    CR-10S5 Firmware
    Firmware installation
    15
    145
    8.5k
      Phaedrux Moderator @Gost101
      @Gost101 said in CR-10S5 Firmware:
      M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
      Your screen shot shows the top speed as 8.4mm/s which is basically 500mm/min. So I think you still haven't removed the limiting start gcode from cura. Follow the directions that @PaulHew has given.
      Once that change is made it will only apply to newly sliced files. All your previously sliced files will have the slow limits set.
      • Gost101undefined
        Gost101 @Veti
        @Veti I did reboot it. I did find that in cura and deleted it. lol
        • Gost101undefined
          Gost101
          @Phaedrux @PaulHew @Veti Great confusion this printer has caused me, yet more to learn I must. Sorry I have been watching to much star wars. lol.
          • Gost101undefined
            Gost101
            START
            M220 S100 ;Reset Feedrate
            M221 S100 ;Reset Flowrate
            G28 ;Home
            G92 E0 ;Reset Extruder
            G1 Z2.0 F3000 ;Move Z Axis up
            G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
            G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
            G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
            G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
            STOP
            G91 ;Relative positioning
            G1 E-2 F2700 ;Retract a bit
            G1 E-2 Z0.2 F2400 ;Retract and raise Z
            G1 X5 Y5 F3000 ;Wipe out
            G1 Z10 ;Raise Z more
            G90 ;Absolute positionning
            G1 X0 Y{machine_depth} ;Present print
            M106 S0 ;Turn-off fan
            M104 S0 ;Turn-off hotend
            M140 S0 ;Turn-off bed
            M84 X Y E ;Disable all steppers but Z
              And what speeds are set in cura for printing moves?
              • Gost101undefined
                Gost101
                @Phaedrux For this profile it is:PrintSpeedCapture.PNG
                • Gost101undefined
                  Gost101
                  @Phaedrux Regardless of any adjustments to this, it still takes a long time to print. Even after the changes made.
                    Can you post a gcode file somewhere for us to see? And perhaps your current config.g file as it is right now?
                    • Gost101undefined
                      Gost101
                      Heres the benchy file: Benchy GCode
                      ;config.g
                      ; Created by Gost101 on Saturday, September 28th, 2019 at 18:00 (6:00PM for Civs).
                      ; This firmware discussion can be found on duet fourm: https://forum.duet3d.com/topic/11964/cr-10s5-firmware/37
                      ; Contact gost1017@gmail.com for more help.
                      G90                                        ; send absolute coordinates...
                      M83                                        ; ...but relative extruder moves
                      M550 P"A.C.E."                             ; set printer name
                      M669 K0                                    ; select Cartesian mode
                      M551 P"SpaceForceHu2020!!"                 ; set password
                      M552 S1                                    ; enable network
                      M586 P0 S1                                 ; enable HTTP
                      M586 P1 S0                                 ; disable FTP
                      M586 P2 S0                                 ; disable Telnet
                      M569 P0 S1                                 ; X physical drive 0 goes forwards
                      M569 P1 S1                                 ; Y physical drive 1 goes forwards
                      M569 P2 S0                                 ; Z physical drive 2 goes backwards
                      M569 P3 S0                                 ; E physical drive 3 goes forwards
                      M584 X0 Y1 Z2 E3                           ; set drive mapping
                      M350 X16 Y16 Z16 E16 I1                    ; configure microstepping with interpolation
                      M92 X80.00 Y80.00 Z400.00 E408.30          ; set steps per mm
                      M566 X500.00 Y500.00 Z30.00 E1500.00      ; set maximum instantaneous speed changes (mm/min)
                      M203 X10800.00 Y9000.00 Z300.00 E3000.00   ; set maximum speeds (mm/min)
                      M201 X1000.00 Y1000.00 Z500.00 E3000.00      ; set accelerations (mm/s^2)
                      M906 X950 Y950 Z850 E900 I30              ; set motor currents (mA) and motor idle factor in per cent
                      M84 S30                                    ; Set idle timeout
                      M208 X0:500 Y0:500 Z0:500                  ; set axis maxima
                      M574 X1 Y1 Z1 S1                           ; set active high endstops
                      M558 P0 H5 F120 T6000                      ; disable Z probe but set dive height, probe speed and travel speed
                      M557 X15:215 Y15:195 S20                   ; define mesh grid
                      M305 P0 T100000 B3950 R4700                ; set thermistor + ADC parameters for the heated bed
                      M143 H0 S120                               ; set temperature limit for heater 0 to 120C
                      M305 P1 T100000 B4725 C7.060000e-8 R4700   ; set thermistor + ADC parameters for heater 1
                      M143 H1 S550                               ; set temperature limit for heater 1 to 550C
                      M106 P0 S0 I0 F500 H-1                     ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                      M106 P1 S1 I0 F500 H1 T45                  ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                      M563 P0 D0 H1 F0                           ; define tool 0
                      G10 P0 X0 Y0 Z0                            ; set tool 0 axis offsets
                      G10 P0 R0 S40                              ; set initial tool 0 active and standby temperatures to 40C
                        Cura has the option for having the first couple layers after the first layer slowly ramping up to full speed. Have you done a full print yet to see if it speeds up? It also has a minimum layer time option which will slow down the print speed to allow for extra cooling time.
                        Would it be possible for you to export your cura print settings so we could see the full settings?
                        Do you have another slicer configured to test against? PrusaSlicer perhaps?
                        • Gost101undefined
                          Gost101
                          @Phaedrux Part of a print, no where near the time of completion it was supposed to be. Sure, here is the Print Settings. I don't have another slicer. Big Rips. Also my cura dosent seem to want to work anymore. It wont launch and I have to reinstall it everytime in order to launch it. I have done a complete un-install as well and this still persists. I keep my congfig files saved.
                          • Vetiundefined
                            Veti
                            first of disable tree support. you dont need that for benchy
                            your inner wall settings is 20mm/sec
                            ;TYPE:WALL-INNER
                            G1 F1200 X252.085 Y243.08 E0.9276
                              If you're on windows you will need to go to %appdata% and rename the cura folder there and then reinstall cura. You may need to re-create your printer and print settings, but it should work properly afterwards.
                              Gost101undefined 1 Reply Last reply Reply Quote 0
                              • Vetiundefined
                                Veti
                                ;SETTING_3 {"extruder_quality": ["[general]\nversion = 4\nname = Super Quality
                                ;SETTING_3 #2\ndefinition = creality_cr10s5\n\n[metadata]\nquality_type = s
                                ;SETTING_3 uper\ntype = quality_changes\nposition = 0\nintent_category = defa
                                ;SETTING_3 ult\nsetting_version = 10\n\n[values]\nbuild_volume_temperature =
                                ;SETTING_3 10\ncoasting_enable = True\ncoasting_volume = 0.4\ndefault_materi
                                ;SETTING_3 al_print_temperature = 210\nfill_outline_gaps = True\ninfill_multip
                                ;SETTING_3 lier = 1\ninfill_overlap = 0\ninfill_pattern = triangles\ninfill_s
                                ;SETTING_3 parse_density = 5\nironing_enabled = True\nlimit_support_retraction
                                ;SETTING_3 s = False\nmaterial_final_print_temperature = 210\nmaterial_initial
                                ;SETTING_3 print_temperature = 210\noptimize_wall_printing_order = True\nretr
                                ;SETTING_3 act_at_layer_change = True\nretraction_amount = 10\nretraction_coun
                                ;SETTING_3 t_max = 0\nretraction_extra_prime_amount = 0\nretraction_extrusion
                                ;SETTING_3 window = 3\nretraction_hop_enabled = True\nretraction_min_travel =
                                ;SETTING_3 0.7\nretraction_prime_speed = 1\nroofing_layer_count = 3\nspeed_pr
                                ;SETTING_3 int = 100\nsupport_angle = 80\nsupport_infill_rate = 5\nsupport_in
                                ;SETTING_3 terface_density = 15\nsupport_interface_height = 1\nsupport_interfa
                                ;SETTING_3 ce_pattern = zigzag\nsupport_interface_skip_height = 1\nsupport_lin
                                ;SETTING_3 e_distance = 5\nsupport_use_towers = True\nswitch_extruder_retracti
                                ;SETTING_3 on_amount = 0\nswitch_extruder_retraction_speeds = 40\ntop_bottom_t
                                ;SETTING_3 hickness = 3\nz_seam_corner = z_seam_corner_inner\nz_seam_type = sh
                                ;SETTING_3 arpest_corner\nzig_zaggify_infill = True\n\n"], "global_quality":
                                ;SETTING_3 "[general]\nversion = 4\nname = Super Quality #2\ndefinition = cre
                                ;SETTING_3 ality_cr10s5\n\n[metadata]\nquality_type = super\ntype = quality_
                                ;SETTING_3 changes\nintent_category = default\nsetting_version = 10\n\n[valu
                                ;SETTING_3 es]\nacceleration_enabled = False\nadhesion_type = raft\ndefault_m
                                ;SETTING_3 aterial_bed_temperature = 50\nflow_rate_extrusion_offset_factor = 95
                                ;SETTING_3 \nflow_rate_max_extrusion_offset = 5\nretraction_combing = off\nsu
                                ;SETTING_3 pport_enable = True\nsupport_type = buildplate\n\n"}
                                you might want to disable that.
                                • Gost101undefined
                                  Gost101 @Phaedrux
                                  @Phaedrux Thanks, that just fixed cura not opening. Cool beans, @Veti don't know why I had tree support turned on. Lol.
                                  • Vetiundefined
                                    Veti
                                    while printing please post the output of the commands M201 till M205
                                    • Gost101undefined
                                      Gost101
                                      @Veti Ill try disabling z retraction.
                                      • Gost101undefined
                                        Gost101 @Veti
                                        @Veti said in CR-10S5 Firmware:
                                        How does one do that?
                                        • Vetiundefined
                                          Veti @Gost101
                                          z retraction.
                                          its called z hob wgeb retracted
                                          • Vetiundefined
                                            Veti @Gost101
                                            @Gost101
                                            in DWC go to console and issue the commands under send commands
