Fan on second heater output
Thank for your replies.
I got not notification, so i noticing it just now.
@deckingman said in Fan on second heater output:
@peterfrosta I'm not sure that I fully understand the problem but for info, it's the negative side that gets switched to provide PWM (the positive side will always be at whatever voltage the heater runs at).
that is clear but thanks!
@bearer said in Fan on second heater output:
guessing you're still using 2.x firmware since you're asking?
@dc42 said in Fan on second heater output:
@peterfrosta, if you are running firmware 2.x then you must first disable that heater using M307, then move a fan to it using the M106 A parameter. With firmware 3.x you just use M950 to create a new fan on that output.that's right. in the meanwhile i did update with:
https://github.com/dc42/RepRapFirmware/releases/download/3.0/Duet2CombinedFirmware.bin
https://github.com/dc42/RepRapFirmware/releases/download/3.0/DuetWiFiServer.binResult:
Board: Duet WiFi 1.02 or later
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.0 (2020-01-03b3)
Duet WiFi Server Version: 1.23But know i ran in other problems.
My Heater (Hotend and Bed) don't work anymore.
i guess i have to do a new thread at first?
@dc42 thank for this information. Actually i don't know the exact howto but i hope i will check it with the gcode references and your M950 tip.
thanks!
Add M140 H0 to your config
ah mistake.. the tempsensors not the heater...
tempsens from heater is n/a.
The tempsens from the bed is -273,1 °C. Welcome in new physics xD@jay_s_uk said in Fan on second heater output:
How would this help? Thats set a temperature for the heater?! -
@peterfrosta Can you provide your latest config.g?
You have a lot of changes to make around your heaters, fans and zprobe code.
I would suggest using the RRF config tool to generate a new file and then modify it to match your old config.
@jay_s_uk thx for tip.
it seems that Version 3 need a new V3 compatible config.
Now ihave the temp values.Unluckily i got new problems.
When i try to home one axis (eg X) it set the x value insteadly to the lower X limit (-7mm).
If i click a second one on the X home button i set x Value to -413 and got the error msg:
"G28 X
G0/G1: insufficent axes homed"i tried active low and active high - same result.
M574 X1 S0 P"xstop"
M574 X2 S0 P"xstop" -
; homex.g ; called to home the X axis ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Jan 17 2020 14:46:51 GMT+0100 (Mitteleuropäische Normalzeit) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-405 F2400 ; move quickly to X axis endstop and stop there (first pass) G1 X5 F6000 ; go back a few mm G1 H1 X-405 F360 ; move slowly to X axis endstop once more (second pass) G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Jan 17 2020 14:46:51 GMT+0100 (Mitteleuropäische Normalzeit) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Tronxy" ; set printer name M667 S1 ; select CoreXY mode ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S1 ; enable FTP M586 P2 S1 ; enable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.66 Y80.32 Z397.61 E389.00 ; set steps per mm M566 X1500.00 Y1500.00 Z180.00 E348.00 ; set maximum instantaneous speed changes (mm/min) M203 X18000.00 Y18000.00 Z1980.00 E9000.00 ; set maximum speeds (mm/min) M201 X1500.00 Y1500.00 Z200.00 E1000.00 ; set accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E1200 I35 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X-8 Y-17 Z0 S1 ; set axis minima M208 X400 Y360 Z390 S0 ; set axis maxima ; Endstops M574 X1 S0 P"xstop" ; configure active-low endstop for low end on X via pin xstop M574 Y1 S0 P"ystop" ; configure active-low endstop for low end on Y via pin ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M558 P1 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds G31 P500 X-30 Y5 Z1.6 ; set Z probe trigger value, offset and trigger height M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters M557 X52:350 Y30:350 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T102400 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0:1 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings ;Tappering M376 H10 ; Bettkompensation läuft über 10mm Linear aus
If i understand this correctly
https://duet3d.dozuki.com/Wiki/FAQ#Section_I_get_this_error_message_Error_G0_G1_insufficient_axes_homed
i have two options, both need to change the fresh created config from the WebConfigurator,hm...Option 1:
change in the homex.gG1 H1 X-405 F2400 ; move quickly to X axis endstop and stop there (first pass)
to
G1 S1 X-405 F2400 ; move quickly to X axis endstop and stop there (first pass)
Option 2:
add "M564 H0"
at the begin of homex.gAm i right?
ok.
Option 1 ist no option.I got this warning and same situation about x value (set to -8mm - and no movment)
G28 X Warning: Obsolete use of S parameter on G1 command. Use H parameter instead. Warning: Obsolete use of S parameter on G1 command. Use H parameter instead.
heating also not working
Error: Heating fault on heater 0, temperature rising much more slowly than the expected 1.8°C/sec
what's happend with this update process?
@peterfrosta
You'll need to PID tune your heaters (hotend and bed) using M303 -
@peterfrosta said in Fan on second heater output:
to
That won't help. You can use either S1 or H1, but in RRF3 you will get an warning if you use S1.
Option 2:
add "M564 H0"
at the begin of homex.gA better solution is to find the move that you are doing before the corresponding axis is homed, and add the H2 parameter to that move. Typically it is something like: G1 Z5
i got run.
i was not firm with the ne config/gcode that expected from V3.
Unlucky, that the config generator does not import the most settings from my old config.the problem with movement was the missing inverting from endstops (motor movement was also not inverted as needed).
I tried with line from old config but they doesn't work anymore.Using new invert style for endstops and i was checking the effects.
M574 X1 S1 P"!xstop"
thanks to all
