Z=0 datum was not determined probing.
2.7k
    Stephenbright
    How do I fix this error? It just started showing up after a firmware update: Duet Maestro M3D Promega
    Warning: the height map was loaded when the current Z=0 datum was not determined probing. This may result in a height offset.
      It means that you have both a Z endstop switch and a Z probe, and you used the endstop switch to home Z. The problem with this arrangement is that the endstop switch and the Z probe need to agree on where Z=0 is. If they don't, then your height map will show a significant offset, corresponding to the different in Z=0 levels. The difference between these two Z=0 levels is likely to be affected by temperature.
      Ways round this include:
      • Ignore it, if you are satisfied that it doesn't cause any problems. The main issue is likely to be that a height map that you produce by probing one day may not work when you load it from the SD card another day, because the difference in Z=0 as seen by the endstop switch and as seen by the Z probe has changed.
      • Instead of using the endstop switch to home Z, use the Z probe. See https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_Z_using_a_Z_probe.
      • After homing Z using the endstop switch, and before either probing (G29 or G29 S0) or loading a height map (G29 S1), do a single G30 probe at/near the centre of the bed.
        Stephenbright
        Thank you !
        This happened after I updated the firmware. It was never an issue before and I'm not sure how or why it's reading the IR probe all of the sudden. I've always used the Z-Probe ( limit switch ) and it worked just fine. How do I disable the IR probing function and should I do that?
          That message is new in the 2.03RC firmware, that's why you didn't have it before.
          I suspect that you have set up your homez.g file and the Z homing section of homeall.g incorrectly. See https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_Z_using_a_Z_probe. Z homing using a Z probe should be done using a G30 command, not a G1 S1 or G1 H1 command.
            Qwelldrin_765
            Hi thanks, for the info but as I havent meshed the bed yet I cant ignore it and using G30 without the switch, the head crashes in to the bed, I have no desire currently to use IR probe. How can I disable it or have the firmware ignore it?
            As above recently updated and now having issues.
              FelixH
              I've been having a similar problem on my Anycubic Kossel for some time now and it has rendered it useless. I already asked on the forum about it, but to no avail, as the map is still not being loaded and some prints just won't stick to the surface. Here is my thread: https://forum.duet3d.com/topic/13286/mesh-grid-compensation-setup-on-initial-gcode?_=1580553217510
              As far as I know I've done everything right...
              undefined 1 Reply Last reply 1 Feb 2020, 16:11 Reply Quote 0
                Phaedrux Moderator @FelixH
                @FelixH Sorry to hear you're still having issues. I'll take another look at your thread.
                undefined 1 Reply Last reply 1 Feb 2020, 16:23 Reply Quote 0
                  FelixH @Phaedrux
                  @Phaedrux I am considering getting a smart effector, but I guess I would have to get the magnetic rods as well and, at the end of the day, I don't know if it would solve the problem because I don't see how it relates to the kind of probe...
                  undefined 1 Reply Last reply 1 Feb 2020, 16:46 Reply Quote 0
                    jay_s_uk @FelixH
                    @FelixH you don't need to use the magnetic rods. There are adapters that can be used to allow the original rods to be used. You'd just need access to a printer that works to print the adatper
