    mesh bed compensation not applying correct corrections
    2.3k
    • necroratundefined
      necrorat
      so deleted the file and reduced the number of probe points and it seems to of accepted the file now,but it still seems to be not applying the mesh correctly. there are inconstant very small gaps between the extruded lines in a couple of patches on the bed so that leads me to believe that something i have borked up in my config. ive checked my extrusion multiplier and calibrated my e steps so at this stage it must be something in my config or associated files.
      • Vetiundefined
        Veti
        @necrorat said in mesh bed compensation not applying correct corrections:
        that is either a problem with under extrusion or backlash in your printer. not a problem with mesh bed leveling.
        necroratundefined 1 Reply Last reply Reply Quote 0
        • necroratundefined
          necrorat @Veti
          @Veti 90% of the bed layer is perfect there are two patches where the gaps are observed so if it was under extrusion or backlash would it not be consistently like that all over the bed with mesh levelling working as it should?
          • Vetiundefined
            Veti
            post a picture
              Phaedrux Moderator @necrorat
              The image seems to show a bowed gantry. What areas are not touching the bed?
              • necroratundefined
                necrorat
                not the best pictures but best i can do at the moment.
                the main area is the region 3 threes what appears to be a island where the print head is too far from the bed
                  Where are those locations in relation to the heightmap?
                    I see you're using the BLTouch. You can attempt to get a bit more accuracy and repeatability out of it by modifying your M558 a bit.
                    M558 P9 H5 F60 T6000 A10 R0.75 S0.003 B1
                    Slower probe speed, with repeated attempts if 2 consecutive probes don't match to within a tighter tolerance. Probing will take longer because of the slower dive height and it will do at least 2 probes per point. But you will be far less likely to get outliers.
                    • necroratundefined
                      necrorat @Phaedrux
                      @Phaedrux so 1 is the rear right of the height map and 3 is the front centre on the height map. sweet thanks for the tip ill change that out and give it a try probably wont be till tomorrow till ill get to try it now though.
                      • Vetiundefined
                        Veti
                        can you measure the z trigger heigh at different positions?
                        it is possible that you have different trigger heights based on position.
                        • necroratundefined
                          necrorat @Veti
                          @Veti so i measured the z trigger height and it didn't vary by more than 0.005mm at each of the 9 points i measured at, it did vary from point to point but thats kinda the point of bed levelling isn't it ?
                          • Vetiundefined
                            Veti @necrorat
                            no the z trigger height has to be constant across the entire bed otherwise you have the effects that you are seeing.
                            to clarify i am not refereing the the result of a G30 but the valude of of Z for G31 when calibrating it.
                            • necroratundefined
                              necrorat @Veti
                              @Veti just ran though a 3x3 grid to check and i am consistently getting 2.31 for the trigger height
                              01/02/2020, 15:16:27 M98 P"0:/macros/probe test"
                              Current reading 0, threshold 25, trigger height 2.31, offsets X-29.5 Y11.4
                              • Vetiundefined
                                Veti @necrorat
                                does that macro do this?
                                https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                                • necroratundefined
                                  necrorat @Veti
                                  @Veti ive wrote it as this to probe 3 times per spot:
                                  G1 Z10
                                  G30 S-1
                                  G1 Z10
                                  G30 S-1
                                  G1 Z10
                                  G30 S-1
                                  • necroratundefined
                                    necrorat
                                    so have just run it again and i am getting quite a large variance now in the region of 0.11mm is this a mechanical issue? the machine is set up on linear rails and i have ensured that they are as square and parallel as possible
                                    • Vetiundefined
                                      Veti @necrorat
                                      G1 Z10
                                      G30 S-1
                                      G1 Z10
                                      G30 S-1
                                      G1 Z10
                                      G30 S-1
                                      that determines repeatability, but does not determine z probe trigger height as you do not determine z=0 before probing as described in the above linked document
                                      • necroratundefined
                                        necrorat @Veti
                                        @Veti so do i have to go though the full calibration procedure for each point that i probe on the bed?
                                        • Vetiundefined
                                          Veti @necrorat
                                          @necrorat
                                          do one at the point where the lines where ok and one where the lines where not ok
                                          • necroratundefined
                                            necrorat @Veti
                                            @Veti so just did a test over 5 point and theses are the results :
                                            2.064
                                            2.068
                                            2.066
                                            2.059
                                            2.046
