    Ender 5 upgraded with Duet 2 Wifi - Problems
    786
    • TiToMoskitoundefined
      TiToMoskito
      im new in the Duet3D world and im able to print the xyz calibration cube.
      The measurements are right and the cube looks really cool.
      But when i start to print larger objects like an case cover for the duet board it starts to make weird things. Why is this happening? WhatsApp Image 2020-01-03 at 16.35.09.jpeg
      This is my config:
      ; generated by RepRapFirmware Configuration Tool v2.1.4 on Sun Dec 29 2019 21:42:21 GMT+0100 (Mitteleuropäische Normalzeit)
      G90                                     ; send absolute coordinates...
      M83                                     ; ...but relative extruder moves
      M550 P"Ender 5"                         ; set printer name
      M918 P1 E4 F2000000                     ; configure direct-connect display
      ;M551 P"Darti401"                        ; set password
      M552 S1                                 ; enable network
      M586 P0 S1                              ; enable HTTP
      M586 P1 S0                              ; disable FTP
      M586 P2 S0                              ; disable Telnet
      M569 P0 S1                              ; physical drive 0 goes forwards
      M569 P1 S1                              ; physical drive 1 goes forwards
      M569 P2 S0                              ; physical drive 2 goes backwards
      M569 P3 S1                              ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                        ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
      M92 X80 Y80 Z400 E385.00  ; set steps per mm  ---  M92 X80.00 Y80.00 Z400.00 E385.00
      M566 X1200.00 Y1200.00 Z24.00 E300.00   ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z180.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00   ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E1000 I50           ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                 ; Set idle timeout
      ;M208 X0 Y0 Z0 S1                        ; set axis minima
      ;M208 X170 Y200 Z300 S0                  ; set axis maxima
      M208 X0:170 Y0:200 Z0:300
      M574 X1 Y1 S1                           ; set active high endstops
      M574 Z1 S2                              ; set endstops controlled by probe
      M307 H3 A-1 C-1 D-1			; Disable the 3th Heater to free up PWM channel 5 on the Duex board.
      M558 P9 H5 F300 T6000                   ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-46 Y-17 Z2.2                 ; set Z probe trigger value, offset and trigger height
      M557 X0:180 Y0:200 S40                	; define mesh grid
      M307 H0 B0 S1.00                        ; disable bang-bang mode for the bed heater and set PWM limit
      M305 P0 T100000 B4092 R4700             ; set thermistor + ADC parameters for heater 0
      M143 H0 S130                            ; set temperature limit for heater 0 to 130C
      M305 P1 T100000 B4092 R4700             ; set thermistor + ADC parameters for heater 1
      M143 H1 S275                            ; set temperature limit for heater 1 to 275C
      M106 P0 S0 I0 F500 H-1                  ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45               ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H1:0 T45             ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 F0                        ; define tool 0
      G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
      G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
      Phaedruxundefined zecchiundefined 2 Replies Last reply Reply Quote 0
      • SIamundefined
        SIam
        @TiToMoskito said in Ender 5 upgraded with Duet 2 Wifi - Problems:
        is your print bed clean no fat or fingerprints on it?
        did you try to reduce the speed for the first layer?
        you can try to higher the print temperature for the first layer?
        the same with the bed Temperature
        is the space between nozzle an printbed realy accurate?
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
        • Vetiundefined
          Veti
          post a picture of your mesh grid
            Phaedrux Moderator @TiToMoskito
            You can likely improve the results of your probing by reducing the probe speed and increasing the trigger sensitivity.
            Try changing M558 F120 and G31 P25 and redoing your mesh compensation.
            You can also try increasing the detail of your grid by reducing M557 S40 to S20.
            • zaptaundefined
              zapta
              Looking at the picture, at one side the skirt doesn't go around the printed object, as if the head cannot go all the way. Are the x/y dimension in your config.g and slicer correct?
              For example, shouldn't these be 0:220 for x,y?
              • zecchiundefined
                zecchi @TiToMoskito
                @TiToMoskito
                Try to clean the bed and turn off the fan during first layer
                  TiToMoskito
                  I cleaned my bed alcohol, so there is no fat or fingerprints on it.
                  Can someone tell me how to make my mesh grid bigger?
                  When i change the grid to
                  M557 X0:200 Y0:200 S40
                  it will probe outside the bed, and it doesnt start really from zero it always start from the homing position.
                  By the way, the homing position shouldn't it be on the center of the bed 😄 ?
                  homing_pos
                  My bed dimensions are: X: 220 Y: 220 (prev. on klipper i had on y 235)
                  Heightmap
                  Here is my heightmap: heightmap.csv
                  I put my z on zero and made a manual paper bed leveling (sorry i dont how to call it, i hope you understand what i mean)
                  • Vetiundefined
                    Veti
                    what material are you printing and at what temperature?
                      TiToMoskito
                      Im printing PLA with 200°C and 60°C bed temp
                      • Vetiundefined
                        Veti
                        can you try the values for the thermistor from this and see if it makes a difference?
                        https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38?lang=en
                          By the way, the homing position shouldn't it be on the center of the bed ?
                          Can you post your homing files?
                            TiToMoskito
                            @Veti this is not a temp issue, i think its more a calibration failure on my site.
                            @Phaedrux What kind of homing files do you need?
                            Vetiundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                            • Vetiundefined
                              Veti @TiToMoskito
                              nevertheless your thermistors settings are not correct.
                                all of them? Homeall, homez, homex, homey. bed.g as well if you use G32 at all.
                                TiToMoskitoundefined 1 Reply Last reply Reply Quote 0
                                  TiToMoskito @Phaedrux
                                  @Phaedrux i hope its everything 🙂
                                  homez.g homey.g homex.g homedelta.g homeall.g bed.g
                                    From your homeall.
                                    G1 H2 Z2 F6000          ; lift Z relative to current position
                                    G1 H1 X-235 Y-230 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
                                    G1 H2 X5 Y5 F6000       ; go back a few mm
                                    G1 H1 X-235 Y-230 F360  ; move slowly to X and Y axis endstops once more (second pass)
                                    G90                     ; absolute positioning
                                    G1 H2 X51 Y22 F6000     ; go to first bed probe point and home Z
                                    G30                     ; home Z by probing the bed
                                    The position of the bed probing for the Z axis is set as X51 Y22. You can change that as needed to position to probe at the center of the bed.
                                      TiToMoskito
                                      Thanks, i changed it to 117 to the center of the bed.
                                      My mesh grid is set on X to max 180, why does it exceed?
                                      M557 X5:180 Y5:215 S10
                                      And why does it start at X: 49.0 Y:22.0 and not from 5 ?
                                      mesherror
                                        Are you getting messages in the console saying points unreachable?
                                        The grid specifies the area of the bed you want probed. But the probe has an offset from the nozzle and it's possible that it cannot reach all points.
