Constant heat faults with my delta
829
    Quadcells
    Culd someone help me with this. This seems to happen every time now :
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04 running on Duet WiFi 1.02 or later
    Board ID: 08DGM-95BLL-N6PSS-6J9F8-3S86T-91T7L
    Used output buffers: 3 of 24 (11 max)
    Static ram: 25680
    Dynamic ram: 92228 of which 380 recycled
    Exception stack ram used: 484
    Never used ram: 12300
    Tasks: NETWORK(ready,628) HEAT(blocked,808) MAIN(running,348) IDLE(ready,200)
    Owned mutexes:
    Last reset 24:19:26 ago, cause: software
    Last software reset at 2019-12-21 11:35, reason: User, spinning module GCodes, available RAM 12328 bytes (slot 1)
    Error status: 8
    Free file entries: 10
    SD card longest block write time: 74.1ms, max retries 0
    MCU temperature: min 31.0, current 37.4, max 46.2
    Supply voltage: min 24.0, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 0: standstill, SG min/max 0/1023
    Driver 1: standstill, SG min/max 0/1023
    Driver 2: standstill, SG min/max 0/1023
    Driver 3: standstill, SG min/max 0/1023
    Driver 4: standstill, SG min/max 0/1023
    Date/time: 2019-12-22 11:55:11
    Slowest loop: 70.53ms; fastest: 0.06ms
    Hiccups: 26, FreeDm: 160, MinFreeDm: 50, MaxWait: 42013005ms
    === DDARing ===
    Heater 0 is on, I-accum = 0.2
    Heater 1 is on, I-accum = 0.7
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 129.72ms; fastest: 0.00ms
    HTTP sessions: 1 of 8
    • WiFi -
      Network state is running
      WiFi firmware version 1.23
      WiFi MAC address a0:20:a6:2f:c2:a2
      WiFi Vcc 3.34, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 24120
      WiFi IP address 192.168.39.146
      WiFi signal strength -45dBm, reconnections 0, sleep mode modem
    /quadcells
    undefined 1 Reply Last reply 23 Dec 2019, 10:37 Reply Quote 0
      Quadcells @Quadcells
      @Quadcells here is my tuned results:
      M307 H1
      Heater 1 model: gain 378.5, time constant 248.3, dead time 2.7, max PWM 1.00, calibration voltage 24.2, mode PID, inverted no, frequency default
      Computed PID parameters for setpoint change: P43.4, I1.675, D82.0
      Computed PID parameters for load change: P43.
      /quadcells
      undefined 1 Reply Last reply 23 Dec 2019, 10:44 Reply Quote 0
        Quadcells
        I also have a silicone sock on the hotend block which id s E3D plated copper block with a Genuine E3D High Precision Heater Cartridge - 24V-30W . have the same setup on my Railcore without any heat faults.
        /quadcells
          Veti @Quadcells
          @Quadcells said in Constant heat faults with my delta:
          M307 H1
          did you actually save the results?
          undefined 1 Reply Last reply 23 Dec 2019, 11:23 Reply Quote 0
            Quadcells @Veti
            @Veti M500
            /quadcells
              Is there an M501 at the end of config.g to load them at startup?
              undefined 1 Reply Last reply 23 Dec 2019, 18:47 Reply Quote 0
                Quadcells @Phaedrux
                @Phaedrux Yes I have M501 at the bottom of my config.g code. and it is not commented out.
                /quadcells
                  What is the exact heater fault error message?
                  What does the temp graph look like?
                  undefined 1 Reply Last reply 24 Dec 2019, 15:20 Reply Quote 0
                    Quadcells
                    after constant re-tuning and and just trying to run up the temp with no luck, I re checked the wire and they were fine. I checked the heater with my multi-meter and I was getting a erroneous readings so I replaced the E3D High Precision heater with a E3d 40 watt heater cartridge, re-ran the heater tune and M500. so far all is well. Oh I also ran the temp up to 270 to seal the nozzle.
                    /quadcells
                      Quadcells
                      Spoke to soon, Happen again.
                      M122
                      Used output buffers: 3 of 24 (10 max)
                      Static ram: 25680
                      Dynamic ram: 92228 of which 900 recycled
                      Exception stack ram used: 476
                      Never used ram: 11788
                      Tasks: NETWORK(ready,676) HEAT(blocked,800) MAIN(running,348) IDLE(ready,200)
                      Owned mutexes:
                      Last reset 06:01:05 ago, cause: power up
                      Error status: 8
                      SD card longest block write time: 3.4ms, max retries 0
                      MCU temperature: min 13.7, current 32.8, max 45.7
                      Supply voltage: min 24.1, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                      Driver 4: standstill, SG min/max 0/278
                      Date/time: 2019-12-24 09:54:30
                      Slowest loop: 52.55ms; fastest: 0.06ms
                      Hiccups: 9, FreeDm: 160, MinFreeDm: 55, MaxWait: 3280877ms
                      === DDARing ===
                      Heater 0 is on, I-accum = 0.1
                      Heater 1 is on, I-accum = 0.0
                      Segments left: 0
                      === Network ===
                      Slowest loop: 15.53ms; fastest: 0.00ms
                      • WiFi -
                        WiFi flash size 4194304, free heap 25824
                        WiFi signal strength -49dBm, reconnections 0, sleep mode modem
                      /quadcells
                        Quadcells
                        can I temperately stop this faults
                        /quadcells
                          Veti @Phaedrux
                          you never answered those questions.
                          undefined 1 Reply Last reply 24 Dec 2019, 15:56 Reply Quote 0
                            Quadcells @Veti
                            /quadcells
                            undefined 1 Reply Last reply 24 Dec 2019, 16:52 Reply Quote 0
                              deckingman @Quadcells
                              @Quadcells That looks all the world like a genuine heater fault. If you've changed the heater cartridge then it can only be the wiring - possibly a bad crimp which makes or breaks connection as the head moves around. Unless you have a powerful part cooling fan which is on and blowing over the nozzle.
                              undefined 1 Reply Last reply 24 Dec 2019, 17:11 Reply Quote 0
                                Quadcells @deckingman
                                @deckingman Thanks, I'll take a look at the connections on the effector 6 pin connector.
                                /quadcells
                                  Quadcells
                                  Thanks again, found a bad crimp, but took such time making good crimps, but I guess removing the plug a few times must of weaked it. So I am in the process of re- crimping all 6 crimps and will report back when working.
                                  Thanks again.
                                  /quadcells
                                  /quadcells
                                    Veti
                                    what tool are you using for the crimping? the tool makes all the difference.
                                    undefined 1 Reply Last reply 24 Dec 2019, 19:31 Reply Quote 0
                                      Quadcells @Veti
                                      @Veti yes, I know been thru a few PA-20
                                      /quadcells
                                      undefined 1 Reply Last reply 24 Dec 2019, 20:28 Reply Quote 0
                                        @Quadcells ....and for info, I use a pair of curved, needle nosed pliers as a crimping tool. Have done ever since I bought my first RepRapPro Mendel printer which came as a kit with made up leads, most of which had bad crimps that I had to repair.
                                        I recently changed from Duet 2 to Duet 3 and had to completely re-wire all 7 axes, 6 extruders (so 13 off 4 wire steppers) plus numerous end stops, heaters, fans, thermistors, lights etc using an assortment of JST and Molex crimps. All done with my trusty curved needle nosed pliers. It's been running for about 5 months, and hundreds of hours and not one single bad connection. 😈
                                        undefined 1 Reply Last reply 24 Dec 2019, 21:28 Reply Quote 0
                                          @deckingman this has been my first bad crimp since using this tool. Built my entire Railcore II 300ZL without any problems. but it only takes one.
                                          Thanks all.
                                          /quadcells
                                          7 out of 21
