    Duet 3 and jetson Nano?
    111
    8.9k
    • hanshogelandundefined
      hanshogeland @gtj0
      @gtj0 said in Duet 3 and jetson Nano?:
      etc/apt/sources.list.d/duet3d.lis
      Yes, Iยดve been thinking about this for a while and just like that the update I was waiting for :)!
      Followed your instructions and it worked like a charm, thank you so much.
      • gtj0undefined
        gtj0
        Those packages have been up there for a while now but both @chrishamm and I forgot to tell anyone. ๐Ÿ™‚
        • HebigTundefined
          HebigT
          @gtj0
          I did a fresh install (both L4T & DSF) and I'm running into an issue:
          Monitoring DCS shows "Kernel SPI buffer" warning & "Duet is not available"
          jpomo@jpomo-desktop:~$ sudo /opt/dsf/bin/DuetControlServer
          Duet Control Server v1.2.3.0
          Written by Christian Hammacher for Duet3D
          Licensed under the terms of the GNU Public License Version 3
          [info] Settings loaded
          [info] Environment initialized
          **[warn] Kernel SPI buffer size is smaller than RepRapFirmware buffer size (4096 configured vs 8192 required)
          [error] Duet is not available**
          Here are my config files -
          http.json:
            "Logging": {
              "LogLevel": {
                "Default": "Information"
            "Kestrel": {
              "Endpoints": {
                "Http": {
                  "Url": "http://127.0.0.1"
            "KeepAliveInterval": 30,
            "ModelRetryDelay": 5000,
            "UseCors": true,
            "UseStaticFiles": true,
            "SocketPath": "/var/run/dsf/dcs.sock",
            "WebSocketBufferSize": 8192
          config.json
            "LogLevel": "info",
            "SocketDirectory": "/var/run/dsf",
            "SocketFile": "dcs.sock",
            "Backlog": 4,
            "SocketPollInterval": 2000,
            "BaseDirectory": "/opt/dsf/sd",
            "HostUpdateInterval": 4000,
            "ConfigUpdateInterval": 5000,
            "MaxMessageAge": 60.0,
            "SpiDevice": "/dev/spidev0.0",
            "SpiFrequency": 1000000,
            "SpiTransferTimeout": 500,
            "MaxSpiRetries": 3,
            "SpiPollDelay": 25,
            "GpioChipDevice": "/dev/gpiochip0",
            "TransferReadyPin": 13,
            "BufferedPrintCodes": 32,
            "BufferedMacroCodes": 16,
            "MaxBufferSpacePerChannel": 1536,
            "ModelUpdateInterval": 125,
            "MaxMachineModelLockTime": -1,
            "FileInfoReadLimitHeader": 12288,
            "FileInfoReadLimitFooter": 262144,
            "MaxLayerHeight": 0.9,
          Additonally,
          sudo systemctl status duetcontrolserver:
          jpomo@jpomo-desktop:~$ sudo systemctl status duetcontrolserver
          โ— duetcontrolserver.service - Duet Control Server
             Loaded: loaded (/usr/lib/systemd/system/duetcontrolserver.service; enabled; vendor preset: ena
             Active: active (running) since Mon 2020-01-13 13:09:55 MST; 589ms ago
           Main PID: 17421 (DuetControlServ)
              Tasks: 9 (limit: 4182)
             CGroup: /system.slice/duetcontrolserver.service
                     โ””โ”€17421 /opt/dsf/bin/DuetControlServer
          Jan 13 13:09:55 jpomo-desktop systemd[1]: Started Duet Control Server.
          Jan 13 13:09:56 jpomo-desktop DuetControlServer[17421]: Duet Control Server v1.2.3.0
          Jan 13 13:09:56 jpomo-desktop DuetControlServer[17421]: Written by Christian Hammacher for Duet3D
          Jan 13 13:09:56 jpomo-desktop DuetControlServer[17421]: Licensed under the terms of the GNU Publi
          sudo systemctl status duetwebserver:
          โ— duetwebserver.service - Duet Web Server
             Loaded: loaded (/usr/lib/systemd/system/duetwebserver.service; enabled; vendor preset: enabled)
             Active: active (running) since Mon 2020-01-13 12:52:11 MST; 18min ago
           Main PID: 4592 (DuetWebServer)
              Tasks: 19 (limit: 4182)
             CGroup: /system.slice/duetwebserver.service
                     โ””โ”€4592 /opt/dsf/bin/DuetWebServer
          Jan 13 13:10:26 jpomo-desktop DuetWebServer[4592]:    at System.Net.Sockets.Socket.Connect(EndPoint remoteEP)
          Jan 13 13:10:26 jpomo-desktop DuetWebServer[4592]:    at DuetAPIClient.BaseConnection.Connect(ClientInitMessage initMessage, String socketPath, CancellationToken cancellationToken
          Jan 13 13:10:26 jpomo-desktop DuetWebServer[4592]:    at DuetWebServer.Services.ModelObserver.Execute() in /home/christian/duet/DuetSoftwareFramework/src/DuetWebServer/Services/Mo
          Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]: warn: DuetWebServer.Services.ModelObserver[0]
          Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]:       Failed to synchronize machine model
          Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]: System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requested address /var/run/dsf/dcs.sock
          Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]:    at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
          Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]:    at System.Net.Sockets.Socket.Connect(EndPoint remoteEP)
          Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]:    at DuetAPIClient.BaseConnection.Connect(ClientInitMessage initMessage, String socketPath, CancellationToken cancellationToken
          Jan 13 13:10:31 jpomo-desktop DuetWebServer[4592]:    at DuetWebServer.Services.ModelObserver.Execute() in /home/christian/duet/DuetSoftwareFramework/src/DuetWebServer/Services/Mo
          As far as I know, I have set the correct GPIO pin and SPI frequency.
          Any advice is appreciated!
          • chrishammundefined
            chrishamm administrators
            Have a look at the note in https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Enabling_SPI I haven't tested this on a Jetson Nano, though.
            Duet software engineer
            • gtj0undefined
              gtj0
              @jpomo10 It's an easy fix...
              Create a file named /etc/modprobe.d/spidev.conf and put 1 line in it...
              options spidev bufsiz=8192
              Then reboot. You should be good to go after that.
              • HebigTundefined
                HebigT
                @chrishamm @gtj0
                Thank you for your help on this.
                This fixed the buffersize problem, but still getting Duet is not available:
                Any other ideas of what might be causing it?
                Thanks!
                • gtj0undefined
                  gtj0
                  What's the contents of /opt/dsf/conf/config.json ?
                  Also start duetcontrolserver with -l debug
                  HebigTundefined 1 Reply Last reply Reply Quote 0
                    My best guess is that you don't have the GPIO pin for the transfer ready line configured yet. Unfortunately this part is a bit counter-intuitive because the pin index in the gpiochip device likely varies from the sysfs index but with the right tool you can dump the indices and figure out what device/index you need to use.
                    • HebigTundefined
                      HebigT @gtj0
                      @gtj0
                        "LogLevel": "info",
                        "Backlog": 4,
                        "SpiFrequency": 500000,
                        "MaxSpiRetries": 3,
                        "SpiPollDelay": 25,
                        "LayerHeightFilters": [
                            "Pattern": "layer_height\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))",
                            "Options": 17
                            "Pattern": "Layer height\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))",
                            "Options": 17
                            "Pattern": "layerHeight\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))",
                            "Options": 17
                            "Pattern": "layer_thickness_mm\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))",
                            "Options": 17
                            "Pattern": "layerThickness\\D\u002B(?\u003Cmm\u003E(\\d\u002B\\.?\\d*))",
                            "Options": 17
                        "FilamentFilters": [
                            "Pattern": "filament used\\D\u002B(((?\u003Cmm\u003E\\d\u002B\\.?\\d*)mm)(\\D\u002B)?)\u002B",
                            "Options": 17
                            "Pattern": "filament used\\D\u002B(((?\u003Cm\u003E\\d\u002B\\.?\\d*)m([^m]|$))(\\D\u002B)?)\u002B",
                            "Options": 17
                            "Pattern": "material\\#\\d\u002B\\D\u002B(?\u003Cmm\u003E\\d\u002B\\.?\\d*)",
                            "Options": 17
                            "Pattern": "filament length\\D\u002B(((?\u003Cmm\u003E\\d\u002B\\.?\\d*)\\s*mm)(\\D\u002B)?)\u002B",
                            "Options": 17
                            "Pattern": "Filament used per extruder:\\r\\n;\\s*(?\u003Cname\u003E.\u002B)\\s\u002B=\\s*(?\u003Cmm\u003E[0-9.]\u002B)",
                            "Options": 17
                        "GeneratedByFilters": [
                            "Pattern": "generated by\\s\u002B(.\u002B)",
                            "Options": 17
                            "Pattern": ";\\s*Sliced by\\s\u002B(.\u002B)",
                            "Options": 17
                            "Pattern": ";\\s*(KISSlicer.*)",
                            "Options": 17
                            "Pattern": ";\\s*Sliced at:\\s*(.\u002B)",
                            "Options": 17
                            "Pattern": ";\\s*Generated with\\s*(.\u002B)",
                            "Options": 17
                        "PrintTimeFilters": [
                            "Pattern": "estimated printing time = ((?\u003Ch\u003E(\\d\u002B))h\\s*)?((?\u003Cm\u003E(\\d\u002B))m\\s*)?((?\u003Cs\u003E(\\d\u002B))s)?",
                            "Options": 17
                            "Pattern": ";TIME:(?\u003Cs\u003E(\\d\u002B\\.?\\d*))",
                            "Options": 17
                            "Pattern": "Build time: ((?\u003Ch\u003E\\d\u002B) hours\\s*)?((?\u003Cm\u003E\\d\u002B) minutes\\s*)?((?\u003Cs\u003E(\\d\u002B) seconds))?",
                            "Options": 17
                            "Pattern": "Estimated Build Time:\\s\u002B((?\u003Ch\u003E(\\d\u002B\\.?\\d*)) hours\\s*)?((?\u003Cm\u003E(\\d\u002B\\.?\\d*)) minutes\\s*)?((?\u003Cs\u003E(\\d\u002B\\.?\\d*)) seconds)?",
                            "Options": 17
                        "SimulatedTimeFilters": [
                            "Pattern": "; Simulated print time\\D\u002B(?\u003Cs\u003E(\\d\u002B\\.?\\d*))",
                            "Options": 17
                      • gtj0undefined
                        gtj0 @chrishamm
                        @chrishamm Yeah I know which one he needs to use.
                        • gtj0undefined
                          gtj0
                          And yeah, 13 is the right pin on the nano
                            AFAIR I used this guide to figure out the right gpiochip index. You can further diagnose why DCS cannot connect by launching it with the --log-level debug parameter.
                            • gtj0undefined
                              gtj0
                              @jpomo10 Turn on debug from the command line or the "LogLevel" in config.json
                              • HebigTundefined
                                HebigT
                                @chrishamm @gtj0
                                [debug] Lost connection to Duet
                                   System.OperationCanceledException: Board is not available (no header)
                                   at DuetControlServer.SPI.DataTransfer.ExchangeHeader() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 965
                                   at DuetControlServer.SPI.DataTransfer.PerformFullTransfer(Boolean mustSucceed) in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 154
                                • gtj0undefined
                                  gtj0
                                  Hmmm. Your SpiFrequency is actually on the low side. Try increasing it to 2000000 (2MHz)
                                    chrishamm administrators @HebigT
                                    @jpomo10 Check the SPI connection. This error message indicates that DCS could not receive any data over SPI.
                                    • HebigTundefined
                                      HebigT @chrishamm
                                      @chrishamm @gtj0
                                      OK, I increased SPI to 2MHz but no change.
                                      To rule-out hardware problems, I set-up a raspberry pi according to the instructions in the getting started guide.
                                      I was able to connect to the Duet3 (thermistors and endstops were reading correctly) but the Duet never responds to gcode sent through the console. e.g. M122 just hangs forever with no response.
                                      I had the exact same problem with the Jetson before I did my fresh install.
                                        Do you have RRF 3.0 (non-beta) installed on the Duet 3? If yes, please share your config.g.
                                        • HebigTundefined
                                          HebigT @chrishamm
                                          @chrishamm
                                          Yes, I'm running 3.0 I'll downgrade today to see if that fixes the issue.
                                          M115
                                          FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet 3 MB6HC FIRMWARE_DATE: 2020-01-03b3<LF>ok<LF>
                                          ; generated by RepRapFirmware Configuration Tool v2.1.5 on Thu Jan 09 2020 15:58:52 GMT-0700 (Mountain Standard Time)
                                          G90                                                              ; send absolute coordinates...
                                          M83                                                              ; ...but relative extruder moves
                                          M550 P"Duet 3"                                                   ; set printer name
                                          M667 S1                                                          ; select CoreXY mode
                                          M569 P0.0 S1                                                     ; physical drive 0.0 goes forwards
                                          M569 P0.2 S1                                                     ; physical drive 0.2 goes forwards
                                          M569 P0.1 S1                                                     ; physical drive 0.1 goes forwards
                                          M569 P0.5 S1                                                     ; physical drive 0.5 goes forwards
                                          M569 P0.3 S1                                                     ; physical drive 0.3 goes forwards
                                          M569 P0.4 S1                                                     ; physical drive 0.4 goes forwards
                                          M584 X0.0 Y0.2 Z0.1 E0.5:0.3:0.4                                 ; set drive mapping
                                          M350 X16 Y16 Z16 E16:16:16 I1                                    ; configure microstepping with interpolation
                                          M92 X100.00 Y100.00 Z1600.00 E409.00:409.00:100.00               ; set steps per mm
                                          M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00                ; set maximum instantaneous speed changes (mm/min)
                                          M203 X30000.00 Y30000.00 Z1200.00 E300000.00:300000.00:300000.00 ; set maximum speeds (mm/min)
                                          M201 X6000.00 Y6000.00 Z400.00 E2500.00:2500.00:500.00           ; set accelerations (mm/s^2)
                                          M906 X1400 Y1400 Z1000 E1000:1000:400 I30                        ; set motor currents (mA) and motor idle factor in per cent
                                          M84 S120                                                         ; Set idle timeout
                                          M208 X-35 Y-49 Z0 S1                                             ; set axis minima
                                          M208 X328.5 Y243 Z300 S0                                         ; set axis maxima
                                          M574 X1 S0 P"io6.in"                                             ; configure active-low endstop for low end on X via pin io6.in
                                          M574 Y1 S0 P"io7.in"                                             ; configure active-low endstop for low end on Y via pin io7.in
                                          M574 Z1 S1 P"io8.in"                                             ; configure active-high endstop for low end on Z via pin io8.in
                                          M558 P5 C"io5.in" H5 F120 T6000                                  ; set Z probe type to switch and the dive height + speeds
                                          G31 P500 X0 Y0 Z2.5                                              ; set Z probe trigger value, offset and trigger height
                                          M557 X-20:215 Y-34:195 S20                                       ; define mesh grid
                                          M308 S0 P"temp0" Y"thermistor" T100000 B4138                     ; configure sensor 0 as thermistor on pin temp0
                                          M950 H0 C"out0" T0                                               ; create bed heater output on out0 and map it to sensor 0
                                          M143 H0 S210                                                     ; set temperature limit for heater 0 to 210C
                                          M307 H0 B1 S1.00                                                 ; enable bang-bang mode for the bed heater and set PWM limit
                                          M140 H0                                                          ; map heated bed to heater 0
                                          M308 S1 P"temp1" Y"thermistor" T100000 B4725                     ; configure sensor 1 as thermistor on pin temp1
                                          M950 H1 C"out1" T1                                               ; create nozzle heater output on out1 and map it to sensor 1
                                          M143 H1 S300                                                     ; set temperature limit for heater 1 to 300C
                                          M307 H1 B0 S1.00                                                 ; disable bang-bang mode for the nozzle heater and set PWM limit
                                          M308 S2 P"temp2" Y"thermistor" T100000 B4725                     ; configure sensor 2 as thermistor on pin temp2
                                          M950 H2 C"out2" T2                                               ; create nozzle heater output on out2 and map it to sensor 2
                                          M143 H2 S300                                                     ; set temperature limit for heater 2 to 300C
                                          M307 H2 B0 S1.00                                                 ; disable bang-bang mode for the nozzle heater and set PWM limit
                                          M950 F0 C"out4" Q500                                             ; create fan 0 on pin out4 and set its frequency
                                          M106 P0 S0 H-1                                                   ; set fan 0 value. Thermostatic control is turned off
                                          M950 F1 C"out5" Q500                                             ; create fan 1 on pin out5 and set its frequency
                                          M106 P1 S0 H-1                                                   ; set fan 1 value. Thermostatic control is turned off
                                          M950 F2 C"out7" Q500                                             ; create fan 2 on pin out7 and set its frequency
                                          M106 P2 S1 H1 T45                                                ; set fan 2 value. Thermostatic control is turned on
                                          M950 F3 C"out8" Q500                                             ; create fan 3 on pin out8 and set its frequency
                                          M106 P3 S1 H2 T45                                                ; set fan 3 value. Thermostatic control is turned on
                                          M563 P0 S"L-Hemera" D0 H1 F0                                     ; define tool 0
                                          G10 P0 X0 Y0 Z0                                                  ; set tool 0 axis offsets
                                          G10 P0 R0 S0                                                     ; set initial tool 0 active and standby temperatures to 0C
                                          M563 P1 S"R-Hemera" D1 H2 F1                                     ; define tool 1
                                          G10 P1 X0 Y0 Z0                                                  ; set tool 1 axis offsets
                                          G10 P1 R0 S0                                                     ; set initial tool 1 active and standby temperatures to 0C
                                          M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"               ; set voltage thresholds and actions to run on power loss
                                            @jpomo10 Don't downgrade, the recommended RRF version is still 3.0. I just tried to use your config.g on my Duet 3 / Raspi and I can still execute commands when config.g has been processed. Also make sure the diag LED on the Duet 3 blinks when powered on.
                                            If the error message in the DCS log remains "no header" then I can only say that the Jetson does not receive any SPI data. Perhaps it's best to check your SPI connection once more.
