    Duet 3 and jetson Nano?
    111
    9.3k
    • gtj0undefined
      gtj0
      @hanshogeland I just uploaded DSF builds for 1.0.4.0. Suggest you give those a try.
      • gtj0undefined
        gtj0
        I'm seeing the same checksum issues. I think I have to tweak the drive strength and the timing a bit.
        Working on it!
        hanshogelandundefined 1 Reply Last reply Reply Quote 1
        • hanshogelandundefined
          hanshogeland @gtj0
          @gtj0 great! ๐Ÿ™‚
          • gtj0undefined
            gtj0
            I figured it out. I stupidly forgot to set the MISO pins to TRISTATE so the data was getting corrupted.
            Tested and things now seem fully operational.
            Grab the new u-boot and dtb files from:
            https://github.com/gtjoseph/jetson-nano-support/tree/l4t_32.2.1
            hanshogelandundefined 1 Reply Last reply Reply Quote 4
              hanshogeland @gtj0
              @gtj0 Success!! Thank you fior your hard work of making it work Iแธฟ truly grateful ๐Ÿ™‚ 32fc5be7-e1cf-4a58-be99-c1d2fc6dbed0-image.png
              • gtj0undefined
                gtj0
                Just a quick update...
                There are official 64 bit builds of Duet Software Framework available from Duet3D. All you have to do is create a file named /etc/apt/sources.list.d/duet3d.list with one line in it...
                deb https://pkg.duet3d.com/ stable armv7
                Even though armv7 is mentioned, you'll get the arm64 packages.
                Then copy the attached gpg key to /etc/apt/trusted.gpg.d/duet3d.gpg.
                duet3d.gpg.txt
                The .txt suffix was added just to satisfy the forum's upload restrictions so you need to remove it.
                Finally, do an apt-get update and apt-get install duetsoftwareframework
                  hanshogeland @gtj0
                  @gtj0 said in Duet 3 and jetson Nano?:
                  Yes, Iยดve been thinking about this for a while and just like that the update I was waiting for :)!
                  Followed your instructions and it worked like a charm, thank you so much.
                  • gtj0undefined
                    gtj0
                    Those packages have been up there for a while now but both @chrishamm and I forgot to tell anyone. ๐Ÿ™‚
                    • HebigTundefined
                      HebigT
                      @gtj0
                      I did a fresh install (both L4T & DSF) and I'm running into an issue:
                      Monitoring DCS shows "Kernel SPI buffer" warning & "Duet is not available"
                      jpomo@jpomo-desktop:~$ sudo /opt/dsf/bin/DuetControlServer
                      Duet Control Server v1.2.3.0
                      Written by Christian Hammacher for Duet3D
                      Licensed under the terms of the GNU Public License Version 3
                      [info] Settings loaded
                      [info] Environment initialized
                      **[warn] Kernel SPI buffer size is smaller than RepRapFirmware buffer size (4096 configured vs 8192 required)
                      [error] Duet is not available**
                      Here are my config files -
                      http.json:
                        "Logging": {
                          "LogLevel": {
                            "Default": "Information"
                        "Kestrel": {
                          "Endpoints": {
                            "Http": {
                              "Url": "http://127.0.0.1"
                        "KeepAliveInterval": 30,
                        "ModelRetryDelay": 5000,
                        "UseCors": true,
                        "UseStaticFiles": true,
                        "SocketPath": "/var/run/dsf/dcs.sock",
                        "WebSocketBufferSize": 8192
                      config.json
                        "LogLevel": "info",
                        "SocketDirectory": "/var/run/dsf",
                        "SocketFile": "dcs.sock",
                        "Backlog": 4,
                        "SocketPollInterval": 2000,
                        "BaseDirectory": "/opt/dsf/sd",
                        "HostUpdateInterval": 4000,
                        "ConfigUpdateInterval": 5000,
                        "MaxMessageAge": 60.0,
                        "SpiDevice": "/dev/spidev0.0",
                        "SpiFrequency": 1000000,
                        "SpiTransferTimeout": 500,
                        "MaxSpiRetries": 3,
                        "SpiPollDelay": 25,
                        "GpioChipDevice": "/dev/gpiochip0",
                        "TransferReadyPin": 13,
                        "BufferedPrintCodes": 32,
                        "BufferedMacroCodes": 16,
                        "MaxBufferSpacePerChannel": 1536,
                        "ModelUpdateInterval": 125,
                        "MaxMachineModelLockTime": -1,
                        "FileInfoReadLimitHeader": 12288,
                        "FileInfoReadLimitFooter": 262144,
                        "MaxLayerHeight": 0.9,
                      Additonally,
                      sudo systemctl status duetcontrolserver:
                      jpomo@jpomo-desktop:~$ sudo systemctl status duetcontrolserver
                      โ— duetcontrolserver.service - Duet Control Server
                         Loaded: loaded (/usr/lib/systemd/system/duetcontrolserver.service; enabled; vendor preset: ena
                         Active: active (running) since Mon 2020-01-13 13:09:55 MST; 589ms ago
                       Main PID: 17421 (DuetControlServ)
                          Tasks: 9 (limit: 4182)
                         CGroup: /system.slice/duetcontrolserver.service
                                 โ””โ”€17421 /opt/dsf/bin/DuetControlServer
                      Jan 13 13:09:55 jpomo-desktop systemd[1]: Started Duet Control Server.
                      Jan 13 13:09:56 jpomo-desktop DuetControlServer[17421]: Duet Control Server v1.2.3.0
                      Jan 13 13:09:56 jpomo-desktop DuetControlServer[17421]: Written by Christian Hammacher for Duet3D
                      Jan 13 13:09:56 jpomo-desktop DuetControlServer[17421]: Licensed under the terms of the GNU Publi
                      sudo systemctl status duetwebserver:
                      โ— duetwebserver.service - Duet Web Server
                         Loaded: loaded (/usr/lib/systemd/system/duetwebserver.service; enabled; vendor preset: enabled)
                         Active: active (running) since Mon 2020-01-13 12:52:11 MST; 18min ago
                       Main PID: 4592 (DuetWebServer)
                          Tasks: 19 (limit: 4182)
                         CGroup: /system.slice/duetwebserver.service
                                 โ””โ”€4592 /opt/dsf/bin/DuetWebServer
                      Jan 13 13:10:26 jpomo-desktop DuetWebServer[4592]:    at System.Net.Sockets.Socket.Connect(EndPoint remoteEP)
                      Jan 13 13:10:26 jpomo-desktop DuetWebServer[4592]:    at DuetAPIClient.BaseConnection.Connect(ClientInitMessage initMessage, String socketPath, CancellationToken cancellationToken
                      Jan 13 13:10:26 jpomo-desktop DuetWebServer[4592]:    at DuetWebServer.Services.ModelObserver.Execute() in /home/christian/duet/DuetSoftwareFramework/src/DuetWebServer/Services/Mo
                      Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]: warn: DuetWebServer.Services.ModelObserver[0]
                      Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]:       Failed to synchronize machine model
                      Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]: System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requested address /var/run/dsf/dcs.sock
                      Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]:    at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
                      Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]:    at System.Net.Sockets.Socket.Connect(EndPoint remoteEP)
                      Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]:    at DuetAPIClient.BaseConnection.Connect(ClientInitMessage initMessage, String socketPath, CancellationToken cancellationToken
                      Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]:    at DuetWebServer.Services.ModelObserver.Execute() in /home/christian/duet/DuetSoftwareFramework/src/DuetWebServer/Services/Mo
                      As far as I know, I have set the correct GPIO pin and SPI frequency.
                      Any advice is appreciated!
                      • chrishammundefined
                        chrishamm administrators
                        Have a look at the note in https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Enabling_SPI I haven't tested this on a Jetson Nano, though.
                        Duet software engineer
                        • gtj0undefined
                          gtj0
                          @jpomo10 It's an easy fix...
                          Create a file named /etc/modprobe.d/spidev.conf and put 1 line in it...
                          options spidev bufsiz=8192
                          Then reboot. You should be good to go after that.
                          • HebigTundefined
                            HebigT
                            @chrishamm @gtj0
                            Thank you for your help on this.
                            This fixed the buffersize problem, but still getting Duet is not available:
                            Any other ideas of what might be causing it?
                            Thanks!
                            • gtj0undefined
                              gtj0
                              What's the contents of /opt/dsf/conf/config.json ?
                              Also start duetcontrolserver with -l debug
                              HebigTundefined 1 Reply Last reply Reply Quote 0
                                My best guess is that you don't have the GPIO pin for the transfer ready line configured yet. Unfortunately this part is a bit counter-intuitive because the pin index in the gpiochip device likely varies from the sysfs index but with the right tool you can dump the indices and figure out what device/index you need to use.
                                • HebigTundefined
                                  HebigT @gtj0
                                  @gtj0
                                    "LogLevel": "info",
                                    "Backlog": 4,
                                    "SpiFrequency": 500000,
                                    "MaxSpiRetries": 3,
                                    "SpiPollDelay": 25,
                                    "LayerHeightFilters": [
                                        "Pattern": "layer_height\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))",
                                        "Options": 17
                                        "Pattern": "Layer height\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))",
                                        "Options": 17
                                        "Pattern": "layerHeight\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))",
                                        "Options": 17
                                        "Pattern": "layer_thickness_mm\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))",
                                        "Options": 17
                                        "Pattern": "layerThickness\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))",
                                        "Options": 17
                                    "FilamentFilters": [
                                        "Pattern": "filament used\\D\u002B(((?\u003Cmm\u003E\\d\u002B\\.?\\d*)mm)(\\D\u002B)?)\u002B",
                                        "Options": 17
                                        "Pattern": "filament used\\D\u002B(((?\u003Cm\u003E\\d\u002B\\.?\\d*)m([^m]|$))(\\D\u002B)?)\u002B",
                                        "Options": 17
                                        "Pattern": "material\\#\\d\u002B\\D\u002B(?\u003Cmm\u003E\\d\u002B\\.?\\d*)",
                                        "Options": 17
                                        "Pattern": "filament length\\D\u002B(((?\u003Cmm\u003E\\d\u002B\\.?\\d*)\\s*mm)(\\D\u002B)?)\u002B",
                                        "Options": 17
                                        "Pattern": "Filament used per extruder:\\r\\n;\\s*(?\u003Cname\u003E.\u002B)\\s\u002B=\\s*(?\u003Cmm\u003E[0-9.]\u002B)",
                                        "Options": 17
                                    "GeneratedByFilters": [
                                        "Pattern": "generated by\\s\u002B(.\u002B)",
                                        "Options": 17
                                        "Pattern": ";\\s*Sliced by\\s\u002B(.\u002B)",
                                        "Options": 17
                                        "Pattern": ";\\s*(KISSlicer.*)",
                                        "Options": 17
                                        "Pattern": ";\\s*Sliced at:\\s*(.\u002B)",
                                        "Options": 17
                                        "Pattern": ";\\s*Generated with\\s*(.\u002B)",
                                        "Options": 17
                                    "PrintTimeFilters": [
                                        "Pattern": "estimated printing time = ((?\u003Ch\u003E(\\d\u002B))h\\s*)?((?\u003Cm\u003E(\\d\u002B))m\\s*)?((?\u003Cs\u003E(\\d\u002B))s)?",
                                        "Options": 17
                                        "Pattern": ";TIME:(?\u003Cs\u003E(\\d\u002B\\.?\\d*))",
                                        "Options": 17
                                        "Pattern": "Build time: ((?\u003Ch\u003E\\d\u002B) hours\\s*)?((?\u003Cm\u003E\\d\u002B) minutes\\s*)?((?\u003Cs\u003E(\\d\u002B) seconds))?",
                                        "Options": 17
                                        "Pattern": "Estimated Build Time:\\s\u002B((?\u003Ch\u003E(\\d\u002B\\.?\\d*)) hours\\s*)?((?\u003Cm\u003E(\\d\u002B\\.?\\d*)) minutes\\s*)?((?\u003Cs\u003E(\\d\u002B\\.?\\d*)) seconds)?",
                                        "Options": 17
                                    "SimulatedTimeFilters": [
                                        "Pattern": "; Simulated print time\\D\u002B(?\u003Cs\u003E(\\d\u002B\\.?\\d*))",
                                        "Options": 17
                                  • gtj0undefined
                                    gtj0 @chrishamm
                                    @chrishamm Yeah I know which one he needs to use.
                                    • gtj0undefined
                                      gtj0
                                      And yeah, 13 is the right pin on the nano
                                        AFAIR I used this guide to figure out the right gpiochip index. You can further diagnose why DCS cannot connect by launching it with the --log-level debug parameter.
                                        • gtj0undefined
                                          gtj0
                                          @jpomo10 Turn on debug from the command line or the "LogLevel" in config.json
                                          • HebigTundefined
                                            HebigT
                                            @chrishamm @gtj0
                                            [debug] Lost connection to Duet
                                               System.OperationCanceledException: Board is not available (no header)
                                               at DuetControlServer.SPI.DataTransfer.ExchangeHeader() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 965
                                               at DuetControlServer.SPI.DataTransfer.PerformFullTransfer(Boolean mustSucceed) in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 154
