Mosfet board vs SSR vs onboard
26
8.2k
    StephenRC
    That cheap ssr will barely let a 12vdc MK2a get above 70C.
    Now, if you go with an AC powered heater, then a DC-AC SSR will have no problems and the heat up time will be short. Mine does the full heat up of bed & hotend less than a few minutes. Of course, you do need to install a thermal fuse on the bed heater for the safety bit.
      mattbenimble
      @T3P3Tony:
      If it is a conventional MK2a (ie the one I adapted from Prusa's original design years ago), with a resistance of 1Ohm then at 12V it will draw 12A which is fine for directly being driven from the Duet.
      That is assuming your power supply can happly provide 12A for the bed+the power for your heaters, fans etc. It may be that D-Bot power specifications work on the idea of having two power supplies one for the bed and one for the heater, in which case look at their capabilities.
      If the heated bed you have is not 1A, specifically if it is going to draw more than 15A then you should use the DC SSR (but make sure you follow the guidance here: https://duet3d.com/wiki/Connecting_a_bed_heater#Bed_heater_driven_using_a_Solid_State_Relay))
      Ive noticed this topic come up a few times, and the documentation referenced does not mention anything about Mosfet expansion boards like the MKS-Mos or BIQU boards (https://www.amazon.com/BIQU-Power-Module-Expansion-Printer/dp/B01HEQVQAK) .
      Can you comment on why this would not be an alternative to the SSR listed in the Duet3D Documentation?
        Fickert
        I do not have my Wifi board yet (Also new member, Hello 🙂 ) but I already have a cheaper bed heater mosfet that I will be using.
        http://www.ebay.com/itm/122028782943?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
        I also have a case fan blowing over it and should provide plenty of cooling to operate at any current draw my bed will take. Small price to pay IMO before hearing your mosfet on the duet fall off.
        I will say even without the fan on it, it stays very cool to bairly even warm in my current setup.
          @mattbenimble:
          That listing gives no specification for that board, nor a schematic for it. Without one or the other, I can't assess its suitability.
            StephenRC
            Found this: http://www.chitu3d.com/3d-printer-parts-general-add-on-heated-bed-power-expansion-module-2/
            After following the url on the circuit board.
            The only spec is 25A max and only mentions 12vdc in determining the load.
              Sethipus
              Some real talk here: with a 12VDC power supply, and a MK2A pcb heated bed (300x200 size) measuring in a 1.3 Ohms resistance, Ohm's Law (V=IR, or I = V/R) tells us that the maximum amperage you're going to be able to draw, excluding any voltage drop through an SSR or mosfet, or any additional resistance of the wiring between the power supply and the heated bed, is around 9.2 A.
              If the Duet Wifi is rated for 15 A safely, then the 8-9A we'll see in practice looks like it's perfectly fine for the Duet Wifi to support.
              As I mentioned above, I might still be interested in an external mosfet board just to offload that power draw from the Duet Wifi itself, just as a protective measure. I'll tell you what, though, I've been running a Duet Wifi on my Maker Select for several months now with nearly constant usage, and it's powering both the nozzle and heated bed, and it's been going like a champ.
              I'm completely satisfied that hooking up the heated bed directly to the heated bed outputs on the Duet Wifi is a reasonable and successfull combination. The only remaining question is whether offloading that power load from the Duet Wifi to an external board is going to gain me any safety or protection of the Duet Wifi to justify the expense.
                Sethipus
                Just for context, there's a reason those external mosfet boards are all the rage right now, and that reason is that the really cheap Melzi boards the Wanhao Di3 & clones have been shipping with have this nasty tendency to burn up their power connectors (this may be a problem with other cheap printers too, but the Di3 line is the one I'm familiar with, and it's a huge deal), because they used really crappy components that simply weren't rated for the load that the printers place on them in practice. That's why people are buying these things up: if they don't, they risk a meltdown on their controller board.
                That doesn't seem to be an issue with the Duet Wifi.
                  T3P3Tony administrators
                  So you are right that any high current will stress any electronics. We had thermal testing conducted on the prototype boards which the results are written up here :
                  http://blog.think3dprint3d.com/2016/07/duetwifi-thermal-testing.html
                  That is where we get the 15A limit from. You will be interested to see the limit is due to the board copper traces rather than the connectors (which are rated to 35A).
                  We have commissioned further testing to continue to check on our production boards so will publish an update. We may be able to raise the stepper driver software limit from 2A to 2.5A but let's see how the testing goes. We are also looking at the bed traces.
                    Sethipus
                    Why do the external mosfet boards and stepper driver boards and whatnot have these massive heatsinks on them, and yet the controllers and chips on the Duet Wifi board don't have any heatsinks, and do just fine?
                    Is it a quality thing, where the controllers and mosfets and whatnot used by the Duet Wifi just aren't dissipating that much heat?
                      Its not one single factor, for example some of the external boards can handle a lot more current than the DuetWifi.
                      Stepper drivers and FETs come with a wide variety of specifications, including on resistance and switching time these effect how much power is dissipated while on, or while turning on/off. There are important interrelating factors - you can get a FET that turns on/off very very quickly (so dissipates less power in the process) but then that very quick on/off switch generates high frequency EMI.
                      You will see from the thermal testing that we have done we know how much current the drivers and FETs (and other components) can take before they reach certain temperatures. We also use a thick copper PCB to help transfer the heat away from the FETs/drivers - the PCB is acting as a heatsink. That's why we recommend a fan blowing on the back of the board for cooling if you are using the drivers/FETs at the top of their power range.
                        Sethipus
                        I'm getting some heatsink adhesive for a different purpose. Would it be worth it to buy some of those tiny copper heatsinks that people put on ram chips on video cards or whatever and gluing them on to the stepper drivers and the mosfet?
                          @Sethipus:
                          Modern surface mount chips have thermal pads underneath them so that heat is transferred to the PCB. The top of the chip is made of plastic and doesn't conduct heat well. So if you are running at high currents close to the limits of the board, use a fan to blow cool air over both sides of the board. Putting heatsinks on top of the chips might actually make things worse if they restrict the flow of air over the PCB.
                            Sethipus
                            Thanks! As we speak I'm working through either a new mount box or a remix of an existing mount for my D-bot. There's one box I like a lot that has good fan provisions, and another box I like better except that the airflow/fan considerations aren't nearly as good. I may have to roll my own and try to have the best of both worlds.
                              deckingman
                              My mount box is here http://www.thingiverse.com/thing:1830918 which takes an internal fan blowing on to the back of the board or this one http://www.thingiverse.com/thing:1859048 which takes both the duet wifi and the expansion board. I included the OpenScad files so you can hack then about to suit. I stuck thermistors on one of the stepper chips on each board and have the fans set thermostatically to come on at 45deg C which makes it silent when idle. HTH
                              • knaboundefined
                                knabo
                                I hope this is the right place for this. I currently have one of the bigger mosfets delivering power to my heated bed controlled by a Duet Wifi. The bed heats great and everything works well. But I found when the heater cycles it does something that causes my extruder to run slower (?) I get a fairly regular thick and then thin extrusion pattern. When I turn off the heated bed, the effect goes away. Is there something I can fix here? I have verified all the wiring and connections.
                                  deckingman
                                  Voltage drop? Running M122 will show if that is the case or not.
                                    I agree, it's probably caused by the voltage at the VIN terminals of the Duet dropping when the bed heater cycles. Some suggestions:
                                    1. Make sure that the screws in the power input terminal block on the Duet are tight.
                                    2. Use a multimeter to measure the voltage at the power supply output terminals with the bed heater both on and off, and also the voltage at the VIN terminal block. If the voltage at the PSU output drops significantly, get a better power supply (cheap ATX power supplies are not very good in this respect). If the voltage at the PSU output remains stable but the voltage at the VIN terminal block drops significantly more, use shorter and/or thicker wires between the PSU and the VIN terminal block.
                                    If you don't have a multimeter, then as Ian mentioned you can use M122 to read the voltage at the VIN terminal block.
                                    3. Switch the bed heater to PID mode.
                                    You've just given me an idea: I could adjust the extruder PWM automatically to compensate for VIN voltage changes.
                                    • knaboundefined
                                      knabo
                                      I have the power supply at the base of the tool and the Duet in the top (converted Rostock Max V2 to V3) I measured the voltage at a terminal strip near the Duet (12 in wire between Duet and terminal strip) during bed heating and I did see a variation 12.01 to 12.05. The heater is in bang bang mode.
                                      I have a meanwell 350W supply
                                      From M122:
                                      Supply voltage: min 11.8, current 12.1, max 12.2, under voltage events: 0, over voltage events: 0
                                      Bed heater = 0, chamber heater = -1
                                      Heater 0 is on, I-accum = 0.0
                                      Heater 1 is on, I-accum = 0.4
                                      I have 12 gauge wire from the PS to the terminal block and to the Duet
                                      With the heater just turned on voltage at the terminal strip, Vin and Bed out all read the same at 12.05
                                      I have 12.66 amps running to the bed through the Mosfet when it is on. There does not seem to be any current running on the control lines from the Duet to the Mosfet. I have 22 gauge wire for the control wires.
                                        OK I misunderstood, I didn't get that you were using an external mosfet to control the bed heater. If the voltage at the Duet really only varies between 12.01 and 12.05 with the bed heater off and on, then I am surprised that it has that much effect on extrusion. OTOH the Duet's own voltage monitor is recording a much bigger variation. If that's the first time you have run M122 since starting the Duet, then the 11.8V figure could be the voltage just after startup. The maximum and minimum recorded voltages are reset whenever you run M122.
                                        Anyway, if the extrusion variation really is caused by power voltage fluctuations affecting the hot end temperature, then switching the bed to PWM should solve it.
                                        If the issue only happens or the first layer or two, then another explanation is that the variation in bed temperature is affecting how the filament flows when it is extruded. Again, switching the bed to PID will solve this.
                                        • knaboundefined
                                          knabo
                                          So switching to PID did solve the problem.
                                          You don't have to read the rest.
                                          I am curious why this happens. On the SeeMeCnc forum one person attributed it to the hot end temperature changing, but my hot end temperature was steady. This is why I assumed there was a changing speed on the extruder.
                                          I am also using a Bondtech extruder, so I wonder if it is more noticeable on a geared extruder.
                                          Does it only happen when you run an SSR or Mosfet? Using these the current on the Duet for the bed heater is very small. Does it happen when running the heater through the Duet?
                                          Anyway, I am finally getting decent prints (I introduced and fixed several issues when converting a Rostock V2 to V3)
                                          I am loving the Duet Wifi.
