122report)
      === Filament sensors ===
      Extruder 0: pos 350.16, errs: frame 16 parity 0 ovrun 0 pol 2 ovdue 0**
      The above was taken after reloading filament this AM.
      Note the agc has climbed to 70 while the mag has continued to fluctuate from 130 to 132. AGC usually stands for automatic gain control and my assumption of the mag number has to do with magnetic strength, but I'm just guessing. The need for a sensitivity setting I still find remarkable, but again assuming, it is probably due to reading a magnetic rotation instead of having a direct drive.
      The monitor did save my job by detecting a very slight blockage in the nozzle, noted by the tell tail curving of the filament as it is extruded. The min reported was 19%. It also properly paused the job when the filament ran out.
      My big takeaway from this job is Not All Filaments are Monitored Equally. Wood filament is a strange animal anyway. I have two more runs of this job to go on this printer and I am anxious to move on to some peg jobs to see how that goes.
      All in all I am very satisfied with this monitor. It would be great to have the report to include the current measured percentage. This would allow one to note the current trend. A means of distinguishing a monitor pause from a button pause would also be a fine feature.
      Like any other new trick, it just takes some training to get the dog to rollover and speak.
      undefined 1 Reply Last reply 11 Nov 2019, 14:35 Reply Quote 0
        dc42 administrators @DarylMcM
        @DarylMcM said in Problem with Magnetic Sensor:
        That's correct. The 'mag' value is after agc is applied, so will always be around the same value until the gain runs out (indicated by agc=128 which is its maximum value). So it is the agc value that gives a better indication of magnetic field strength, lower values = higher strength.
        To get good readings, it is critical that when the extruder retracts filament, the filament gets pushed back through the filament monitor and turns it backwards. This is best achieved by keeping the filament path between the filament monitor and extruder drive very short and straight, and constraining the filament in that region in PTFE tubing which is only just large enough for the filament,
          DarylMcM
          dc42, I do have a minimal distance between the monitor and the extruder entrance. About 3mm. I do not have PTFE in that small area. I do have PTFE restraining the filament from the reel to the entrance of the monitor keeping it straight.
          Does the 'A' parameter of the M591 entry need to be set in order for the retractions to be Taken into account?
          undefined 1 Reply Last reply 11 Nov 2019, 17:15 Reply Quote 0
            No. The default is A0 which means that actual/commanded movement will only be compared during normal printing moves, not retraction or re-prime moves. You can try A1 if you like, but it will probably give worse results.
              RandyL
              I seem to be having a simmer issue. I installed the mag sensor about a week ago recently purchased from Filastruder as well. It was working okfor a couple of prints then all of a sudden it started overrunning the set parameters of R60:130 L24.8 E3.0. When I swapped out the filament to Ninja Flex ( a very soft TPU) I stated seeing under runs of ~ 30 to 35%. I adjusted the "R" value accordingly and the remainder of the TPU prints finished off ok. I then swapped out my .04 nozzle for a .8mm nozzle with PLA+ and things went south. I'm now seeing under runs down to 10% and over runs up to 330% My last print was like so:
              Duet3D rotating magnet filament monitor v2 on input 3, enabled, sensitivity 25.05mm/rev, allow 10% to 370%, check every 3.0mm, current pos 259.8, measured sensitivity 25.27mm/rev, min 94% max 179% over 9348.6mm
              I replaced the the cable between the sensor the E1 stop input with a twister trio to cancel out any interference but this did not make any difference.
              My diag output:
              RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
              Board ID: 08DGM-917DA-G4MSJ-6JTF0-3S86M-T9NMA
              Used output buffers: 1 of 24 (12 max)
              Static ram: 25680
              Dynamic ram: 94232 of which 16 recycled
              Exception stack ram used: 540
              Never used ram: 10604
              Tasks: NETWORK(ready,524) HEAT(blocked,1236) MAIN(running,1668) IDLE(ready,160)
              Owned mutexes:
              Last reset 01:22:56 ago, cause: software
              Last software reset at 2019-11-18 13:58, reason: User, spinning module GCodes, available RAM 10652 bytes (slot 1)
              Error status: 0
              Free file entries: 10
              SD card longest block write time: 12.1ms, max retries 0
              MCU temperature: min 28.5, current 29.3, max 31.9
              Supply voltage: min 23.9, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 0: standstill, SG min/max 0/1023
              Driver 1: standstill, SG min/max 0/1023
              Driver 2: standstill, SG min/max 0/117
              Driver 3: standstill, SG min/max 0/1023
              Driver 4: standstill, SG min/max 0/107
              Date/time: 2019-11-18 15:21:31
              Slowest loop: 59.42ms; fastest: 0.07ms
              Hiccups: 0, FreeDm: 169, MinFreeDm: 121, MaxWait: 1366776ms
              Bed compensation in use: mesh, comp offset 0.373
              === DDARing ===
              Heater 0 is on, I-accum = 0.1
              Heater 1 is on, I-accum = 0.6
              Segments left: 0
              Stack records: 3 allocated, 0 in use
              Movement lock held by null
              http is idle in state(s) 0
              telnet is idle in state(s) 0
              file is idle in state(s) 0
              serial is idle in state(s) 0
              aux is idle in state(s) 0
              daemon is idle in state(s) 0
              queue is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 25.93ms; fastest: 0.00ms
              HTTP sessions: 1 of 8
              • WiFi -
                Network state is running
                WiFi firmware version 1.23
                WiFi MAC address ec:fa:bc:01:e0:39
                WiFi Vcc 3.32, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 25464
                WiFi IP address 192.168.1.19
                WiFi signal strength -53dBm, reconnections 0, sleep mode modem
                Extruder 0: pos 250.31, ok, measured sens 25.28mm/rev min 94% max 179% over 10057.0mm, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                3:06:28 PMFinished printing file 0:/gcodes/rEX.gcode, print time was 0h 46m
              undefined 1 Reply Last reply 28 Nov 2019, 09:24 Reply Quote 0
                ciaossu
                I just purchased a filament sensor from Filastruder and set it up. My mount is not ideal according to the directions because I do not want to mount the sensor on top of the bondtech extruder that is set up as a direct drive on a Railcore. This would add a lot of moving weight. So the sensor is mounted outside the printer and there is a long ptfe tube between the sensor output and the bondtech. I was able to run 3-4 12 hour prints without issue. Now though the sensor stops and says not enough movement was detected.
                Is there a way to configure the sensor to simply detect any movement over x amount of time and not try to exactly sync the movements to the print? Should I be using the switch and the magnet sensor? I tried opening up the tolerance to work over a wide range but that did not help.
                Settings:
                Duet3D magnetic filament monitor on input 3, enabled, sensitivity 24.70mm/rev, allow 20% to 250%, check every 3.0mm, version 2, measured sensitivity 24.82mm/rev, min 91% max 105% over 160.8mm
                If you need additional information please let me know.
                undefined 1 Reply Last reply 28 Nov 2019, 09:27 Reply Quote 0
                  dc42 administrators @RandyL
                  @RandyL said in Problem with Magnetic Sensor:
                  1. How close to the extruder drive inlet is the filament monitor? It needs to be very close, especially for soft filaments such as TPU. Otherwise, when the extruder retracts filament, the filament will try to bunch up in the space between the extruder inlet and the filament monitor, instead of retracting through the filament monitor.
                  2. A 0.8mm nozzle has four times the filament flow of a 0.4mm nozzle. To get comparable performance from the filament monitor, you should increase the measurement length in proportion. So try 12mm instead of 3mm.
                    dc42 administrators @ciaossu
                    @ciaossu said in Problem with Magnetic Sensor:
                    That is not going to work well, because filament will bunch up in the tube when retraction occurs..
                    You still have the measurement distance set to 3.0mm. Try a larger amount.
                    undefined 1 Reply Last reply 29 Nov 2019, 06:25 Reply Quote 0
                    • tagliaundefined
                      taglia
                      Hi, a quick update from me. Duet replaced my sensor (kudos to @Roland, the swap was quick and flawless, even if I live in Singapore).
                      I have been using the new sensor for several weeks now, and it has saved many prints, and potentially more disastrous situations. The sensor never paused the printer without a valid reason: clogged nozzle, empty spool, and once the spool even fell to the floor.
                      Great tool, highly recommended.
                        T3P3Tony administrators
                        @taglia thanks for the update
                          RandyL @dc42
                          @dc42,
                          Thanks for the advice. I will try increasing the measurement length as you suggest. My sensor is mounted ~20mm above a direct drive extruder and was flexing around a lot. I added a brace which helped a lot but am still having issue. I will try increasing the measurement length as you suggest.
