    Fan on second heater output
    1.1k
      deckingman @peterfrosta
      @peterfrosta I'm not sure that I fully understand the problem but for info, it's the negative side that gets switched to provide PWM (the positive side will always be at whatever voltage the heater runs at).
        A Former User
        @peterfrosta said in Fan on second heater output:
        how can I set the second heater output as Fan for the print colling fan (pwm)?
        guessing you're still using 2.x firmware since you're asking?
          dc42 administrators @peterfrosta
          @peterfrosta, if you are running firmware 2.x then you must first disable that heater using M307, then move a fan to it using the M106 A parameter. With firmware 3.x you just use M950 to create a new fan on that output.
          • peterfrostaundefined
            peterfrosta
            Thank for your replies.
            I got not notification, so i noticing it just now.
            @deckingman said in Fan on second heater output:
            that is clear but thanks!
            @bearer said in Fan on second heater output:
            @dc42 said in Fan on second heater output:
            that's right. in the meanwhile i did update with:
            https://github.com/dc42/RepRapFirmware/releases/download/3.0/Duet2CombinedFirmware.bin
            https://github.com/dc42/RepRapFirmware/releases/download/3.0/DuetWiFiServer.bin
            Result:
            Board: Duet WiFi 1.02 or later
            Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.0 (2020-01-03b3)
            Duet WiFi Server Version: 1.23
            But know i ran in other problems.
            My Heater (Hotend and Bed) don't work anymore.
            i guess i have to do a new thread at first?
            @dc42 thank for this information. Actually i don't know the exact howto but i hope i will check it with the gcode references and your M950 tip.
            thanks!
              jay_s_uk
              Add M140 H0 to your config
              peterfrostaundefined 1 Reply Last reply Reply Quote 0
                peterfrosta @jay_s_uk
                ah mistake.. the tempsensors not the heater...
                tempsens from heater is n/a.
                The tempsens from the bed is -273,1 °C. Welcome in new physics xD
                @jay_s_uk said in Fan on second heater output:
                How would this help? Thats set a temperature for the heater?!
                  jay_s_uk @peterfrosta
                  @peterfrosta Can you provide your latest config.g?
                    @jay_s_uk sure.
                    i did not change anything after updateing or short before...
                    config.g
                      jay_s_uk
                      @peterfrosta
                      You have a lot of changes to make around your heaters, fans and zprobe code.
                      I would suggest using the RRF config tool to generate a new file and then modify it to match your old config.
                        @jay_s_uk thx for tip.
                        it seems that Version 3 need a new V3 compatible config.
                        Now ihave the temp values.
                        Unluckily i got new problems.
                        When i try to home one axis (eg X) it set the x value insteadly to the lower X limit (-7mm).
                        If i click a second one on the X home button i set x Value to -413 and got the error msg:
                        "G28 X
                        G0/G1: insufficent axes homed"
                        i tried active low and active high - same result.
                        M574 X1 S0 P"xstop"
                        M574 X2 S0 P"xstop"
                          peterfrosta
                          ; homex.g
                          ; called to home the X axis
                          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Jan 17 2020 14:46:51 GMT+0100 (Mitteleuropäische Normalzeit)
                          G91               ; relative positioning
                          G1 H2 Z5 F6000    ; lift Z relative to current position
                          G1 H1 X-405 F2400 ; move quickly to X axis endstop and stop there (first pass)
                          G1 X5 F6000       ; go back a few mm
                          G1 H1 X-405 F360  ; move slowly to X axis endstop once more (second pass)
                          G1 H2 Z-5 F6000   ; lower Z again
                          G90               ; absolute positioning
                            peterfrosta
                            G90                                                    ; send absolute coordinates...
                            M83                                                    ; ...but relative extruder moves
                            M550 P"Tronxy"                                         ; set printer name
                            M667 S1                                                ; select CoreXY mode
                            M552 S1                                                ; enable network
                            M586 P0 S1                                             ; enable HTTP
                            M586 P1 S1                                             ; enable FTP
                            M586 P2 S1                                             ; enable Telnet
                            M569 P0 S1                                             ; physical drive 0 goes forwards
                            M569 P1 S1                                             ; physical drive 1 goes forwards
                            M569 P2 S1                                             ; physical drive 2 goes forwards
                            M569 P3 S1                                             ; physical drive 3 goes forwards
                            M584 X0 Y1 Z2 E3                                       ; set drive mapping
                            M350 X16 Y16 Z16 E16 I1                                ; configure microstepping with interpolation
                            M92 X80.66 Y80.32 Z397.61 E389.00                      ; set steps per mm
                            M566 X1500.00 Y1500.00 Z180.00 E348.00                 ; set maximum instantaneous speed changes (mm/min)
                            M203 X18000.00 Y18000.00 Z1980.00 E9000.00             ; set maximum speeds (mm/min)
                            M201 X1500.00 Y1500.00 Z200.00 E1000.00                ; set accelerations (mm/s^2)
                            M906 X1000 Y1000 Z1000 E1200 I35                       ; set motor currents (mA) and motor idle factor in per cent
                            M84 S30                                                ; Set idle timeout
                            M208 X-8 Y-17 Z0 S1                                       ; set axis minima
                            M208 X400 Y360 Z390 S0                                 ; set axis maxima
                            M574 X1 S0 P"xstop"                                    ; configure active-low endstop for low end on X via pin xstop
                            M574 Y1 S0 P"ystop"                                    ; configure active-low endstop for low end on Y via pin ystop
                            M574 Z1 S2                                             ; configure Z-probe endstop for low end on Z
                            M558 P1 C"zprobe.in+zprobe.mod" H5 F120 T6000          ; set Z probe type to unmodulated and the dive height + speeds
                            G31 P500 X-30 Y5 Z1.6                                  ; set Z probe trigger value, offset and trigger height
                            M556 S50 X0 Y0 Z0                                      ; set orthogonal axis compensation parameters
                            M557 X52:350 Y30:350 S20                               ; define mesh grid
                            M308 S0 P"bedtemp" Y"thermistor" T102400 B4138         ; configure sensor 0 as thermistor on pin bedtemp
                            M950 H0 C"bedheat" T0                                  ; create bed heater output on bedheat and map it to sensor 0
                            M143 H0 S120                                           ; set temperature limit for heater 0 to 120C
                            M307 H0 B0 S1.00                                       ; disable bang-bang mode for the bed heater and set PWM limit
                            M140 H0						       ; map heated bed to heater 0
                            M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                            M950 H1 C"e0heat" T1                                   ; create nozzle heater output on e0heat and map it to sensor 1
                            M143 H1 S280                                           ; set temperature limit for heater 1 to 280C
                            M307 H1 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
                            M950 F0 C"fan0" Q500                                   ; create fan 0 on pin fan0 and set its frequency
                            M106 P0 S0 H-1                                         ; set fan 0 value. Thermostatic control is turned off
                            M950 F1 C"fan1" Q500                                   ; create fan 1 on pin fan1 and set its frequency
                            M106 P1 S1 H1 T45                                      ; set fan 1 value. Thermostatic control is turned on
                            M563 P0 D0 H1 F0:1                                     ; define tool 0
                            G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
                            G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
                            ; Custom settings
                            ;Tappering
                            M376 H10			                                            ; Bettkompensation läuft über 10mm Linear aus
                              peterfrosta
                              If i understand this correctly
                              https://duet3d.dozuki.com/Wiki/FAQ#Section_I_get_this_error_message_Error_G0_G1_insufficient_axes_homed
                              i have two options, both need to change the fresh created config from the WebConfigurator,hm...
                              Option 1:
                              change in the homex.g
                              to
                              G1 S1 X-405 F2400 ; move quickly to X axis endstop and stop there (first pass)
                              Option 2:
                              add "M564 H0"
                              at the begin of homex.g
                              Am i right?
                                peterfrosta
                                ok.
                                Option 1 ist no option.
                                I got this warning and same situation about x value (set to -8mm - and no movment)
                                G28 X
                                Warning: Obsolete use of S parameter on G1 command. Use H parameter instead.
                                  peterfrosta
                                  heating also not working 😞
                                  Error: Heating fault on heater 0, temperature rising much more slowly than the expected 1.8°C/sec
                                  what's happend with this update process?
                                    jay_s_uk
                                    @peterfrosta
                                    You'll need to PID tune your heaters (hotend and bed) using M303
                                      Option 1:
                                      to
                                      That won't help. You can use either S1 or H1, but in RRF3 you will get an warning if you use S1.
                                      Option 2:
                                      add "M564 H0"
                                      A better solution is to find the move that you are doing before the corresponding axis is homed, and add the H2 parameter to that move. Typically it is something like: G1 Z5
                                        peterfrosta
                                        i got run.
                                        i was not firm with the ne config/gcode that expected from V3.
                                        Unlucky, that the config generator does not import the most settings from my old config.
                                        the problem with movement was the missing inverting from endstops (motor movement was also not inverted as needed).
                                        I tried with line from old config but they doesn't work anymore.
                                        Using new invert style for endstops and i was checking the effects.
                                        M574 X1 S1 P"!xstop"
                                        thanks to all
