Pressure Advance seems to not be working.
83
6.7k
    Phaedrux Moderator @Samuel235
    @Samuel235 said in Pressure Advance seems to not be working.:
    I do have combing enabled, but its set to 10.
    I dislike combing, I'd much rather retract at all times.
    undefined 1 Reply Last reply 5 Jan 2020, 18:05 Reply Quote 0
      Samuel235 @Phaedrux
      @Phaedrux - Combing has now been disabled, i'm joining the dark side!
        Samuel235
        I'm getting a little confused between M201 and M204, the duet gcode page is saying that M201 is per axis acceleration and M204 is for printing overall, will only the lowest value get used when it comes to printing?
          M201 sets the maximum value for all cases. M204 is optional and gives a bit finer control by separating print and travel moves and lets you use higher acceleration on travel moves. This can be controlled in the slicer now as well with much finer grained control still.
          It comes down to preference where and how you set those values. And as long as you're aware it doesn't really matter. Some people like to use M201 in config.g and leave it at that with acceleration set the same for all moves. Or maybe use M204 and split print and travel. And others like me use the slicer to have fine grained control over each move type. I use faster for travels, medium for internal areas, and lower for external surfaces. Cura is best for this. PrusaSlicer has more limited control over acceleration and no control of jerk.
            More to the point maybe. I'm not sure which will take precedence. If M201 sets a limit at 1000, and M204 sets print moves at 500 and travel at 5000, I'm not sure if M201 will override the M204 or if M204 just sets the new limit.
            Even if using M204 you'd still need to use M201 to set the values for all axis since M204 only applies to XY movement I believe.
              Samuel235
              Thanks for that, much appreciated, makes a little more sense now.
              I have now kicked off a print with no coasting and 3mm retraction at 50mm/s and the following acceleration/jerk settings:
              M566 X700 Y700 Z60 E3000 ; Set maximum instantaneous speed changes (mm/min)
              M203 X18000 Y18000 Z3000 E15000 ; Set maximum speeds (mm/min)
              M201 X2000 Y2000 Z250 E3000 ; Set maximum accelerations (mm/s^2)
              M204 P1500 T2000 ; Set printing acceleration and travel accelerations
              This print is testing the following PA values:
              Layers | PA Value
              0 - 25 | 0.5
              25 - 50 | 0.0
              50 - 75 | 0.6
              75 - 100 | 0.0
              100 - 125 | 0.7
              125 - 150 | 0.0
              150 - 175 | 0.8
              175 - 200 | 0.0
              200 - 225 | 0.9
                Samuel235
                A PA value of 0.7 is still giving me issues. How low should I realistically be looking to take the retraction down to when PA on? This was down to 3mm retraction at 50mm/s...
                The interesting thing is that the one line in the infil actually printed with the PA set to 0.9 but nothing else on those layers did...
                  You could do a reverse test for finding the retraction value. Leave PA set at 0.7 and vary the retraction from 0 to 3mm.
                    Samuel235
                    This was with 1mm retraction, will be dropping it lower tomorrow:
                      zapta
                      I spent months struggling to get a decent print quality from my 600mm bowden setup and the problems went way once I switch to a direct extruder.
                      Just saying 😉
                        Samuel235
                        I'm waiting for Voron Afterburner to get released out of Beta before switching back to direct drive (have two Wilson 2 printers with Direct Drive). This is simply to get me through to the point where I can print very nice prints until that point. But to be honest with you, I'm burning through filament and time at a crazy speed to get this single issue ironed out, I might just jump onto Voron's direct drive while its in BETA version.
                          Have you printed much other than test cubes for pressure advance? You can still learn a lot by just adjusting it while printing an actual object. Some pressure advance is better than no pressure advance even if it's not the perfect amount.
                          The Wilson was my first printer by the way. Good little machine for the time.
                            Samuel235
                            I haven't, no. I'm about to start printing things with PA of 0.5 to see how it is, ill bring my retraction back up a little bit to 3mm and see how I go from there. I will pick PA testing back up when I convert over to Direct Drive I think, I hate having bowden in the setup, I would much rather sacrifice some speed for quality.
                            Its still bugging me seeing the extrusion just straight up fail with those PA values I were testing with, I feel like its just a single setting that is hurting my experiments but i'm unsure what it is.
                            I really enjoyed my time using the Wilson 2's, but I'm so over the sketchup design and the way it performs its probing. I'm all for CoreXY now since joining in with Voron 2.
                              oliof
                              I have completely disabled PA after switching to KISS with it's looping seam hiding. When going to Hemera, I also disabled KISS' PreloadVE settings which is like slicer based PA to my understanding (but working of an experimentally deduced viscosity model of the material used).
                              Supermerill's Slic3r++ fork includes looping seam hiding as well, but I haven't tried it yet (the latest build crashes at launch and I haven't tried to figure out why).
                              undefined 1 Reply Last reply 9 Jan 2020, 13:47 Reply Quote 0
                                OBELIKS @oliof
                                @oliof said in Pressure Advance seems to not be working.:
                                He has a fix on the releases page. "You have to remove creality.ini and basic.ini from resources/profiles because they have duplicate lines."
                                I also need to try it.
                                P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
                                Original Prusa i3 MK3S
                                78 out of 83
