Z axis issue: wrong movement (layers)
@Phaedrux I think it’s worse than that. The user seems to be using pid with the bed but using default parameters. This may not be worse than bang bang but it could very well be.
I don’t think the user understood what I was saying. Tuning the bed PID or trying bang bang was my suggestion, basically. I’m so bad at wording posts.
@bot said in Z axis issue: wrong movement (layers):
Yeah , it is. I've never tuned the bed because I never use it (At least for now ).
@zecchi Sorry about that. If you're not heating the bed that is clearly not a factor.
Today I'll try the new z axes. I set up them yesterday. My last chance...
And here we go!!
The problem were the two z axis.
Maybe it was due to the elasticity of the belts!!Thanks to all.
Congrats on solving the issue.
A question out of curiosity, what did you change in your Z axis?
@zecchi
Thank you for sharing.
So you wouldn't recommend short belts for driving the axis?
I was close to modify my HEVO in the same way.
By the way, have you designed the geared axis by yourself? -
@Dkos
I've replaced it in this way:Actually there are other improvements to do (these lead screws are too short ) but for now it's ok
All my printer is designed by me.
And yeah , belts are not a good solution for high loads. -
@zecchi Thanks for the info, I also have the same issue as you had (i think), but not as intense as yours and i am running my Z axis with a closed loop belt. I guess i will give the direct a try to see if the issue is going to be completely eliminated for me as well.
Cheers!
So I'm guessing eccentric pulley leading to uneven motion.
