    How do I enable MESH leveling for the print?
    25
    3.6k
    • Rat_Patrolundefined
      Rat_Patrol
      10:24:26 AMM122
      RepRapFirmware for Duet 2 Maestro version 2.05 running on Duet Maestro 1.0
      Board ID: 08DAM-9F9GA-J24TD-6J9F0-3SW6R-K51QV
      Used output buffers: 1 of 24 (14 max)
      Static ram: 19804
      Dynamic ram: 91164 of which 0 recycled
      Exception stack ram used: 336
      Never used ram: 19768
      Tasks: NETWORK(ready,716) HEAT(blocked,1272) MAIN(running,3896) IDLE(ready,160)
      Owned mutexes:
      Last reset 17:18:54 ago, cause: power up
      Last software reset at 2020-01-20 16:37, reason: User, spinning module GCodes, available RAM 19780 bytes (slot 2)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      Free file entries: 10
      SD card 0 detected, interface speed: 15.0MBytes/sec
      SD card longest block write time: 53.1ms, max retries 0
      MCU temperature: min 21.1, current 34.8, max 41.8
      Supply voltage: min 0.0, current 24.2, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: standstill, read errors 0, write errors 0, ifcount 16, reads 2962, timeouts 0
      Driver 1: standstill, read errors 0, write errors 0, ifcount 16, reads 2949, timeouts 13
      Driver 2: standstill, read errors 0, write errors 0, ifcount 16, reads 2962, timeouts 0
      Driver 3: standstill, read errors 0, write errors 0, ifcount 14, reads 2948, timeouts 16
      Driver 4: standstill, read errors 0, write errors 0, ifcount 6, reads 2972, timeouts 0
      Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 2977
      Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 2977
      Date/time: 2020-01-21 10:24:21
      Slowest loop: 147.95ms; fastest: 0.05ms
      Hiccups: 0, FreeDm: 160, MinFreeDm: 130, MaxWait: 56660031ms
      Bed compensation in use: mesh, comp offset 0.073
      === DDARing ===
      Scheduled moves: 12, completed moves: 12, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Bed heaters = 0, chamberHeaters = -1 -1
      Heater 0 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      lcd is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 135.62ms; fastest: 0.02ms
      HTTP sessions: 1 of 8
      Interface state 5, link 100Mbps full duplex
        jay_s_uk
        @Rat_Patrol said in How do I enable MESH leveling for the print?:
        It shows as being active.
        Do you have a picture of your bed mesh?
        How many probe points do you have?
        Do you probe it hot or cold?
          Rat_Patrol
          Pic of probing results:
          Ran MESH at PETG temps.
            Rat_Patrol
            My bed is very uneven at this point: I'm running a temporary Y carriage setup until I get some hardware in to manually level it out.
            Or until I cut up some soda cans 😄
              Rat_Patrol
              Well, I re-sliced and uploaded, and MESH appears to be working now.
              Not doing a great job though, its like my nozzle-to-probe offset is wrong.
              I got the numbers for the offset from Fusion where I modeled all the parts, does my config look good?
              ; Configuration file for Duet Maestro (firmware version 2.03)
              ; generated by RepRapFirmware Configuration Tool v2.1.5 on Thu Jan 09 2020 17:14:50 GMT-0600 (Central Standard Time)
              G90                                      ; send absolute coordinates...
              M83                                      ; ...but relative extruder moves
              M550 P"Robo R1++"                        ; set printer name
              M918 P1 E4 F2000000                      ; configure direct-connect display
              M551 P"xxxxx"                         ; set password
              M552 P0.0.0.0 S1                         ; enable network and acquire dynamic address via DHCP
              M586 P0 S1                               ; enable HTTP
              M586 P1 S0                               ; disable FTP
              M586 P2 S0                               ; disable Telnet
              M569 P0 S1                               ; physical drive 0 goes forwards
              M569 P1 S1                               ; physical drive 1 goes forwards
              M569 P2 S1                               ; physical drive 2 goes forwards
              M569 P3 S1                               ; physical drive 3 goes forwards
              M584 X0 Y1 Z2 E3                         ; set drive mapping
              M350 X16 Y16 Z16 E16 I1                  ; configure microstepping with interpolation
              M92 X80.00 Y80.00 Z400.00 E813.65        ; set steps per mm
              M566 X100.00 Y100.00 Z100 E100      ; set maximum instantaneous speed changes (mm/min)
              M203 X9000.00 Y9000.00 Z720.00 E2100.00  ; set maximum speeds (mm/min)
              M201 X1100.00 Y1100.00 Z1100.00 E3000.00  ; set accelerations (mm/s^2)
              M906 X1500 Y1500 Z1000 E1500 I50          ; set motor currents (mA) and motor idle factor in per cent
              M84 S30                                  ; Set idle timeout
              M208 X0 Y0 Z0 S1                         ; set axis minima
              M208 X210 Y210 Z250 S0                   ; set axis maxima
              M574 X1 Y1 S1                            ; set active high endstops
              M574 Z1 S2                               ; set endstops controlled by probe
              M558 P9 H5 F300 T6000                   ; set Z probe type to bltouch and the dive height + speeds
              G31 P500 X-32.201 Y-26.389 Z3.00                ; set Z probe trigger value, offset and trigger height
              M557 X0:210 Y0:210 S40                   ; define mesh grid
              M305 P0 T100000 B4138 R2200              ; set thermistor + ADC parameters for heater 0
              M143 H0 S120                             ; set temperature limit for heater 0 to 120C
              M305 P1 T100000 B4725 C7.060000e-8 R2200 ; set thermistor + ADC parameters for heater 1
              M143 H1 S280                             ; set temperature limit for heater 1 to 280C
              M106 P0 S0 I0 F500 H-1                   ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
              M106 P1 T45 S1 H1                  ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
              M563 P0 S"Extruder" D0 H1 F0           ; define tool 0
              G10 P0 X0 Y0 Z0                          ; set tool 0 axis offsets
              G10 P0 R0 S0                             ; set initial tool 0 active and standby temperatures to 0C
              devleonundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
              • PaulHewundefined
                PaulHew
                In my experience I manually level the bed using to 4 screws on my ender3.
                I try and make it as level as possible using paper gauge between nozzle and bed.
                Not teaching sucking eggs, I release the x/y steppers so I can move the gantry. Z is jogged down to grip paper, but stepper is engaged.
                The I run the mesh after heating the nozzle to 160 and bed to 60
                I also have 2 mirrors I use. I rename each heightmap to mirror 1 or 2 and call each mirror from cura’s start code.
                • devleonundefined
                  devleon @Rat_Patrol
                  @Rat_Patrol
                  I too had my offset from CAD, but turns out, it's not correct, since tolerances make things imperfect. Put a paper on the Heatbed, and slowly and manually run the nozzle into it, leaving a tiny mark, and also mark where your bed Probe is. Now measure everything and use that.
                  I had the same issue of thinking that mesh bed leveling was doing a bad job, until I remeasured my offset and realized I was off my 10mm.
                    Phaedrux Moderator @Rat_Patrol
                    You can increase the accuracy and repeatability of the BLTouch by tweaking those settings a bit.
                    M558 P5 H5 F100 T6000 R0.5 A5
                    G31 P25
                    Then use this link to calibrate the trigger height and measure the X Y offset for the rest of G31.
                    https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                      droftarts administrators @Phaedrux
                      @Phaedrux said in How do I enable MESH leveling for the print?:
                      G31 P25
                      Don’t you mean M558 P9 H5 F100 T6000 R0.5 A5 ?
                        Phaedrux Moderator @droftarts
                        @droftarts absolutely I did!
                          Rat_Patrol
                          Its not that the initial layer height is just wrong everywhere, some parts of the print have major squish and others are just fine.
                            Rat_Patrol
                            I did run through the BLTouch probe calibration procedure (ended up at 2.95mm IIRC). I designed my extruder carriage, so I just took the probe offset from the nozzle from Fusion, so it should be darned accurate.
                              There was a post just yesterday of someone using the measurement from CAD and then measuring it physically and it was off enough to matter. So at least verify that it's accurate. A bad offset would give results similar to what you see.
                              The slower feed rate of the probe move helps to improve the consistency of the BLTouch and it's forced to have at least 2 probes match which helps reject off values. Again, a variation in probe trigger height could describe what you're seeing.
                                Rat_Patrol
                                Did I input my probe offset correctly in config.g?
                                Compared to X0 Y0, my probe is negative in both axis, so there is actually no way to measure the extreme right side of my bed with the probe.
                                I have the flu, but if I'm thinking properly, the probe offset should be negative, right?
                                  X would be negative based on your description, but I'm not sure about your Y. Negative Y would put the probe in front of the nozzle.
                                    Rat_Patrol
                                    Yes, the probe is in front of the nozzle.
                                    • TaDDragonZundefined
                                      TaDDragonZ
                                      Looks like the same error I have, I will check the probe offset right now.
