SSR stuck on???
35
1.4k
    dc42 administrators @gnydick
    @gnydick said in SSR stuck on???:
    It's all wired correctly.
    How exactly have you wires the SSR to the Duet? Photo please.
    undefined 1 Reply Last reply 30 Dec 2019, 18:50 Reply Quote 0
      gnydick @dc42
      #1 to black wago
      #2 to bed loop eventually to white wago
      #3 bed pos
      #4 bed neg
      Behavior
      • Connected as is: bed turns on and stays on with heater off or on
      • #3 disconnected: bed stays off with heater off or on
      • #3 & #4 reversed: bed stays off with heater off or on
        gnydick @DocTrucker
        @DocTrucker as soon as I disconnect the signal wires, the bed turns off.
        With them connected, the bed is always on, even if I turn the heater on, which would turn it off if my config was inverted, if I understand that correctly.
          Can you pull the SD card entirely, disconnect the bed connector on the Duet, power on, and carefully check if there is VIN across the bed terminals?
          If yes, then that would indicate that the bed heater mosfet has failed on.
          If not, Insert the SD card and check again, if there is now VIN across the terminals, then that would indicate a configuration issue.
          undefined 1 Reply Last reply 30 Dec 2019, 20:36 Reply Quote 0
            gnydick @Phaedrux
            @Phaedrux do I just set my meter to low voltage and touch to both terminals directly?
            undefined 1 Reply Last reply 30 Dec 2019, 20:40 Reply Quote 0
              Phaedrux Moderator @gnydick
              @gnydick I'm not familiar with your particular meter, but yes you'd set it to DC voltage in the range that would register 24v accurately. Touch + to + and - to -. Careful not to short anything else.
              undefined 2 Replies Last reply 30 Dec 2019, 20:45 Reply Quote 0
                gnydick @Phaedrux
                @Phaedrux yep, 24.1v 😞
                  gnydick @Phaedrux
                  @Phaedrux can I use a different connection to trigger the SSR while I wait for the replacement?
                    A Former User
                    If its not covered by warranty and you want to use the SSR anyway you might get away with soldering a wire from the gate on the bed FET and run that to the SSR input. (you may have to invert the output if you do)
                    Edit: sure, can def use any of the fan outputs instead.
                    undefined 1 Reply Last reply 30 Dec 2019, 20:50 Reply Quote 0
                      gnydick @A Former User
                      @bearer any pointers on how to set that up? Would I just wire two of the pwm pins to the SSR and map the bed heater to that pwm?
                      ? 1 Reply Last reply 30 Dec 2019, 20:55 Reply Quote 0
                        Since the bed heater is being powered via SSR and the SSR input will accept lower voltage than VIN, you could use any other open heater or fan output with a little configuration.
                        If the Duet came with the RailCore kit I'd seek a warranty claim.
                        undefined 1 Reply Last reply 30 Dec 2019, 20:56 Reply Quote 0
                          A Former User @gnydick
                          i'd use the "ground" from a fan, that ground is pwm controlled by the duet and you can use any supply voltage, the one on the fan output is convenient though. then unmap the fan if needed and map the heater. I'm sure some of the wizzards can help with the config if needed
                            gnydick @Phaedrux
                            @Phaedrux I am, but it will take time. I'd like to get everything else tested out while I wait.
                            undefined 1 Reply Last reply 30 Dec 2019, 21:01 Reply Quote 0
                              You can also use a spare heater output on the Duet or the DueX5.
                              undefined 1 Reply Last reply 30 Dec 2019, 21:03 Reply Quote 0
                                Here's the directions for using a chamber heater. It's the same principal. Using an alternate pin for controlling an extra heater. The only difference for you is that instead of defining a new heater 3, you'd be altering the configuration for heater 0 (the bed on duet 2)
                                https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_a_chamber_heater
                                undefined 1 Reply Last reply 30 Dec 2019, 21:02 Reply Quote 0
                                  gnydick @Phaedrux
                                  @Phaedrux thanks
                                    jens55
                                    It is highly unlikely that the SSR has failed since it is not stuck in the 'on' position. It is way more likely that there is a wiring error.
                                    Are you aware that the positive line will always be high no matter if the heater is on or off?
                                    Simply wiring the negative to ground will cause all these issues.
                                    Verify the ruting of the two control lines.
                                      gnydick @dc42
                                      @dc42 do I remap a pin to H0 or do map a different heater to "bed"? I'm kinda lost as to which direction to go.
                                      undefined 1 Reply Last reply 30 Dec 2019, 21:08 Reply Quote 0
                                        If you are using RRF2 then use a different heater number. Use M140 with an H parameter in config.g to tell the firmware which one.
                                        It's very usual to have a dud bed heater mosfet on a Duet. Is the bed heater LED on the Duet permanently illuminated too?
                                          whosrdaddy
                                          @gnydick : If I look at your photo, I believe you made a wiring error, you have wires labeled "BED-SSR" connected to the VIN connector and wired VIN to the Bed output connector!!!! Please double check your wiring, diagrams can be found here
                                          undefined undefined 2 Replies Last reply 30 Dec 2019, 21:12 Reply Quote 1
                                          13 out of 35
