    Duet 3 and jetson Nano?
    111
    9.3k
    • hanshogelandundefined
      hanshogeland @gtj0
      @gtj0 great! ๐Ÿ™‚
      • gtj0undefined
        gtj0
        I figured it out. I stupidly forgot to set the MISO pins to TRISTATE so the data was getting corrupted.
        Tested and things now seem fully operational.
        Grab the new u-boot and dtb files from:
        https://github.com/gtjoseph/jetson-nano-support/tree/l4t_32.2.1
        hanshogelandundefined 1 Reply Last reply Reply Quote 4
          hanshogeland @gtj0
          @gtj0 Success!! Thank you fior your hard work of making it work Iแธฟ truly grateful ๐Ÿ™‚ 32fc5be7-e1cf-4a58-be99-c1d2fc6dbed0-image.png
          • gtj0undefined
            gtj0
            Just a quick update...
            There are official 64 bit builds of Duet Software Framework available from Duet3D. All you have to do is create a file named /etc/apt/sources.list.d/duet3d.list with one line in it...
            deb https://pkg.duet3d.com/ stable armv7
            Even though armv7 is mentioned, you'll get the arm64 packages.
            Then copy the attached gpg key to /etc/apt/trusted.gpg.d/duet3d.gpg.
            duet3d.gpg.txt
            The .txt suffix was added just to satisfy the forum's upload restrictions so you need to remove it.
            Finally, do an apt-get update and apt-get install duetsoftwareframework
              hanshogeland @gtj0
              @gtj0 said in Duet 3 and jetson Nano?:
              Yes, Iยดve been thinking about this for a while and just like that the update I was waiting for :)!
              Followed your instructions and it worked like a charm, thank you so much.
              • gtj0undefined
                gtj0
                Those packages have been up there for a while now but both @chrishamm and I forgot to tell anyone. ๐Ÿ™‚
                • HebigTundefined
                  HebigT
                  @gtj0
                  I did a fresh install (both L4T & DSF) and I'm running into an issue:
                  Monitoring DCS shows "Kernel SPI buffer" warning & "Duet is not available"
                  jpomo@jpomo-desktop:~$ sudo /opt/dsf/bin/DuetControlServer
                  Duet Control Server v1.2.3.0
                  Written by Christian Hammacher for Duet3D
                  Licensed under the terms of the GNU Public License Version 3
                  [info] Settings loaded
                  [info] Environment initialized
                  **[warn] Kernel SPI buffer size is smaller than RepRapFirmware buffer size (4096 configured vs 8192 required)
                  [error] Duet is not available**
                  Here are my config files -
                  http.json:
                    "Logging": {
                      "LogLevel": {
                        "Default": "Information"
                    "Kestrel": {
                      "Endpoints": {
                        "Http": {
                          "Url": "http://127.0.0.1"
                    "KeepAliveInterval": 30,
                    "ModelRetryDelay": 5000,
                    "UseCors": true,
                    "UseStaticFiles": true,
                    "SocketPath": "/var/run/dsf/dcs.sock",
                    "WebSocketBufferSize": 8192
                  config.json
                    "LogLevel": "info",
                    "SocketDirectory": "/var/run/dsf",
                    "SocketFile": "dcs.sock",
                    "Backlog": 4,
                    "SocketPollInterval": 2000,
                    "BaseDirectory": "/opt/dsf/sd",
                    "HostUpdateInterval": 4000,
                    "ConfigUpdateInterval": 5000,
                    "MaxMessageAge": 60.0,
                    "SpiDevice": "/dev/spidev0.0",
                    "SpiFrequency": 1000000,
                    "SpiTransferTimeout": 500,
                    "MaxSpiRetries": 3,
                    "SpiPollDelay": 25,
                    "GpioChipDevice": "/dev/gpiochip0",
                    "TransferReadyPin": 13,
                    "BufferedPrintCodes": 32,
                    "BufferedMacroCodes": 16,
                    "MaxBufferSpacePerChannel": 1536,
                    "ModelUpdateInterval": 125,
                    "MaxMachineModelLockTime": -1,
                    "FileInfoReadLimitHeader": 12288,
                    "FileInfoReadLimitFooter": 262144,
                    "MaxLayerHeight": 0.9,
                  Additonally,
                  sudo systemctl status duetcontrolserver:
                  jpomo@jpomo-desktop:~$ sudo systemctl status duetcontrolserver
                  โ— duetcontrolserver.service - Duet Control Server
                     Loaded: loaded (/usr/lib/systemd/system/duetcontrolserver.service; enabled; vendor preset: ena
                     Active: active (running) since Mon 2020-01-13 13:09:55 MST; 589ms ago
                   Main PID: 17421 (DuetControlServ)
                      Tasks: 9 (limit: 4182)
                     CGroup: /system.slice/duetcontrolserver.service
                             โ””โ”€17421 /opt/dsf/bin/DuetControlServer
                  Jan 13 13:09:55 jpomo-desktop systemd[1]: Started Duet Control Server.
                  Jan 13 13:09:56 jpomo-desktop DuetControlServer[17421]: Duet Control Server v1.2.3.0
                  Jan 13 13:09:56 jpomo-desktop DuetControlServer[17421]: Written by Christian Hammacher for Duet3D
                  Jan 13 13:09:56 jpomo-desktop DuetControlServer[17421]: Licensed under the terms of the GNU Publi
                  sudo systemctl status duetwebserver:
                  โ— duetwebserver.service - Duet Web Server
                     Loaded: loaded (/usr/lib/systemd/system/duetwebserver.service; enabled; vendor preset: enabled)
                     Active: active (running) since Mon 2020-01-13 12:52:11 MST; 18min ago
                   Main PID: 4592 (DuetWebServer)
                      Tasks: 19 (limit: 4182)
                     CGroup: /system.slice/duetwebserver.service
                             โ””โ”€4592 /opt/dsf/bin/DuetWebServer
                  Jan 13 13:10:26 jpomo-desktop DuetWebServer[4592]:    at System.Net.Sockets.Socket.Connect(EndPoint remoteEP)
                  Jan 13 13:10:26 jpomo-desktop DuetWebServer[4592]:    at DuetAPIClient.BaseConnection.Connect(ClientInitMessage initMessage, String socketPath, CancellationToken cancellationToken
                  Jan 13 13:10:26 jpomo-desktop DuetWebServer[4592]:    at DuetWebServer.Services.ModelObserver.Execute() in /home/christian/duet/DuetSoftwareFramework/src/DuetWebServer/Services/Mo
                  Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]: warn: DuetWebServer.Services.ModelObserver[0]
                  Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]:       Failed to synchronize machine model
                  Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]: System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requested address /var/run/dsf/dcs.sock
                  Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]:    at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
                  Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]:    at System.Net.Sockets.Socket.Connect(EndPoint remoteEP)
                  Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]:    at DuetAPIClient.BaseConnection.Connect(ClientInitMessage initMessage, String socketPath, CancellationToken cancellationToken
                  Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]:    at DuetWebServer.Services.ModelObserver.Execute() in /home/christian/duet/DuetSoftwareFramework/src/DuetWebServer/Services/Mo
                  As far as I know, I have set the correct GPIO pin and SPI frequency.
                  Any advice is appreciated!
                  • chrishammundefined
                    chrishamm administrators
                    Have a look at the note in https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Enabling_SPI I haven't tested this on a Jetson Nano, though.
                    Duet software engineer
                    • gtj0undefined
                      gtj0
                      @jpomo10 It's an easy fix...
                      Create a file named /etc/modprobe.d/spidev.conf and put 1 line in it...
                      options spidev bufsiz=8192
                      Then reboot. You should be good to go after that.
                      • HebigTundefined
                        HebigT
                        @chrishamm @gtj0
                        Thank you for your help on this.
                        This fixed the buffersize problem, but still getting Duet is not available:
                        Any other ideas of what might be causing it?
                        Thanks!
                        • gtj0undefined
                          gtj0
                          What's the contents of /opt/dsf/conf/config.json ?
                          Also start duetcontrolserver with -l debug
                          HebigTundefined 1 Reply Last reply Reply Quote 0
                            My best guess is that you don't have the GPIO pin for the transfer ready line configured yet. Unfortunately this part is a bit counter-intuitive because the pin index in the gpiochip device likely varies from the sysfs index but with the right tool you can dump the indices and figure out what device/index you need to use.
                            • HebigTundefined
                              HebigT @gtj0
                              @gtj0
                                "LogLevel": "info",
                                "Backlog": 4,
                                "SpiFrequency": 500000,
                                "MaxSpiRetries": 3,
                                "SpiPollDelay": 25,
                                "LayerHeightFilters": [
                                    "Pattern": "layer_height\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))",
                                    "Options": 17
                                    "Pattern": "Layer height\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))",
                                    "Options": 17
                                    "Pattern": "layerHeight\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))",
                                    "Options": 17
                                    "Pattern": "layer_thickness_mm\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))",
                                    "Options": 17
                                    "Pattern": "layerThickness\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))",
                                    "Options": 17
                                "FilamentFilters": [
                                    "Pattern": "filament used\\D\u002B(((?\u003Cmm\u003E\\d\u002B\\.?\\d*)mm)(\\D\u002B)?)\u002B",
                                    "Options": 17
                                    "Pattern": "filament used\\D\u002B(((?\u003Cm\u003E\\d\u002B\\.?\\d*)m([^m]|$))(\\D\u002B)?)\u002B",
                                    "Options": 17
                                    "Pattern": "material\\#\\d\u002B\\D\u002B(?\u003Cmm\u003E\\d\u002B\\.?\\d*)",
                                    "Options": 17
                                    "Pattern": "filament length\\D\u002B(((?\u003Cmm\u003E\\d\u002B\\.?\\d*)\\s*mm)(\\D\u002B)?)\u002B",
                                    "Options": 17
                                    "Pattern": "Filament used per extruder:\\r\\n;\\s*(?\u003Cname\u003E.\u002B)\\s\u002B=\\s*(?\u003Cmm\u003E[0-9.]\u002B)",
                                    "Options": 17
                                "GeneratedByFilters": [
                                    "Pattern": "generated by\\s\u002B(.\u002B)",
                                    "Options": 17
                                    "Pattern": ";\\s*Sliced by\\s\u002B(.\u002B)",
                                    "Options": 17
                                    "Pattern": ";\\s*(KISSlicer.*)",
                                    "Options": 17
                                    "Pattern": ";\\s*Sliced at:\\s*(.\u002B)",
                                    "Options": 17
                                    "Pattern": ";\\s*Generated with\\s*(.\u002B)",
                                    "Options": 17
                                "PrintTimeFilters": [
                                    "Pattern": "estimated printing time = ((?\u003Ch\u003E(\\d\u002B))h\\s*)?((?\u003Cm\u003E(\\d\u002B))m\\s*)?((?\u003Cs\u003E(\\d\u002B))s)?",
                                    "Options": 17
                                    "Pattern": ";TIME:(?\u003Cs\u003E(\\d\u002B\\.?\\d*))",
                                    "Options": 17
                                    "Pattern": "Build time: ((?\u003Ch\u003E\\d\u002B) hours\\s*)?((?\u003Cm\u003E\\d\u002B) minutes\\s*)?((?\u003Cs\u003E(\\d\u002B) seconds))?",
                                    "Options": 17
                                    "Pattern": "Estimated Build Time:\\s\u002B((?\u003Ch\u003E(\\d\u002B\\.?\\d*)) hours\\s*)?((?\u003Cm\u003E(\\d\u002B\\.?\\d*)) minutes\\s*)?((?\u003Cs\u003E(\\d\u002B\\.?\\d*)) seconds)?",
                                    "Options": 17
                                "SimulatedTimeFilters": [
                                    "Pattern": "; Simulated print time\\D\u002B(?\u003Cs\u003E(\\d\u002B\\.?\\d*))",
                                    "Options": 17
                              • gtj0undefined
                                gtj0 @chrishamm
                                @chrishamm Yeah I know which one he needs to use.
                                • gtj0undefined
                                  gtj0
                                  And yeah, 13 is the right pin on the nano
                                    AFAIR I used this guide to figure out the right gpiochip index. You can further diagnose why DCS cannot connect by launching it with the --log-level debug parameter.
                                    • gtj0undefined
                                      gtj0
                                      @jpomo10 Turn on debug from the command line or the "LogLevel" in config.json
                                      • HebigTundefined
                                        HebigT
                                        @chrishamm @gtj0
                                        [debug] Lost connection to Duet
                                           System.OperationCanceledException: Board is not available (no header)
                                           at DuetControlServer.SPI.DataTransfer.ExchangeHeader() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 965
                                           at DuetControlServer.SPI.DataTransfer.PerformFullTransfer(Boolean mustSucceed) in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 154
                                        • gtj0undefined
                                          gtj0
                                          Hmmm. Your SpiFrequency is actually on the low side. Try increasing it to 2000000 (2MHz)
                                            chrishamm administrators @HebigT
                                            @jpomo10 Check the SPI connection. This error message indicates that DCS could not receive any data over SPI.
