Struggled for a month with Ender3 Upgrade.
@droftarts ok that took me to a page with 8 things on it which do i download?
@abstraktlighting said in Duetwifi? THIS FRIGGIN BOARD.? CUSTOMER SERVICE?:
DuetWebControl.zip
You're going to need the sys and www contents on your sd card. Without www, there's no DWC. without sys, there's no configuration for the machine.
I'd say to do is either put the contents of your SD card back on the SD card or if you're unsure of what changes you've made. Start fresh with the sys and www folders from here.
The files from the DuetWebControl.zip go into the www folder on your SD card.
You still need a sys folder too,
I would also suggest redoing the config bundle using the instructions here.
If it was previously allowing you to DWC, then you shouldn't have to do any of that "Getting Connected to your Duet"
But, Step 6 and 7 there might help you get the status of the network connection
I'd say restore all the SD card stuff, then boot up the board, connect to it through YAT like you did and send M552. It should report the status of the network connection and then take appropriate action from there.
@abstraktlighting If you still can't access the DWC after refreshing the files, we'll need to see your config.g, as something in that may be stopping it from working. You can get your config.g from YAT by sending M503. Copy and post it here.
@droftarts copy all that . I'll let you know thanks
@droftarts hey one sec
what is ?
@droftarts no config file found m503
what is ?
?Meaning that if you've made so many changes that might affect things that you no longer know what you've done, it's best to start clean and then you know which state it's in.
No config.g found, there's a sys folder on your sd card with a config.g in it?
@blt3dp yes I understand and want to dothat but theres nothing there called config?
@blt3dp theres 8.zip assets
@abstraktlighting that webcntrolfile on sd card in www didnt work to open web control
and theres no file "here" called config -
@abstraktlighting If you want to start again with the SD card, download SD_Card_Contents.zip from https://github.com/T3P3/Duet/tree/master/Duet2/SD Card Contents and decompress that to the SD card.
Everything from DuetWebControl.zip goes into a folder named www on the sd card.
Then there should be another folder named sys, which is where all the files from when you ran the Reprap Firmware Configurator, it should include a config.g
Or you could just start completely over with an empty sd card and put the www and sys folders from Ian's link
@abstraktlighting, can you communicate with your Duet over USB?
@dc42 im good droftarts is helping me
@dc42 Hey Man How you doing? This thing is still crazy I cant get any cionfigs to work they all travel too far . and say the heaters are faulting. I'm going to pull this card and bl touch and put arduino back in or smash it to peices if Icant get it working .Can you look at it Please.Ive spent another 10hrs f'ing with it today. I'm beat. My names Jeff. I went through Pheadreuxs guide twice now,
@dc42 Hey How you doing? This thing is still crazy I cant get any cionfigs to work they all travel too far . and say the heaters are faulting. I'm going to pull this card and bl touch and put arduino back in or smash it to peices if Icant get it working .Can you look at it Please.Ive spent another 10hrs f'ing with it today. I'm beat. My names Jeff. I went through Pheadreuxs guide twice now,
{"board":"duetwifi10","expansion_boards":[],"firmware":2.03,"standalone":true,"nvram":true,"auto_save":{"enabled":true,"save_threshold":10,"resume_threshold":11,"gcodes_to_run":"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"},"display":{"type":0,"encoder_steps":4,"spi_frequency":2000000,"menus":[{"name":"main","value":""}],"images":[]},"geometry":{"type":"cartesian","mins":[0,0,0],"maxes":[230,210,200],"delta_radius":105.6,"homed_height":250,"low_dive_height":false,"max_carriage_travel":260,"print_radius":85,"rod_length":215,"z_min":0},"drives":[{"direction":0,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":80,"instant_dv":15,"max_speed":100,"acceleration":500,"current":800,"driver":0,"driver_v3":"0.0","endstop_pin":"xstop","endstop_type":1,"endstop_location":1},{"direction":0,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":80,"instant_dv":15,"max_speed":100,"acceleration":500,"current":800,"driver":1,"driver_v3":"0.1","endstop_pin":"ystop","endstop_type":1,"endstop_location":1},{"direction":1,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":4000,"instant_dv":0.2,"max_speed":3,"acceleration":20,"current":800,"driver":2,"driver_v3":"0.2","endstop_pin":null,"endstop":null,"endstop_type":0,"endstop_location":1},{"direction":1,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":420,"instant_dv":2,"max_speed":20,"acceleration":250,"current":800,"driver":3,"driver_v3":"0.3"},{"direction":1,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":420,"instant_dv":2,"max_speed":20,"acceleration":250,"current":800,"driver":4,"driver_v3":"0.3"}],"idle":{"used":true,"factor":30,"timeout":30},"homing_speed_fast":30,"homing_speed_slow":6,"travel_speed":100,"z_dive_height":5,"slow_homing":false,"probe":{"type":"unmodulated","recovery_time":0.4,"trigger_height":2.5,"trigger_value":500,"x_offset":0,"y_offset":0,"speed":2,"deploy":false,"points":[],"pwm_channel":3,"pwm_inverted":true,"pwm_pin":null,"input_pin":"zprobe.in","modulation_pin":"zprobe.mod"},"bed_is_nozzle":true,"bed":{"present":true,"use_pid":false,"heater":2},"chamber":{"present":false,"use_pid":false,"heater":2},"heaters":[{"temp_limit":120,"scale_factor":100,"series":4700,"thermistor":100000,"beta":4138,"c":0,"channel":0,"sensor":0,"output_pin":"bedheat","sensor_type":"thermistor","sensor_pin":"bedtemp"},null,{"temp_limit":120,"scale_factor":100,"series":4700,"thermistor":100000,"beta":4138,"a":0.0005717725,"b":0.0002416626,"c":0,"channel":2,"sensor":0,"output_pin":null,"sensor_type":null,"sensor_pin":null}],"num_nozzles":1,"toolchange_wait_for_temperatures":false,"generate_t_code":false,"tools":[{"mix_ratio":[],"number":0,"name":"","extruders":[0],"heaters":[],"fans":[0],"x_offset":0,"y_offset":0,"z_offset":0}],"compensation_x_offset":15,"compensation_y_offset":15,"peripheral_points":3,"halfway_points":3,"calibration_factors":6,"probe_radius":85,"mesh":{"x_min":15,"x_max":215,"y_min":15,"y_max":195,"radius":85,"spacing":20},"home_first":false,"orthogonal":{"compensation":false,"height":50,"deviations":[0,0,0]},"network":{"enabled":true,"mac_address":"","name":"My Printer","password":"","ssid":"","ssid_password":"","dhcp":true,"ip":"192.168.1.20","netmask":"255.255.255.0","gateway":"192.168.1.254","protocols":{"http":true,"ftp":false,"telnet":false}},"fans":[{"name":"","value":0,"inverted":false,"frequency":500,"thermostatic":false,"heaters":[],"trigger_temperature":45,"output_pin":"fan0"},{"name":"","value":100,"inverted":false,"frequency":500,"thermostatic":false,"heaters":[1,0],"trigger_temperature":45,"output_pin":"fan1"},{"name":"","value":100,"inverted":false,"frequency":500,"thermostatic":false,"heaters":[1,0],"trigger_temperature":45,"output_pin":"fan1"}],"custom_settings":""}
i hope you bought that duet used, because V1.0 is an old revision of the board that that is missing some useful features.
also please post the config.g and not the config.json
also when you are going through the guide and dont understand a step or get a different result please ask for help on that specific step. saying that you read the guide twice and its not working does not help us understand where you problems are exacly.
@Veti copy that
