    PanelDue and Motors will not function properly with Duet Wifi
    80
    3.9k
    • firex726undefined
      firex726 @A Former User
      @bearer said in PanelDue and Motors will not function properly with Duet Wifi:
      @firex726 said in PanelDue and Motors will not function properly with Duet Wifi:
      M574 X2 S1 P"xstop"
      https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_Set_endstop_configuration
      Xnnn Position of X endstop: 0 = none, 1 = low end, 2 = high end.
      X2 will give you 280. X1 will give you 0.
      I understand, but if it's X1 I get 0 and then it wont mover left or right, since it wont move into a negative, just like how it wont move beyond 280 since that's what I set the far limit to. And otherwise it'll slam into the endstop flag if I moved it using a positive movement command.
      If I set it for X2 then it's at +280 and I can move it using negative movement commands, but I don't think I've seen an option in Cura to invert an axis movement commands. That and it'd all be mirrored based off the way it'd appear in the slicer, wouldn't it?
        A Former User
        In a cartesian printer i would say your motor turns the wrong direction, but not familiar with corexy. In any case if you want X=0 when homing you need to use X1 as a parameter.
        firex726undefined 1 Reply Last reply Reply Quote 0
        • firex726undefined
          Thanks for the suggestion, yea it's my first CoreXY too. I guess the big question is where in the files is it defined that X home is next to Beta motor? I guess worst case I can just dismantle the carriage and flip it so it'll be correct, but I've seen commercial and hobbyist printers with the motors at the front.
          Flipping just the one results in the axis being flipped when moving.
            A Former User @firex726
            its between M208 that defines the min/max value, and M574 X1/X2 that defines if the home value is at the min or max value.
            • firex726undefined
              its between M280 that defines the min/max value, and M574 X1/X2 that defines if the home value is at the min or max value.
              Just in case I tried swapping both M208 and M574, as well at each individually and same end effect. With a positive movement making it move further into the endstop and negative away like I intend.
              I wonder, instead of defining it has having X280, Y280, and Z280, could I change it to X-280, Y280, and Z280.
              • infiniteloopundefined
                infiniteloop @firex726
                Time for a mental reboot. – Looking at X and Y, you can move your print head along these axes, and, with the end stops, you can tell the Duet which coordinate to reference for any further moves. You’ve got your steps/mm right…
                That are the basics. Now, a second concept comes into play: a coordinate system you and your slicer understand. Just to be clear: Cura is quite flexible, so it’s up to you which idea you are most comfortable with.
                The origin of this system can be in any corner, it can even be in the center of your bed, leaving you with 4 quadrants to deal with. In config.g, you use M208 to define the area your head can reach, in coordinates relative to the origin you want. These can be negative, too - remember, the end stops are only an initial reference point.
                This is key: select an origin of your choice, then, stay with that. If something goes wrong, it’s just a question of Gcodes.
                Homing just means to confirm the minimum or maximum coordinate you have defined in M208. It’s that simple. If you become comfortable with your coordinate system, it is easy to detect when a stepper’s direction is inverted. Just invert it in Gcode: dunnit.
                • firex726undefined
                  firex726 @infiniteloop
                  @infiniteloop said in PanelDue and Motors will not function properly with Duet Wifi:
                  Well that's what I thought I was doing... I have two other machines with their origin in the front left.
                  For M208 I tried it with the default min max at 0/280. And also flipped as 280/0 with the same movement behavior; as well as changing the endstop from Low side to High side, and also motor direction.
                  I'm not sure what other options I can flip...
                  Y has been behaving like I intend with no major fiddling, so that's why I assume it's only something with X.
                    Phaedrux Moderator @firex726
                    Both endstops are triggered near Alpha in the previously posted photo.
                    Are your motors at the back of the printer, or the front?
                    Perhaps could you post a photo of your printer showing the locations of things? That can help a lot getting us on the same page.
                    There's also the motor movement tests here: https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter
                    • mrehorstdmdundefined
                      mrehorstdmd
                      I don't know if it will help, but I did a blog post on setting up the origin and endstops so that the origin is at the center of the bed. If you use Cura, setting the origin at the center makes it especially easy to set up a custom printer because you simply check the "origin is at center" box and Cura will drop prints at the center of the bed.
                      See: https://drmrehorst.blogspot.com/2018/07/ummd-better-way-to-set-up-origin-and.html
                      • firex726undefined
                        firex726 @Phaedrux
                        @Phaedrux said in PanelDue and Motors will not function properly with Duet Wifi:
                        Front... So in the previous diagram, Beta is to my right, and Alpha to my left.
                        The home for X and Y is the corner near Alpha; where both endstops are.
                        My intention is that Alpha corner is X0, and Beta is X+280. But with all my flipping it keeps wanting positive movement commands to move it further into Alpha.
                        I'll have to get home to test exactly, but as I recall if Alpha is 0 then positive moments will move it further into Alpha. And if it's set for +280 then I'll need to command it to move -280 over to Beta where it'll be at 0, and then positive commands will move like normal.
                        • firex726undefined
                          firex726
                          Found an old photo, it has the motor mounts and I added the coordinates on where it's trying to move.
                            Have you gone through the corexy setup link I posted above?
                            • firex726undefined
                              firex726 @Phaedrux
                              I'll double check, but as I recall I did, and the motor movement is OK unless I home them. Since it'll think they are someplace they are not.
                              I think the issue is I have a Left hand system:
                              Important: make sure that you have chosen a right-hand axis system. That is, looking down on the printer the +Y direction should be 90 degrees anticlockwise from the +X direction. If instead it is 90 degrees clockwise, you have a left-hand axis system, which will give you mirror-image prints.
                                Yes, exactly.
                                If you go through that link again you can at least verify that the motors are turning correctly.
                                The rest comes down to getting the M208 min and max sizes correct, getting the endstop positions reflected accurately in M574, and then having the homing move directions correct in the homing macros.
                                Using this photo as an example
                                M208 X0 Y0 Z0 S1 ; axis minima
                                M208 X300 Y200 Z300 S0 ; axis maxima
                                M574 X1 Y2 Z2 S1 ; x endstop at low end, y at high end, Z at high end.
                                X homing moves are negative, Y homing moves are positive.
                                Compare your setup to that photo and see what differs.
                                • firex726undefined
                                  firex726 @Phaedrux
                                  OK two parts...
                                  Now I remember, the article listed seems a bit out dated, I keep getting warnings of obsolete commands. As @dc42 noted, the commands I should use are "G1 H2 X20", which based off the article looks like it's working as intended. The carriage moves in a diagonal path towards +X/+Y.
                                  If the head moves diagonally in the +X and +Y directions, all is well.
                                  For your example photo, I redid mine to match, with the endstop in the back, and set X to low and Y to high.
                                  I tried the following config settings all with the same effect; the carriage follows negative homing commands moving it to the right (Beta) and away from the endstop (Alpha).
                                  M208 X280 Y280 Z280 S0 ; axis maxima
                                  M574 X1 S1 P"xstop"
                                  M574 Y2 S1 P"ystop"
                                  M208 X280 Y0 Z0 S1 ; axis minima
                                  M208 X0 Y280 Z280 S0 ; axis maxima
                                  M574 X1 S1 P"xstop"
                                  M574 Y2 S1 P"ystop"
                                  M574 X2 S1 P"xstop"
                                  M574 Y2 S1 P"ystop"
                                  Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                    Did you send G91 first?
                                      M574 X1 S1 P"xstop"
                                      M574 Y2 S1 P"ystop"
                                      This one is correct. The others are not.
                                      • firex726undefined
                                        firex726 @Phaedrux
                                        Yes, I followed all the commands on the article as written, save for the movement syntax noted earlier.
                                        Then those are currently loaded.
                                        I got an updated photo.
                                        • firex726undefined
                                          firex726
                                          If I reverse the X/Y motor directions, then that fixes X, but transfers the issue to Y.
                                          So it'll HomeAll at the corner of Alpha, but any +Y command will make the carriage try to move more towards the front. So I can neither move it +Y since it'll hit the frame, nor -Y since the firmware wont let it move to less than 0.
                                          And if I then swap the Y limits it appears to have no effect.
                                          M208 X0 Y280 Z0 S1 ; set axis minima
                                          M208 X280 Y0 Z280 S0 ; set axis maxima
                                          I can set the Y endstop to the highside but then when I home it'll think it's at 0, 280, 0. Which atleast then will allow further movement, but only in a negative. And then when I try to print something it'll use +Y commands and thus hit the frame.
                                          firex726undefined infiniteloopundefined 2 Replies Last reply Reply Quote 0
                                          • firex726undefined
                                            firex726 @firex726
                                            This post is deleted!
