    Conditional GCode and object model variables
    Gcode meta commands
    32
    66
    10.4k
    • JuKuundefined
      JuKu
      For me the most useful, by far, would be something that I can set myself: Set object value to something, use the value later. I write the software that sends G code to my machine myself, so I’d be happy with something simple, like
      “var1 = xx.xx” and later use “G0 X%var1%”.
      Perhaps more generally useful would be a way to set a value from a get command or a previously set value. Examples:
      varX = M114 X // set varX to current X position
      BedT = M140 S? // set BedT value to whatever was previously set by M140 command
        A Former User
        While I don't have the whole plan ready to go I'd be most interested in functions that would enable me to probe the work piece in (CNC mode)
        Basic trig like you mentioned, tool diameters (either as user defined variables like JuKu mentioned or as part of the tool definition). And for user interaction attaching input pins to user prompts, with optional timeouts and default for M291. Input (and output) pin state instead of M582.
        Looking forward to experiment with this!
          A Former User @dc42
          @dc42 said in Conditional GCode and object model variables:
          BTW in case anyone is wondering why it's taken a while: https://wordpress.com/post/miscsolutions.wordpress.com/3287
          took me to a login page. presumably this is the one? https://miscsolutions.wordpress.com/2019/12/27/using-exceptions-in-c-embedded-software/
          interesting read. thanks for sharing! (lots more to read as well i see, good stuff
            A Former User @dc42
            I hope you do know that gcc/g++ exceptions are not "really" thread-safe. Never used exceptions on embedded systems so can't confirm how it behaves on ARM but since you are using RTOS on the RRF3 you might wanna be careful 🙂
            As variables go, no idea, never used variables in G-Code, no clue what I'd use it for but I'm sure when I see how others are using it some ideas will be born 😄
            • timcurtis67undefined
              timcurtis67 @dc42
              @dc42 Math functions and the ability to store coordinates in temporary variables is what I am looking for. Also yes to the sin, cos, tan, sqrt, abs. It would be handy to have.
              Example of center find on X axis,
              Storing x axis location stop point in each direction. (H1 and H2).
              Then subtracting location 1 from location 2. (H3=H1-H2).
              Dividing the result in half. (H4=H3/2)
              Adding the new result to location 1. (H5 =H4+H1)
              Move to new location G1(H1).
              At some point when the center location is found the XYZ offset can then be saved to G10 for the tool with an M500.
              The "H" can of course be whatever name you are planning to use. In the Fanuc controls the variables are stored in locations with a "#". So I can call up a value to move to like this, G1 X12.125 Y#2265 F30.0. What ever is stored in 2265 gets transferred into Y.
              Not sure if you are planning to follow a GCode standard or not.
                A Former User
                Perhaps it’s time for a library build in between newlib and newlib-nano
                I have seen number of these, they are pain to maintain and usually never get updated/patched ... actually now when I think about it, I don't think I ever seen one revisited after initially created for the project ... creating some "standard" newlib-milli and/or newlib-micro would probbly get traction if one is to dedicate one's time to maintain it...
                • OwenDundefined
                  OwenD
                  Whilst I don't have anything specific in mind, I'd think that some type of switch/case function would be handy for many of the intended uses.
                    deckingman
                    I swap between multiple mixing hot ends and have a number of configuration files to suit. I also use pre and post print macros rather than using the slicer start and end gcode. But if I use the wrong macro, I get errors setting temperatures for non-existant tools. So it would be great if I could have something like "If tool n exists, G10 Pn Snnn Rnnn". Then I'd only need one macro per filament rather than multiple macros to suit the number of tools defined in config.g as well as filament types.
                    I'd also like to be able to run a purge macro depending on the time that a filament has been held at print temperature. So when printing PLA which will hydrolyse over time, when changing tools (filaments) a purge macro would only run if the time since the new filament was last used was greater than a predefined amount of time.
                      @smece said in Conditional GCode and object model variables:
                      Interesting, I wasn't aware of that. Are you sure? Now that C++ supports threads natively, that seems odd. The implication is that gcc uses a static area of memory to do the stack unwinding. Anyway, it won't matter because only the GCode parsing part of RRF uses exceptions, and only one task calls that code.
                      • Danalundefined
                        Danal
                        • Everything reported in an M408.
                        • Time (ticks? ).
                        • User (dynamic)
                        • EVERY command that sets anything, perhaps as a %command% to make it easy to remember.
                        The above probably covers this: Everything that has a position. The 'control point' Work coordinate systems, every kind of offset like tool offset, cutter offset, and so forth. Everything that has a position or offset.
                          What I am actually asking for is the most useful things to include in the object model, so that I can do a beta release that is useful to some people. If I wait until I have implemented everything that I plan to include, it will be weeks or even months before the beta release.
                          Rievundefined 1 Reply Last reply Reply Quote 0
                            jay_s_uk
                            The most useful thing for me would being able to detect a voltage on an input to identify which tool is fitted.
                            E.g. tool 1 is 1V, tool 2 is 2V and so on.
                            Then the machine would be aware of what tool is fitted and apply offsets accordingly etc.
                            • littlehobbyshopundefined
                              littlehobbyshop
                              • Currently selected filament (Similar uses to currently selected tool)
                              • min(), max(), ave() functions. Could be used universally. Like with G29 if your initial suggestion returned a list (max deviation) rather than a specific function alone for G29.
                              BLV MGN Cube w/Hemera, K8200, Sunlu S8
                              • mrehorstdmdundefined
                                mrehorstdmd
                                I use a Duet wifi card in my sand table. Right now I can program playlists using the M98 command, but it would be nice if there was some means to randomly select pattern files to run from among any gcode file stored in a specific directory on card 0 or card 1. It would be especially nice if I could call a single gcode macro file upon power-up that would then randomly select pattern files to run and just keep doing that until the machine is powered off (maybe days or weeks later). That would require some looping capability, I imagine.
                                It would be especially nice if the random function were seeded by a real time clock or other means so that when I power up the table, the random sequence that it plays would be different every time (or almost every time).
                                  A Former User @dc42
                                  Are you sure?
                                  Unfortunately, yes. that's for e.g. why Falcon never went GA after so many engineer years was put in and hundreds of bugs reported (and fixed) to both GCC and Intel C/C++ compiler. It's not unsafe by design, it's just that most C++ compilers have it buggy as hell. Today situation is much better than for e.g. 2009, but is still not resolved. Again, no clue how that relates to embedded systems, and if it relates at all.. it's just one of those things few ppl think about and can hit you below the belt when you least expect
                                  If that's the only thing 😄
                                  That's safe.
                                  I think it would be safe even if not only that 'cause the unsafe part start to pop up under contention, I don't finally remember all the details but but I think it's the number of threads and not the CPU load that was a problem so since I doubt you'll have issue with number of threads on the RRF you should be safe 😄 whatever you do... but yes, single thread using exceptions will never hit any of those bugs
                                  • wescundefined
                                    wesc @dc42
                                    Ternary operator like the c language ? :
                                    Very useful for doing machine specific parameter substitutions vs having to do if then else.
                                    Min, max functions
                                    Max z of the current print job. Useful for doing tuning of parameters. That, or an interpolate with z function. For example
                                    M572 DO S%zinterpolate(0.1,2.0)%
                                    which would be the same as
                                    M572 D0 S%0.1+(2.0-0.1)*z/max_z%
                                    CroXY - Crossed Gantry Printer, Ultibots D300VS+, Custom CoreXYU
                                    • DaBitundefined
                                      DaBit
                                      I suspect most of my conditional code use would be some form of
                                      while (measured value < setpoint) {
                                      move this
                                      move that
                                      pause a while
                                      and if (this) then { that }
                                      The conditional code provided by LinuxCNC and accessing of state information through numbered or named variables is not all that complicated and works well enough.
                                      I would at prefer to have access to axis positions and sensor values.
                                      • JoergS5undefined
                                        JoergS5
                                        My proposal for G-Code is to have all sorts of input values like external pin signals, temperaturs, voltages, current stepper positions; then calling macros to react to them and have some time waiting/pausing/reset to specified state methods. G-Code to call external methods like a Raspi for camera analysis and come back for reaction. The G-Code implementation should follow syntax rules of a known programming language (C++, Python etc. but only one of them), so the syntax needs not to be learned new again.
                                          The syntax has already been defined. It id described at https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands. We are constrained by the conventions and symbols that are already used in GCode.
                                          As GCode is a line-oriented language, the main decision that had to be taken was whether to denote block scopes using indentation (as in Haskell and Python) or using block end keywords (as in Algol 68, Ada and Fortran). I chose indentation.
                                          • mwolterundefined
                                            mwolter
                                            Min and Max X and Y coordinates of the print.
                                            Would be very helpful if the min and max X and Y coordinates of the print could be read from the g code and used as a variable in an M557 which is saved before running G29. This would allow a custom probe grid to be used that only probes the area of the bed used for that particular print.
                                            Luke'sLaboratoryundefined 1 Reply Last reply Reply Quote 1
