    Struggled for a month with Ender3 Upgrade.
    My Duet controlled machine
    duet wifi upgrade wont print stalls after homing bltouch light goes out
    14
    72
    3.1k
    • blt3dpundefined
      blt3dp @abstraktlighting
      @abstraktlighting said in Duetwifi? THIS FRIGGIN BOARD.? CUSTOMER SERVICE?:
      @droftarts hey one sec
      what is ?
      I'd say to do is either put the contents of your SD card back on the SD card or if you're unsure of what changes you've made. Start fresh with the sys and www folders from here.
      Meaning that if you've made so many changes that might affect things that you no longer know what you've done, it's best to start clean and then you know which state it's in.
      No config.g found, there's a sys folder on your sd card with a config.g in it?
      My 3D Printing YouTube Channel
      Better Living Through 3D Printing
      Follow me on Instagram and Twitter
      Instagram
      Twitter
      abstraktlightingundefined 2 Replies Last reply Reply Quote 0
      • abstraktlightingundefined
        abstraktlighting @blt3dp
        @blt3dp yes I understand and want to dothat but theres nothing there called config?
          @blt3dp theres 8.zip assets
          droftartsundefined blt3dpundefined 2 Replies Last reply Reply Quote 0
            abstraktlighting @abstraktlighting
            @abstraktlighting that webcntrolfile on sd card in www didnt work to open web control
            and theres no file "here" called config
              droftarts administrators @abstraktlighting
              @abstraktlighting If you want to start again with the SD card, download SD_Card_Contents.zip from https://github.com/T3P3/Duet/tree/master/Duet2/SD Card Contents and decompress that to the SD card.
              • blt3dpundefined
                Everything from DuetWebControl.zip goes into a folder named www on the sd card.
                Then there should be another folder named sys, which is where all the files from when you ran the Reprap Firmware Configurator, it should include a config.g
                Or you could just start completely over with an empty sd card and put the www and sys folders from Ian's link
                Instagram
                Twitter
                  dc42 administrators @abstraktlighting
                  @abstraktlighting, can you communicate with your Duet over USB?
                  abstraktlightingundefined 3 Replies Last reply Reply Quote 0
                    abstraktlighting @dc42
                    @dc42 im good droftarts is helping me
                      @dc42 Hey Man How you doing? This thing is still crazy I cant get any cionfigs to work they all travel too far . and say the heaters are faulting. I'm going to pull this card and bl touch and put arduino back in or smash it to peices if Icant get it working .Can you look at it Please.Ive spent another 10hrs f'ing with it today. I'm beat. My names Jeff. I went through Pheadreuxs guide twice now,
                        @dc42 Hey How you doing? This thing is still crazy I cant get any cionfigs to work they all travel too far . and say the heaters are faulting. I'm going to pull this card and bl touch and put arduino back in or smash it to peices if Icant get it working .Can you look at it Please.Ive spent another 10hrs f'ing with it today. I'm beat. My names Jeff. I went through Pheadreuxs guide twice now,
                          abstraktlighting
                          {"board":"duetwifi10","expansion_boards":[],"firmware":2.03,"standalone":true,"nvram":true,"auto_save":{"enabled":true,"save_threshold":10,"resume_threshold":11,"gcodes_to_run":"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"},"display":{"type":0,"encoder_steps":4,"spi_frequency":2000000,"menus":[{"name":"main","value":""}],"images":[]},"geometry":{"type":"cartesian","mins":[0,0,0],"maxes":[230,210,200],"delta_radius":105.6,"homed_height":250,"low_dive_height":false,"max_carriage_travel":260,"print_radius":85,"rod_length":215,"z_min":0},"drives":[{"direction":0,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":80,"instant_dv":15,"max_speed":100,"acceleration":500,"current":800,"driver":0,"driver_v3":"0.0","endstop_pin":"xstop","endstop_type":1,"endstop_location":1},{"direction":0,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":80,"instant_dv":15,"max_speed":100,"acceleration":500,"current":800,"driver":1,"driver_v3":"0.1","endstop_pin":"ystop","endstop_type":1,"endstop_location":1},{"direction":1,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":4000,"instant_dv":0.2,"max_speed":3,"acceleration":20,"current":800,"driver":2,"driver_v3":"0.2","endstop_pin":null,"endstop":null,"endstop_type":0,"endstop_location":1},{"direction":1,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":420,"instant_dv":2,"max_speed":20,"acceleration":250,"current":800,"driver":3,"driver_v3":"0.3"},{"direction":1,"microstepping":16,"microstepping_interpolation":true,"steps_per_mm":420,"instant_dv":2,"max_speed":20,"acceleration":250,"current":800,"driver":4,"driver_v3":"0.3"}],"idle":{"used":true,"factor":30,"timeout":30},"homing_speed_fast":30,"homing_speed_slow":6,"travel_speed":100,"z_dive_height":5,"slow_homing":false,"probe":{"type":"unmodulated","recovery_time":0.4,"trigger_height":2.5,"trigger_value":500,"x_offset":0,"y_offset":0,"speed":2,"deploy":false,"points":[],"pwm_channel":3,"pwm_inverted":true,"pwm_pin":null,"input_pin":"zprobe.in","modulation_pin":"zprobe.mod"},"bed_is_nozzle":true,"bed":{"present":true,"use_pid":false,"heater":2},"chamber":{"present":false,"use_pid":false,"heater":2},"heaters":[{"temp_limit":120,"scale_factor":100,"series":4700,"thermistor":100000,"beta":4138,"c":0,"channel":0,"sensor":0,"output_pin":"bedheat","sensor_type":"thermistor","sensor_pin":"bedtemp"},null,{"temp_limit":120,"scale_factor":100,"series":4700,"thermistor":100000,"beta":4138,"a":0.0005717725,"b":0.0002416626,"c":0,"channel":2,"sensor":0,"output_pin":null,"sensor_type":null,"sensor_pin":null}],"num_nozzles":1,"toolchange_wait_for_temperatures":false,"generate_t_code":false,"tools":[{"mix_ratio":[],"number":0,"name":"","extruders":[0],"heaters":[],"fans":[0],"x_offset":0,"y_offset":0,"z_offset":0}],"compensation_x_offset":15,"compensation_y_offset":15,"peripheral_points":3,"halfway_points":3,"calibration_factors":6,"probe_radius":85,"mesh":{"x_min":15,"x_max":215,"y_min":15,"y_max":195,"radius":85,"spacing":20},"home_first":false,"orthogonal":{"compensation":false,"height":50,"deviations":[0,0,0]},"network":{"enabled":true,"mac_address":"","name":"My Printer","password":"","ssid":"","ssid_password":"","dhcp":true,"ip":"192.168.1.20","netmask":"255.255.255.0","gateway":"192.168.1.254","protocols":{"http":true,"ftp":false,"telnet":false}},"fans":[{"name":"","value":0,"inverted":false,"frequency":500,"thermostatic":false,"heaters":[],"trigger_temperature":45,"output_pin":"fan0"},{"name":"","value":100,"inverted":false,"frequency":500,"thermostatic":false,"heaters":[1,0],"trigger_temperature":45,"output_pin":"fan1"},{"name":"","value":100,"inverted":false,"frequency":500,"thermostatic":false,"heaters":[1,0],"trigger_temperature":45,"output_pin":"fan1"}],"custom_settings":""}
                          • Vetiundefined
                            Veti
                            i hope you bought that duet used, because V1.0 is an old revision of the board that that is missing some useful features.
                            also please post the config.g and not the config.json
                            also when you are going through the guide and dont understand a step or get a different result please ask for help on that specific step. saying that you read the guide twice and its not working does not help us understand where you problems are exacly.
                              abstraktlighting @Veti
                              @Veti copy that
                                @Veti I'dnever buy anything from them again a guy helped me some today but you cant even get simple questions answered in a timely fashion. It's a terrible business model.,
                                • jens55undefined
                                  jens55
                                  I think I would like to give some cudos to all the people bending over backwards to help abstracktlighting. You are showing an amazing amount of patience !
                                    abstraktlighting @infiniteloop
                                    @infiniteloop Hi how you doing? I am almost good except for my z. the bracket I made for my bl touch isnt holding it in the right spot. whould you happen to know how I can get it to let me not use it and manually set Z so i could print a bracjket?
                                      You can edit config.g and find the line with M558 P9 for the BLTouch. You can put a ; in front of that line to comment it out. Then below that put a line that says M558 P0. That will let you use a jog dialogue box to move the Z axis down until the nozzle touchs the bed when you try to home your Z axis.
                                        abstraktlighting @Phaedrux
                                        @Phaedrux ALRIGHT GREAT THANKS MAN i REALLY APPRECIATE IT!!!!
                                        • infiniteloopundefined
                                          infiniteloop @abstraktlighting
                                          @abstraktlighting
                                          Hi how you doing?
                                          I’m fine, but maybe you should cool down a bit: 3D printing is less a matter of mood than a challenge of logical thinking. It doesn’t help to be angry with your printer or with the community…
                                          This said, you can always resort to handcrafted bed levelling. Just move your nozzle to every X/Y coordinate you want to probe, jog Z down until a sheet of paper barely fits between nozzle and bed, adjust the lead screws accordingly…
                                          Best is to follow this guide, it contains instructions dedicated to the Ender 3 which you happen to own.
                                          After you’re done with all corners of the bed and the results are consistent, enter G10 L20 P0 Z0 to define the current nozzle height (of tool 0) as Z=0. Then: print.
                                          abstraktlightingundefined 1 Reply Last reply Reply Quote 0
                                            @infiniteloop Thanks for your printer advice I appreciate THAT. As for your other advice I am thankful for the community members that helped or tried as I stated. I dont need you to advise me on what you wrongly perceived as anger, just as I wont advise you on what I may wrongly perceive as arrogance. I merely stated that I think Duet would be alot more user friendly if they had more direct clear and concise paths and procedures for trouble shooting that can be accessed without having to navigate through personalities to retrieve required assistance in a timely non-judgemental manner. I stand by my assertion that it's not a beneficial aspect for a business model. Thanks again for sticking to printer advising and steering away from psycho analyzing.
