    Duet 2 wifi Mesh compensation
    Firmware installation
    480
      droftarts administrators
      @Runar What firmware version are you running? Send M115 in the DWC console and post response.
      You shouldn't need the second G29 S1; G29 on it's own will probe the bed, save the height map in a file on the SD card, and activate bed compensation. You can check this by sending M408 S3, which shows the compensation in use in the report:
      M408 S3
      {"status":"P","coords":{"axesHomed":[1,1,1],"wpl":1,"xyz":[-3.868,-17.534,10.900],"machine":[-13.108,-27.845,10.850],"extr":[556.4]},"speeds":{"requested":15.0,"top":15.0},"currentTool":0,"params":{"atxPower":0,"fanPercent":[100,100,0,0,0,0,0,0,0],"fanNames":["","","","","","","","",""],"speedFactor":100.0,"extrFactors":[100.0],"babystep":-0.050},"sensors":{"probeValue":0,"fanRPM":0},"temps":{"bed":{"current":60.4,"active":60.0,"standby":0.0,"state":2,"heater":0},"current":[60.4,184.9,2000.0,2000.0,2000.0,2000.0,2000.0,2000.0],"state":[2,2,0,0,0,0,0,0],"names":["","","","","","","",""],"tools":{"active":[[185.0]],"standby":[[190.0]]},"extra":[{"name":"*MCU","temp":32.7}]},"time":7606.0,"coldExtrudeTemp":160.0,"coldRetractTemp":90.0,"compensation":"None","controllableFans":1,"tempLimit":290.0,"endstops":4088,"firmwareName":"RepRapFirmware for Duet 2 WiFi/Ethernet","geometry":"cartesian","axes":3,"totalAxes":3,"axisNames":"XYZ","volumes":2,"mountedVolumes":1,"name":"CartesIan","probe":{"threshold":500,"height":1.25,"type":1},"tools":[{"number":0,"heaters":[1],"drives":[0],"axisMap":[[0],[1]],"fans":1,"filament":"","offsets":[0.00,0.00,0.00]}],"mcutemp":{"min":13.3,"cur":32.7,"max":33.1},"vin":{"min":11.4,"cur":12.0,"max":12.4}}
      You can send M408 S3 while printing to check (I just did!)
      • Runarundefined
        Runar
        Okay, thanks I try when I get home. Stupid question though, you say "save the height map in a file on the SD card" I do not use any SD card my heightmap.csv is in folder / sys. Is there a difference?
        My Firmware 2,04
        • aidarundefined
          aidar
          Ian means G29 saves the height map in file on SD card. And yes, you have SD card in Duet, the / sys folder is on it. Without SD card Duet will not work, assuming its Duet2 (wifi, ethernet or maestro, doesnt matter)
          • Runarundefined
            Runar
            @aidar said in Duet 2 wifi Mesh compensation:
            Thank you all, now I understand. I will check everything when Iยดm at home.
            /Runar
              Phaedrux Moderator @droftarts
              @droftarts said in Duet 2 wifi Mesh compensation:
              M408 S3
              You can also see if compensation is active in the results of M122
              • gtj0undefined
                gtj0
                Make sure your Z "jerk" (M566) isn't set too low, if it is, the motors may not move at all.
                  Phaedrux Moderator @gtj0
                  @gtj0 said in Duet 2 wifi Mesh compensation:
                  If the Z zerk is too low the Z motors will still move, but the X and Y may pause to give the Z axis time to finish the move, resulting in jerky movement.
                  • gtj0undefined
                    gtj0 @Phaedrux
                    @Phaedrux said in Duet 2 wifi Mesh compensation:
                    You know, I thought I was speaking from experience...
                    https://forum.duet3d.com/topic/13423/can-anyone-else-confirm-these-z-behaviors-with-3-0rc1?_=1576942676499
                    But I'll be damned if I can replicate my findings now. ๐Ÿ˜ž
                      @gtj0 I can't speak to any variation between 2.x behaviour and 3.x behaviour.
                      • gtj0undefined
                        gtj0 @Phaedrux
                        Thanks for confirming my worst nightmare... it's just me. ๐Ÿ™‚
                        • Grahamundefined
                          Graham
                          Used this to solve my issue with my Predator upgrade. Set Z jerk to 1500 and poof, problem solved.
