    Reading negative temperature and N/A temp
    1.8k
    • johnyundefined
      johny
      After wiring all (duet 2 wifi v1.04) i get the following temp reading:
      what whould it be? i already changed the B value from the gcode, re-wire, it doesn't change.
      Thank you
      • Danalundefined
        Danal
        -273.1 is the "magic number" that indicates a totally open circuit on an input configured for a thermistor. So you have a broken wire, are plugged into the wrong input, or similar.
        johnyundefined 1 Reply Last reply Reply Quote 0
        • johnyundefined
          johny @Danal
          @Danal Thank you for your help; even without anything plugged i get the "magic number", what should this indicate?
          What about the n/a one?
          Thank you
          A Former User? Danalundefined 2 Replies Last reply Reply Quote 0
            A Former User @johny
            @johny said in Reading negative temperature and N/A temp:
            that your thermistor isn't properly connected when you think its connected.
            • Danalundefined
              Danal @johny
              Thank you
              That is exactly what it means: Open circuit; nothing plugged in.
              Not sure about the N/A
                jay_s_uk
                @johny
                What type of thermistors are you connecting and where are you connecting them?
                Please also post your config.g file
                • johnyundefined
                  johny
                  For the heat bed it is the standard thermistors from Chinese heat beds, for the hot end its the one: ATC Semitec 104GT-2/104NT-4-R025H42G (http://www.atcsemitec.co.uk/gt-2-glass-thermistors.html )
                  Gcode:
                  M307 H0 B0 S1.00
                  M305 P0 R4700 T100000 B4267 C0.0000000706
                  M143 H0 S130
                  M305 P1 R4700 T100000 B4267 C0.0000000706
                  M305 P2 R4700 T100000 B4725 C0.0000000706
                  M143 H1 S275
                  M106 P0 S0 I0 F500 H-1
                  M106 P1 S1 I0 F500 H1 T45
                  M106 P2 S1 I0 F500 H-1
                  M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
                  T0 ; select first tool
                    jay_s_uk
                    @johny
                    Apart from having 3 thermistors setup with only 2 heaters, nothing jumps out at me as being odd.
                    Could you take a photo of where you are connecting the thermistors?
                    • johnyundefined
                      johny
                      Regarding to where i am connecting them its according to the wiring, also it is printed in the board E0 temp and bed heater :
                      bead heater
                      hot end heater
                      Edit: i tried to connect to the E1 thermistor as well to check if it works that's why it have 3 thermistors setup
                        jay_s_uk
                        @johny
                        Is the second image correct? that you are attaching the thermistor to the green terminals?
                        • johnyundefined
                          johny
                          no sorry! In that i plug the heater, the thermistor is bellow
                            jay_s_uk
                            I would set the values to the following
                            M305 P0 T10000 B3950 R4700               ; set thermistor + ADC parameters for heater 0
                            M143 H0 S120                             ; set temperature limit for heater 0 to 120C
                            M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
                            M143 H1 S280                             ; set temperature limit for heater 1 to 280C
                            The P0 is a generic 3950 which is what tends to be used by chinese suppliers.
                            The P1 is correct for a 104GT
                            I would remove the P2 as this is probably confusing things.
                            If you're still getting no values, I would revisit your crimping
                            • johnyundefined
                              johny
                              I did those changes and i even solder a pair of wires directly to the bed thermistor to bypass any broken cable, the magic number is still there.
                              Probably is something burn in the board, what could it be?
                              Thank you
                                jay_s_uk
                                You could try remapping the bed thermistor to P2 and connecting to the e1 temp header and see if you get a reading
                                • johnyundefined
                                  johny
                                  I did it, no luck, still same error :S
                                  I unplugged a thermistor from another printer to check it if was the thermistor and the same result.
                                    A Former User
                                    (Don't think there is one)
                                    • johnyundefined
                                      johny
                                      @bearer said in Reading negative temperature and N/A temp:
                                      Well i measure between the vssa and gnd and i got 3 ohms.
                                      I just checked that my heat bed had a short between the +12v and gnd but i got no readings even before plugging it.
                                      • blt3dpundefined
                                        blt3dp
                                        What version of the firmware does M115 report? Might be useful in troubleshooting.
                                        My 3D Printing YouTube Channel
                                        Better Living Through 3D Printing
                                        Follow me on Instagram and Twitter
                                        Instagram
                                        Twitter
                                        • johnyundefined
                                          johny
                                          @blt3dp said in Reading negative temperature and N/A temp:
                                          M115
                                          M115
                                          FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-01-03b3
                                          blt3dpundefined 1 Reply Last reply Reply Quote 0
                                          • blt3dpundefined
                                            blt3dp @johny
                                            That's why you're not getting a reading, you need have to define the pin that it's using.
                                            Instagram
                                            Twitter
