    Pressure Advance Calibration
    187
    60.4k
    • SnakeSPundefined
      SnakeSP @burtoogle
      @burtoogle Thanks!
        @SnakeSP sorry for providing misinformation. I'm surprised that the stock Cura build won't allow it.
        • spllgundefined
          spllg
          thanks for this thread!
          after playing a bit with pressure advance i was able to boost the quality of at least one print and i feel the shape of the model matters a lot. pressure advance enabled me to print a model with tiny 45 degree overhanging sharp corners.
          • devleonundefined
            devleon
            I have tuned PA according to the method in the wiki, not with the script, but by printing a 100mm cube and adjusting on the fly. I have settled on 0.7, with a bowden tube of around 480mm length.
            While my corners, overall surface and z-seam look better, I'm now getting gaps in the infill - not in the parameters though. I looked in PrusaSlicer and the only setting I can find that mentions overlap is "Infill/Perimeters overlap". By default, it was set to 25%. Is this the value I need to change?
            If yes, what should I change it to?
              Phaedrux Moderator @devleon
              @devleon yes the wiki does mention that maps may form. It's like the slicers have been compensating for bulging line ends already. Try an additional 3-5%.
              devleonundefined 1 Reply Last reply Reply Quote 0
              • devleonundefined
                devleon @Phaedrux
                @Phaedrux
                I changed the value from 25%, to 30% and to 40% with no difference.
                Thinking more about it, I don't think it's Infill/Perimeter Overlap. Shouldn't it be the extrusion width for solid infill? After all the lines are now thinner on the first layer than before. This is what my config looks like in PrusaSlicer:
                Printing the same G-Code with PA disabled, and I get a beautiful first and second layer with no gaps. As soon as PA is enabled, I get gaps in the first and second layer between the individual lines of filament.
                  I don't let slic3r pick the extrusion width normally. All widths would either be same as nozzle size or a bit more. 200% for first layer is an old school hack for bed adhesion. Try with first layer at nozzle size and 0.2 layer height.
                  • DanS79undefined
                    DanS79 @SnakeSP
                    @SnakeSP I feel your pain, as Ideamaker is the same way. It says i can put the seam anywhere, but it always puts it at a corner. I'm going to try this out with a large diameter cylinder instead of a square.
                    • sunnywilson09undefined
                      sunnywilson09 @OBELIKS
                      I know, but this is a bit silly.
                      I am using a cloned Titan extruder. A bad clone.
                      https://get-mobdro.com // https://get-tubemate.in - do share your views?
                      • stripsundefined
                        strips
                        Just want to share a few changes I made in the python script.
                        • Prints a box instead of two walls
                        • Tidied up the skirt generation as id did some strange moves
                        • has a text block for starting gcode and end gcode
                        advance_cal_box.py.txt
                        Ender 5 Plus, E3D Bigbox Dual
                        • MartinNYHCundefined
                          MartinNYHC
                          May I ask for help interpreting the result? Looks like the higher PA is the better the result? I'm using a direct drive. Thanks.
                            MartinNYHC
                            This post is deleted!
                              Phaedrux Moderator @MartinNYHC
                              @MartinNYHC Yes it would appear that way buy you should also test with an actual print to check for any unintended behaviours of running with a high pressure advance value.
                              How long is your bowden tube? Have you tried the cube wall method shown here? https://duet3d.dozuki.com/Wiki/Pressure_advance#Section_Simplest_Method_Possible
                                MartinNYHC
                                @Phaedrux There's only a short PTFE tube between extruder and hotend. I think it's about 20mm. Will do some additional tests today.
                                • avion23undefined
                                  avion23
                                  I've updated the *.py file with
                                  • preamble
                                  • postamble
                                  • klipper compatibility
                                  • Marlin compatibility
                                  advance_cal.py
                                  These are my results:
                                  Delta Fyling extruder PA 0 - 0.5 over 40mm PLA
                                  Delta Fyling extruder PA 0 - 0.5 over 40mm PLA carbon fiber
                                  • jim546undefined jim546 referenced this topic
                                  • duosvidundefined
                                    duosvid
                                    duosvidundefined 1 Reply Last reply Reply Quote 0
                                    • duosvidundefined
                                      duosvid @duosvid
                                      @duosvid said in Pressure Advance Calibration:
                                      overall surface and z-seam look better, I'm now getting gaps in the infill - not in the parameters though . .
                                        Phaedrux Moderator @duosvid
                                        It's not uncommon to need to increase perimeter overlap slightly after tuning pressure advance.
                                        • tmitch205undefined
                                          tmitch205 @dc42
                                          @dc42 said in Pressure Advance Calibration:
                                          Yes that's a valid approach. It's on our list to add a generator of pressure advance tests scripts to reprapfirmware.org, but it hasn't happened yet.
                                          I know this is a super old thread but wanted to check anyway. Has the generator been created and added? If so, could you provide the link, please?
                                            jay_s_uk @tmitch205
                                            @tmitch205 my version of the klipper one generated RRF compatible pressure advance tests https://jaysuk.github.io/Voron/PA/pressure_advance.html
