    PanelDue and Motors will not function properly with Duet Wifi
    80
    3.9k
    • firex726undefined
      firex726 @infiniteloop
      @infiniteloop said in PanelDue and Motors will not function properly with Duet Wifi:
      @firex726 said in PanelDue and Motors will not function properly with Duet Wifi:
      Just in case I tried swapping both M208 and M574, as well at each individually and same end effect. With a positive movement making it move further into the endstop and negative away like I intend.
      This is key: select an origin of your choice, then, stay with that. If something goes wrong, it’s just a question of Gcodes.
      Homing just means to confirm the minimum or maximum coordinate you have defined in M208. It’s that simple. If you become comfortable with your coordinate system, it is easy to detect when a stepper’s direction is inverted. Just invert it in Gcode: dunnit.
      Well that's what I thought I was doing... I have two other machines with their origin in the front left.
      For M208 I tried it with the default min max at 0/280. And also flipped as 280/0 with the same movement behavior; as well as changing the endstop from Low side to High side, and also motor direction.
      I'm not sure what other options I can flip...
      Y has been behaving like I intend with no major fiddling, so that's why I assume it's only something with X.
        Phaedrux Moderator @firex726
        Both endstops are triggered near Alpha in the previously posted photo.
        Are your motors at the back of the printer, or the front?
        Perhaps could you post a photo of your printer showing the locations of things? That can help a lot getting us on the same page.
        There's also the motor movement tests here: https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter
        firex726undefined 1 Reply Last reply Reply Quote 0
        • mrehorstdmdundefined
          mrehorstdmd
          I don't know if it will help, but I did a blog post on setting up the origin and endstops so that the origin is at the center of the bed. If you use Cura, setting the origin at the center makes it especially easy to set up a custom printer because you simply check the "origin is at center" box and Cura will drop prints at the center of the bed.
          See: https://drmrehorst.blogspot.com/2018/07/ummd-better-way-to-set-up-origin-and.html
          • firex726undefined
            firex726 @Phaedrux
            @Phaedrux said in PanelDue and Motors will not function properly with Duet Wifi:
            Front... So in the previous diagram, Beta is to my right, and Alpha to my left.
            The home for X and Y is the corner near Alpha; where both endstops are.
            My intention is that Alpha corner is X0, and Beta is X+280. But with all my flipping it keeps wanting positive movement commands to move it further into Alpha.
            I'll have to get home to test exactly, but as I recall if Alpha is 0 then positive moments will move it further into Alpha. And if it's set for +280 then I'll need to command it to move -280 over to Beta where it'll be at 0, and then positive commands will move like normal.
            • firex726undefined
              firex726
              Found an old photo, it has the motor mounts and I added the coordinates on where it's trying to move.
                Have you gone through the corexy setup link I posted above?
                • firex726undefined
                  firex726 @Phaedrux
                  I'll double check, but as I recall I did, and the motor movement is OK unless I home them. Since it'll think they are someplace they are not.
                  I think the issue is I have a Left hand system:
                  Important: make sure that you have chosen a right-hand axis system. That is, looking down on the printer the +Y direction should be 90 degrees anticlockwise from the +X direction. If instead it is 90 degrees clockwise, you have a left-hand axis system, which will give you mirror-image prints.
                    Yes, exactly.
                    If you go through that link again you can at least verify that the motors are turning correctly.
                    The rest comes down to getting the M208 min and max sizes correct, getting the endstop positions reflected accurately in M574, and then having the homing move directions correct in the homing macros.
                    Using this photo as an example
                    M208 X0 Y0 Z0 S1 ; axis minima
                    M208 X300 Y200 Z300 S0 ; axis maxima
                    M574 X1 Y2 Z2 S1 ; x endstop at low end, y at high end, Z at high end.
                    X homing moves are negative, Y homing moves are positive.
                    Compare your setup to that photo and see what differs.
                    • firex726undefined
                      firex726 @Phaedrux
                      OK two parts...
                      Now I remember, the article listed seems a bit out dated, I keep getting warnings of obsolete commands. As @dc42 noted, the commands I should use are "G1 H2 X20", which based off the article looks like it's working as intended. The carriage moves in a diagonal path towards +X/+Y.
                      If the head moves diagonally in the +X and +Y directions, all is well.
                      For your example photo, I redid mine to match, with the endstop in the back, and set X to low and Y to high.
                      I tried the following config settings all with the same effect; the carriage follows negative homing commands moving it to the right (Beta) and away from the endstop (Alpha).
                      M208 X280 Y280 Z280 S0 ; axis maxima
                      M574 X1 S1 P"xstop"
                      M574 Y2 S1 P"ystop"
                      M208 X280 Y0 Z0 S1 ; axis minima
                      M208 X0 Y280 Z280 S0 ; axis maxima
                      M574 X1 S1 P"xstop"
                      M574 Y2 S1 P"ystop"
                      M574 X2 S1 P"xstop"
                      M574 Y2 S1 P"ystop"
                      Phaedruxundefined 2 Replies Last reply Reply Quote 0
                        Did you send G91 first?
                          M574 X1 S1 P"xstop"
                          M574 Y2 S1 P"ystop"
                          This one is correct. The others are not.
                          • firex726undefined
                            firex726 @Phaedrux
                            Yes, I followed all the commands on the article as written, save for the movement syntax noted earlier.
                            Then those are currently loaded.
                            I got an updated photo.
                            • firex726undefined
                              firex726
                              If I reverse the X/Y motor directions, then that fixes X, but transfers the issue to Y.
                              So it'll HomeAll at the corner of Alpha, but any +Y command will make the carriage try to move more towards the front. So I can neither move it +Y since it'll hit the frame, nor -Y since the firmware wont let it move to less than 0.
                              And if I then swap the Y limits it appears to have no effect.
                              M208 X0 Y280 Z0 S1 ; set axis minima
                              M208 X280 Y0 Z280 S0 ; set axis maxima
                              I can set the Y endstop to the highside but then when I home it'll think it's at 0, 280, 0. Which atleast then will allow further movement, but only in a negative. And then when I try to print something it'll use +Y commands and thus hit the frame.
                              firex726undefined infiniteloopundefined 2 Replies Last reply Reply Quote 0
                              • firex726undefined
                                firex726 @firex726
                                This post is deleted!
                                • infiniteloopundefined
                                  infiniteloop @firex726
                                  @firex726
                                  M574 X1 S1 P"xstop"
                                  M574 Y2 S1 P"ystop"
                                  I’m not quite sure, it’s a complicated thread, but if your endstop for Y is at the front of your printer and if you want the X/Y origin to be in the front left corner, I think you must change the last line to
                                  M574 Y1 S1
                                  because - if I’m right - the Y-endstop sits at the low end.
                                  • firex726undefined
                                    @firex726
                                    M574 X1 S1 P"xstop"
                                    M574 Y2 S1 P"ystop"
                                    M574 Y1 S1
                                    Double checked to try that, and it'll set it to 0, 0, 0. But any +Y command will keep it going towards the front of the frame.
                                    I guess I want to mirror the Y while also keeping 0 at the corner, but instead of moving forward for +Y it'll go back.
                                    Make sense?
                                      @firex726 That makes sense, if you want to have the origin of the X/Y coordinate system to be front/left.
                                      – Just to be clear: at this point in space and time, your end stops and your min./max. settings are perfect. Don’t touch these lines again. –
                                      Now, the question is how to change the direction of a single axis on a coreXY: honestly, I don’t know. With my cartesian, it’s simple, but here, either you know what to do, or one of the coreXY experts has to chime in.
                                      Last, you will likely have to adjust your homeXY moves - possibly to a negative Y value.
                                      • firex726undefined
                                        Tried that too... Sadly the issue is just when it's home. If I just move it around manually it'll be OK.
                                        The motors and endstops seem to be OK based off the linked articles; it's just logically it think's it's mirrored once it hits home.
                                        I think it was noted earlier that the firmware is expecting a Right hand build, but I have a Left hand one, so one axis will be flipped.
                                          @firex726
                                          I noticed that. What I do not understand is this:
                                          You mean that before homing, positive Y values move the head to the back of the printer?
                                          • firex726undefined
                                            Sadly no... Whichever is mirrored will move in the opposite direction. But due to the design of the mount it's easier to deal with on the Y.
                                            I think I may just rebuild it to how the firmware thinks it's designed. I had assumed there would just be a simple setting I could flip to mirror whatever axis I want.
