    Pressure Advance Calibration
    187
    61.2k
    • botundefined
      bot @wilriker
      If a user has a very geared down extruder, low E jerk is required (if using pressure advance). IIRC, extruder jerk is only used when pressure advance is in effect. Otherwise, it has no effect on print time. E Accel has an effect on print time when set too low, with or without pressure advance.
      My extruder can't use correct amounts of pressure advance without a low E jerk value of ~90.
      *not actually a robot
      • SnakeSPundefined
        SnakeSP
        I have very strange results when trying to calibrate PA.
        Here are the speed, acceleration and jerk settings:
        M203 X15000.00 Y15000.00 Z15000.00 E6000.00
        M201 X2000.00 Y2000.00 Z2000.00 E2000.00
        M566 X1200.00 Y1200.00 Z1200.00 E1200.00
        I'm using BMG cloned extruder (if matters) with bowden of 550 mm and ID 2 mm.
        Used python script to print patterns with the following settings:
        extrusion_width = 0.5 (nozzle is 0.4 actually, 0.5 is used in slicer as an extrusion width)
        layer_height = 0.2
        filament_diameter = 1.72 (measured with calipers)
        travel_speed = 150
        first_layer_speed = 15
        slow_speed = 5
        fast_speed = 70
        I tried PA settings from 0.1 to 1.0 at first and there were no signs of PA working. Further experiments showed that noticable result is there only in range 1.5 to 1.9. But this looks insane... Or this is normal?
        Also i noticed that the speed is limited to 63-65 mm/s (due to too low extruder settings possibly?).
          Phaedrux Moderator @SnakeSP
          @SnakeSP Perhaps try this method of tuning pressure advance.
          https://duet3d.dozuki.com/Wiki/Pressure_advance#Section_Methods_of_finding_the_right_amount_of_pressure_advance
          SnakeSPundefined 1 Reply Last reply Reply Quote 0
          • SnakeSPundefined
            SnakeSP @Phaedrux
            @Phaedrux
            I tried the first one, with the python script.
            Will try the second one, with the cube, but need to understand how to make Simplify3d to align seam at the center of the side, for now i can only align it to one of the corners.
            One more thing still bothers me: i have not yet found the proper settings for BMG extruder (speed, acceleration, jerk) there are very different number said to be best in every topic i've read and there is nothing about it on Bondtech site. Can you point me where can i find such info please?
            • SnakeSPundefined
              SnakeSP
              No matter what i try to set with "Choose start point..." the beginning of the line is always in the corner. Same for Cura. Does anyone know how to align Z seam to the center of the cube's side?
                @SnakeSP not sure about simplify but with Cura you choose it specified and then choose an x y coordinate for the seam.
                • SnakeSPundefined
                  SnakeSP @Phaedrux
                  @Phaedrux
                  Yes, i tried that but Cura still places seam to the corner...
                    @SnakeSP
                    Z seam alignment - User specified
                    Z seam position - back
                    Seam corner preference - none
                    Produces the desired result. That's in 4.4.1. In older versions there was an X and Y position you could specify. The setting is still there in the settings visibility filter, but it's not being shown and I'm not sure what's blocking it. Regardless, setting it to back, front, left, or right works to align it to a face.
                    • SnakeSPundefined
                      SnakeSP @Phaedrux
                      @Phaedrux
                      Does not work for me 😞
                      Cura 4.4.1, settings as you've specified - seam is generated in one of the corners no matter what coordinates i set.
                      Can you share a gcode of the cube (20x20x20) with a single perimeter with a seam in the center of one of the sides so i can modify it for my printer, please?
                      burtoogleundefined DanS79undefined 2 Replies Last reply Reply Quote 0
                      • burtoogleundefined
                        burtoogle @SnakeSP
                        @SnakeSP said in Pressure Advance Calibration:
                        @Phaedrux
                        See https://forum.duet3d.com/post/124481
                        SnakeSPundefined 1 Reply Last reply Reply Quote 1
                        • SnakeSPundefined
                          SnakeSP @burtoogle
                          @burtoogle Thanks!
                            @SnakeSP sorry for providing misinformation. I'm surprised that the stock Cura build won't allow it.
                            • spllgundefined
                              spllg
                              thanks for this thread!
                              after playing a bit with pressure advance i was able to boost the quality of at least one print and i feel the shape of the model matters a lot. pressure advance enabled me to print a model with tiny 45 degree overhanging sharp corners.
                              • devleonundefined
                                devleon
                                I have tuned PA according to the method in the wiki, not with the script, but by printing a 100mm cube and adjusting on the fly. I have settled on 0.7, with a bowden tube of around 480mm length.
                                While my corners, overall surface and z-seam look better, I'm now getting gaps in the infill - not in the parameters though. I looked in PrusaSlicer and the only setting I can find that mentions overlap is "Infill/Perimeters overlap". By default, it was set to 25%. Is this the value I need to change?
                                If yes, what should I change it to?
                                  Phaedrux Moderator @devleon
                                  @devleon yes the wiki does mention that maps may form. It's like the slicers have been compensating for bulging line ends already. Try an additional 3-5%.
                                  devleonundefined 1 Reply Last reply Reply Quote 0
                                  • devleonundefined
                                    devleon @Phaedrux
                                    @Phaedrux
                                    I changed the value from 25%, to 30% and to 40% with no difference.
                                    Thinking more about it, I don't think it's Infill/Perimeter Overlap. Shouldn't it be the extrusion width for solid infill? After all the lines are now thinner on the first layer than before. This is what my config looks like in PrusaSlicer:
                                    Printing the same G-Code with PA disabled, and I get a beautiful first and second layer with no gaps. As soon as PA is enabled, I get gaps in the first and second layer between the individual lines of filament.
                                      I don't let slic3r pick the extrusion width normally. All widths would either be same as nozzle size or a bit more. 200% for first layer is an old school hack for bed adhesion. Try with first layer at nozzle size and 0.2 layer height.
                                      • DanS79undefined
                                        DanS79 @SnakeSP
                                        @SnakeSP I feel your pain, as Ideamaker is the same way. It says i can put the seam anywhere, but it always puts it at a corner. I'm going to try this out with a large diameter cylinder instead of a square.
                                        • sunnywilson09undefined
                                          sunnywilson09 @OBELIKS
                                          I know, but this is a bit silly.
                                          I am using a cloned Titan extruder. A bad clone.
                                          https://get-mobdro.com // https://get-tubemate.in - do share your views?
                                          • stripsundefined
                                            strips
                                            Just want to share a few changes I made in the python script.
                                            • Prints a box instead of two walls
                                            • Tidied up the skirt generation as id did some strange moves
                                            • has a text block for starting gcode and end gcode
                                            advance_cal_box.py.txt
                                            Ender 5 Plus, E3D Bigbox Dual
