    Issues setting up duet wifi with dual x axis motors and endstops
    59
    3.3k
      droftarts administrators
      Update your DWC version, you’re using a very old one, may not be compatible, and give wrong info. It may assume an order for the motors that is incorrect. Use the latest version (2.04 or 1.22.6) from the firmware release DuetWebControl-SD-2.04.zip file or https://github.com/chrishamm/DuetWebControl/releases
      This won’t affect the homing behaviour, but should give you the correct info!
      It shouldn’t make any difference, but can you try changing the order of your M584 command? To M584 X0:4 Y1 Z2 U4 E3
      Have you tried homing the U axis on its own? Try typing into console:
      M584 X0 U4 P4
      G91
      G1 H1 U-800 F3000
      G90
      • wingtipundefined
        wingtip
        well according the link you first gave me it said the zip file i downloaded should update everything but i will go looking for the webcontrol update real quick. However when i was testing the movements and endstops that was using the paneldue.
        Highly modified FT5 R1, ATX supply, mosfet w/silicone heat pad, bmg ext, TMC2600 drivers, and my custom quad z mod with 4 lead screws and custom cut new upper panels and bed, and using the dual z endstop mod. New project is 800x500x500z printer.
        • wingtipundefined
          wingtip
          i just tried the commands you suggested and still the same thing, the u starts to head to home and endstop is ignored the state says its triggered when its not suppose to be, then when i manually trigger it , it says triggered=no So you can see it working its just backwards . but its setup just the same as the x1 as both motors rotate in the same direction etc so the direction is correct and endstop settings should be the same since the x1 works perfect. Right?
          the updated webcontrol is certainly different.. i dont like how it lessened the travel buttons from the +100 to now max travel button is +50.
            Phaedrux Moderator @wingtip
            @wingtip said in Issues setting up duet wifi with dual x axis motors and endstops:
            You can right click on the buttons and redefine them.
            wingtipundefined 1 Reply Last reply Reply Quote 0
            • wingtipundefined
              wingtip @Phaedrux
              @Phaedrux Nice! told you guys im new to reprap and duets but im loving it so far despite the issues im having lol
                Is your PanelDue firmware up to date too? https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
                Is the wiring, or the endstop, different on the U axis to the X axis? Because that sounds like it’s inverted, which it isn’t in config.g
                In the Fans section of your config.g, the comments of the two M106 commands seemed to had a return put in, so the words “turned off” and “turned on” appear to be on new lines. Lines must start with a Gcode or a comment mark (semi colon). I doubt this will change anything, but good to tidy it up!
                I am running out of ideas as to why this isn’t working. My only other suggestion would be to swap the U axis with the extruder, so move the U motor to E0, and the U endstop to E0 Endstop pins, and test if it works there.
                • wingtipundefined
                  wingtip @droftarts
                  @droftarts
                  the paneldue is 1.21.4
                  • wingtipundefined
                    wingtip
                    well im done... trying to update this panel due as suggested and its been a headache and now im to mad to continue for tonight... first off the enclosure i printed from thingiverse wasnt designed with updating firmware in mind and would be to much work to disassemble.... the designer left plenty of room for the other connectors but no way to get a micro usb plug to the board.. i had to sand down my plug to skin and bones to fit in the tiny slot he left for access... then when i followed the instructions on the web link provided after downloading bossa, my panel due now only displays a black screen and its not recognising it in windows so i cant get the port to use bossa to re upload the firmware....
                    ill see you guys in the morning
                      dc42 administrators @wingtip
                      Ok... im getting frustrated here but i think we're close. So right now here are my versions now.
                      Firmware Version: 2.04 (2019-11-01b1)
                      WiFi Server Version: 1.23
                      Web Interface Version: 1.21.2-dc42
                      I also removed the Endstop line for E as mentioned. I verified the x2 endstop is in fact working and triggering when viewing the machine properties window. but im still not able to stop the x2 motor/aka U drive thats plugged into the E1 port with the enstop thats plugged into the E1 enstop port.
                      the green circle shows the x1 motor/vertical post. the motor is currently at mid travel OFF the endstop and is displaying the correct status. This motor also stops correctly when it does get to the endstop
                      the red circle shows the x2 motor/vertical post that is plugged into the E1 motor port which is remapped to U4. The endstop is plugged into the E1 port. the motor is currently at mid travel OFF the endstop and is displaying the wrong status but does trigger when manually activated. the problem is it still does not STOP the x2 motor/vertical post aka U4. the motor still just ignores this endstop
                      the blue circle has me really confused... why is my E0, aka extruder showing a min of 0 and a max of 800 while the E1, aka the x2 motor only shows n/a despite clearly being defined in the config to be min 0 and max 800???????? uggggg im brain fried
                      To see the U axis endstop properly, you need to make the U axis visible temporarily, by sending M584 P4.
                      • wingtipundefined
                        wingtip
                        good morning gents..... so after a nights rest and calming down i found another cable this morning and tried it and bam, it recognised it and gave me the port i needed and now have my panel due working again and updated to now 1.23.2.
                        so i went to try to home again and same issues... so in the new web control when editing it has a g code reference where before i was using some random web page... when using the reference from the webcontrol it seems to have some more updated info and i noticed this section and thought id give it a try
                        M574 - RepRapFirmware 3
                        Parameters
                        Xnnn Position of X endstop: 0 = none, 1 = low end, 2 = high end.
                        Ynnn Position of Y endstop: 0 = none, 1 = low end, 2 = high end.
                        Znnn Position of Z endstop: 0 = none, 1 = low end, 2 = high end.
                        P"pin_name" Defines the pin name(s) that the endstop(s) for the specified axis are connected to. Needed when S=0 or S=1.
                        Snnn Endstop type: 0 = active low endstop input, 1 = active high endstop input, 2 = Z probe (when used to home an axis other than Z), 3 = single motor load detection, 4 = multiple motor load detection (see Notes).
                        Order dependency
                        This command must be later in config.g than the M584 command that creates additional axes, or axes that have multiple motors and endstops.
                        Usage
                        The M574 command has been updated to allow for more flexibility. This includes supporting axes defined with multiple motors and multiple endstops (one per motor), use of non-default endstop inputs, and re-assigning endstop inputs.
                        Notes
                        Use a separate M574 command for each axis.
                        New parameter P gives the pin name(s) for the endstop(s) for the specified axis. If the number of pins matches the number of motors assigned to that axis, motors will be stopped individually when their endstop switches trigger.
                        New endstop type S4 means use motor stall detection (like S3) but if there are multiple motors, stop each one individually as it stalls. S3 means use motor stall detection but as in RRF 2: stop all relevant motors when the first one stalls.
                        Example
                        Old RRF_2.x code:
                        M574 X1 Y1 Z1 U2 S1 ; active high endstop switches, XYZ at min, U at max
                        New RRF_3 code:
                        M574 X1 S1 P"xstop" ; X min active high endstop switch
                        M574 Y1 S1 P"ystop" ; Y min active high endstop switch
                        M574 Z1 S1 P"zstop" ; Z min active high endstop switch
                        M574 U2 S1 P"e0stop" ; U max active high endstop switch
                        To use two Z motors using independent homing switches, declare two Z motors in M584, then declare two pins for Z endstops in a single M574 command. Example
                        M584 X0 Y1 Z2:3 E4
                        M574 Z1 S1 P"io2.in+io3.in" ; Z axis with two motors, individual min endstops, active high
                        The order of endstop switch pin names in M574 must match the order of Z motor driver numbers in M584. When homing Z, RRF_3 homes the motors of the axis at the same time, independently to their defined endstops.
                        so i briefly experimented with this in hopes this would solve my issues but still nothing. And im still noticing the 2nd endstop is still triggered on the wrong end no matter which way you configure it... i think i need to follow the advice to swap to a different port instead of E1/drive 4 but im off to work now and i will do some more suffering after work lol....
                          droftarts administrators @wingtip
                          Sorry you're having difficulty. Probably would have been better to modify the enclosure rather than the PanelDue, though. It sounds like you have already deleted the firmware, and the USB is not making enough of a connection on whatever remains of the USB connector. You could solder a cut off USB cable's wires direct to the PCB, on the back where the pins are accessible. I'm checking to see if there's any other way to program the PanelDue apart from via USB (edit: fixed!). Have you got a Thingiverse link to the enclosure? Worth mentioning the problem in the comments.
                          I'm going to try and recreate your issue with the X homing today with a really simple set up (2 motors, 2 endstops and your config and homing files). I'll let you know how I get on.
                            Great!
                            You've probably been looking at the general reprap Gcode page https://reprap.org/wiki/G-code, which may not have the latest info on it, and has multiple versions of gcodes for how each different firmware interprets the commands! Best to use the Duet-specific one we curate: https://duet3d.dozuki.com/Wiki/Gcode. There are plenty of links in the documentation to our one, and in my posts where I've referenced gcodes!
                            Unless you've updated your Duet firmware again, you are NOT using RRF3, you're using RRF2 v2.04. Make sure you use the correct section! https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_RepRapFirmware_2_x_and_earlier
                            Okay! I'll test your setup and see what I get.
                            • wingtipundefined
                              wingtip @droftarts
                              @droftarts
                              Ya I realized it was a different version but I was desperate and can easily change back the few lines I edited.
                              I look forward to your results if you use the same ports/drives and my config.
                                @wingtip
                                I've had some problems with this, but the outcome seems to be to plug the U endstop into E0! This works for me, even though the motor is plugged into motor drive E1. I'll check with @dc42 why this might be! On the whole, I'd just move the whole U axis to motor driver 3 (E0).
                                Edit: Tested, set U to driver 3 (E0) U endstop connected to E0_ENDSTOP works. In config.g change to:
                                M584 X0:3 Y1 Z2 U3 E4 P3
                                M569 P3 S0
                                M569 P4 S1
                                Also change U4 to U3 in homing files.
                                I think your endstops may be wired Normally Open (NO) rather than Normally Closed (NC). It says HERE that you should use the Normally Closed pins (the outer two, the three pins usually being G (Ground), NO (Normally Open) and NC (Normally Closed)) of your microswitch. It goes on to say:
                                ... set the signal polarity to active high (S1) in the M574 command
                                eg yours should be:
                                M574 X1 Y1 U1 S1 ; position low, active low
                                This should mean that:
                                • If an endstop is not connected, the LED next to the axis motor connector will be off, and 'Triggered' will be 'Yes'
                                • If an endstop is connected and not triggered, the LED next to the axis motor connector will be lit, and 'Triggered' will be 'No'
                                • If an endstop is connected and triggered, the LED next to the axis motor connector will be off, and 'Triggered' will be 'Yes'
                                However, your config.g has the endstops triggering active low (M574 S0), and this seems to be shown in the endstop response. I have to invert mine with S1 to get the right response. The main thing is that all used endstops should report 'No' when not triggered, and 'Yes' when triggered!
                                  I confirm, endstop switches are allocated to axes independently of stepper drivers. In RRF2 the endstop switch allocation is automatic and can't be changed. Your U axis will be allocated the first unassigned endstop, which is E0. If you created another axis such as V, that will be assigned to E1.
                                  BTW, RRF3 handles multiple endstops on an axis automatically, without having to create additional axes.
                                  • wingtipundefined
                                    wingtip @dc42
                                    @dc42 soooooo are you saying for us mere mortals that i can leave the motor in its current connection in the E1/dr 4 slot but i just need to move the endstop to the E0 endstop slot? or should i move both?
                                    • wingtipundefined
                                      wingtip @droftarts
                                      @droftarts the panel due enclosure i printed is this one
                                      https://www.thingiverse.com/thing:3101323
                                        Yes, you can leave the motor on E1/dr 4 and move the endstop to E0. Like I said in my earlier post!
                                        Also, when I was running your config.g, I realised you must have leadscrews on your X axis, with the steps per mm of 400. However, at the speeds the axis was hitting during jogging (100mm at F6000), I got motor phase disconnection warnings, which can happen if the motor is turning faster than it can cope with, and will lead to missed steps. I was using some standard NEMA17 motors. If you are, I'd set your X axis speed limit a bit lower.
                                        • wingtipundefined
                                          wingtip
                                          SUCCESS!!!!! WOOHOOO..... 😂
                                          finally.... everything as far as the x axis is concerned is working as it should now. Thank you so much everyone. now i feel safe enough to install the cross beams to physically connect the two vertical posts.
                                          I did get the errors you were mentioning as well... i can slow them down or up the current i suppose but i already had them to 1000 mah if i recall... what would you suggest for a max for nema 17s on lead screws... with two motors on the x it should be able to move x around without breaking a sweat... lol
                                          Phaedruxundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                            It's recommended to target 70-85% of max rated motor current. You can go as high as 100% of rated but the motors will get quite hot.
